1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: Help with rtems nfs mounting
From: Chris Johns via Tech-talk <[email protected]>
To: "Miceli, Antonino" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 9 Sep 2024 07:18:17 +1000
On 7/9/2024 6:27 am, Miceli, Antonino via Tech-talk wrote:
> Hi,
> I have some legacy rtems IOCs. I can't get the NFS mount to work after our IT
> upgraded to RHEL9. So, they setup an RHEL8 VM with nfs v2 activated.  They say
> it is working:
> [root@dplab ~]# mount -o vers=2 rtems-dserv:/xorApps  /mnt
> [root@dplab ~]# mount | grep mnt
> rtems-dserv:/xorApps on /mnt type nfs (rw,vers=2,addr=10.54.100.9)
> But not of the IOC below....
> Any advices on debugging this?
> B$ printenv
> FACTORY=Arcturus Networks Inc.
> REVISION=uC5282-16E16C64
> SERIAL=X4CB88918-01660
> CONSOLE=ttyS0
> KERNEL=0:linux.bin
> KERNEL_ARGS=root=/dev/mtdblock0 quiet
> HWADDR0=00:06:3b:01:36:60
> FW_VERSION=010809000
> RAMIMAGE=yes
> CACHE=on
> _0=10000000:400000:RW
> BOOTFILE=/xorApps/epics/synApps_5_3/ioc/dth/bin/RTEMS-uC5282/dthApp.boot
> CMDLINE=/xorApps/epics/synApps_5_3/ioc/dth/iocBoot/iocdth3/st.rtems.cmd
> NETMASK=255.255.255.0
> AUTOBOOT=20
> HOSTNAME=iocdth3
> IPADDR0=10.54.112.70
> GATEWAY=10.54.112.1
> NAMESERVER=10.54.100.9
> SERVER=10.54.100.9
> NTPSERVER=10.54.100.9
> NFSMOUNT=10.54.100.9:/xorApps:/xorApps
> B$ go!
> go!: command not found
> B$ go
> Copy...done
> go! 0x40000
> ***** Initializing network *****
> Startup after Software reset.
> fs1: Ethernet address: 00:06:3b:01:36:60
> ***** Initializing NFS *****
> This is RTEMS-RPCIOD Release $Name: rtems-addon-packages-4-7-1 $
> ($Id: rpcio.c,v 1.4 2006/08/30 13:52:10 joel Exp $)
> Till Straumann, Stanford/SLAC/SSRL 2002
> See LICENSE file for licensing info
> This is RTEMS-NFS Release $Name: rtems-addon-packages-4-7-1 $
> ($Id: nfs.c,v 1.3 2006/06/20 00:36:25 ericn Exp $)
> Trying to mount 10.54.100.9:/xorApps on /xorApps
> RPCIO: server '10.54.100.9' not responding - still trying
This message can happen if the RPC requests times out [1]. I could check NFSv2
RPC support is not firewalled or something like that. Also ..
Is the gateway 10.54.112.1 working?
Are other services like NTP working?
Chris
[1]
https://urldefense.us/v3/__https://gitlab.rtems.org/rtems/pkg/rtems-net-legacy/-/blob/main/nfsclient/src/rpcio.c?ref_type=heads*L1379__;Iw!!G_uCfscf7eWS!bY-GqBCf1ym5iz-IBJzf5vV5nAAH-kyZz_dpPz7gHimhFNnuMEHR44Q70mNpzk2hQbM3yPKNRiDe5J5HN-w$
> ***** Initializing NTP *****
>     *************** WARNING ***************
>     ***** NO RESPONSE FROM NTP SERVER *****
>     *****  TIME SET TO DEFAULT VALUE  *****
> ***** Starting EPICS application *****
> # RTEMS startup file for the uCDIMM
> # NFS mount external file systems
> < ../nfsCommands
> #nfsMount s100dserv.xray.aps.anl.gov /APSshare /APSshare
> nfsMount rtems-dserv.xray.aps.anl.gov /APSshare /APSshare
> nfsMount: host 'rtems-dserv.xray.aps.anl.gov' not found
> Thanks,
> Nino
Help with rtems nfs mounting Miceli, Antonino via Tech-talk
Prev: Re: Help with rtems nfs mounting Johnson, Andrew N. via Tech-talk
Next: Re: Help with rtems nfs mounting Knap, Giles (DLSLtd,RAL,LSCI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: Re: Help with rtems nfs mounting Chris Johns via Tech-talk
Next: The teck-talk mailing list seems to be unarchived Shuei YAMADA via Tech-talk
