1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Help with rtems nfs mounting
From: "Miceli, Antonino via Tech-talk" <[email protected]>
Date: Fri, 6 Sep 2024 20:27:59 +0000
I have some legacy rtems IOCs. I can't get the NFS mount to work after our IT upgraded to RHEL9. So, they setup an RHEL8 VM with nfs v2 activated.  They say it is working:
[root@dplab ~]# mount -o vers=2 rtems-dserv:/xorApps  /mnt
[root@dplab ~]# mount | grep mnt
rtems-dserv:/xorApps on /mnt type nfs (rw,vers=2,addr=10.54.100.9)
But not of the IOC below....
Any advices on debugging this?
B$ printenv
FACTORY=Arcturus Networks Inc.
REVISION=uC5282-16E16C64
SERIAL=X4CB88918-01660
CONSOLE=ttyS0
KERNEL=0:linux.bin
KERNEL_ARGS=root=/dev/mtdblock0 quiet
HWADDR0=00:06:3b:01:36:60
FW_VERSION=010809000
RAMIMAGE=yes
CACHE=on
_0=10000000:400000:RW
BOOTFILE=/xorApps/epics/synApps_5_3/ioc/dth/bin/RTEMS-uC5282/dthApp.boot
CMDLINE=/xorApps/epics/synApps_5_3/ioc/dth/iocBoot/iocdth3/st.rtems.cmd
NETMASK=255.255.255.0
AUTOBOOT=20
HOSTNAME=iocdth3
IPADDR0=10.54.112.70
GATEWAY=10.54.112.1
NAMESERVER=10.54.100.9
SERVER=10.54.100.9
NTPSERVER=10.54.100.9
NFSMOUNT=10.54.100.9:/xorApps:/xorApps
B$ go!
go!: command not found
B$ go
Copy...done
go! 0x40000
***** Initializing network *****
Startup after Software reset.
fs1: Ethernet address: 00:06:3b:01:36:60
***** Initializing NFS *****
This is RTEMS-RPCIOD Release $Name: rtems-addon-packages-4-7-1 $
($Id: rpcio.c,v 1.4 2006/08/30 13:52:10 joel Exp $)
Till Straumann, Stanford/SLAC/SSRL 2002
See LICENSE file for licensing info
This is RTEMS-NFS Release $Name: rtems-addon-packages-4-7-1 $
($Id: nfs.c,v 1.3 2006/06/20 00:36:25 ericn Exp $)
Trying to mount 10.54.100.9:/xorApps on /xorApps
RPCIO: server '10.54.100.9' not responding - still trying
***** Initializing NTP *****
    *************** WARNING ***************
    ***** NO RESPONSE FROM NTP SERVER *****
    *****  TIME SET TO DEFAULT VALUE  *****
***** Starting EPICS application *****
# RTEMS startup file for the uCDIMM
# NFS mount external file systems
< ../nfsCommands
#nfsMount s100dserv.xray.aps.anl.gov /APSshare /APSshare
nfsMount rtems-dserv.xray.aps.anl.gov /APSshare /APSshare
nfsMount: host 'rtems-dserv.xray.aps.anl.gov' not found
Nino
Re: Help with rtems nfs mounting Knap, Giles (DLSLtd,RAL,LSCI) via Tech-talk
Re: Help with rtems nfs mounting Chris Johns via Tech-talk
Prev: OPCUA v0.10: full support for open62541 SDK client Ralph Lange via Tech-talk
Next: Re: Help with rtems nfs mounting Knap, Giles (DLSLtd,RAL,LSCI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
