1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: Help with rtems nfs mounting
From: "Knap, Giles \(DLSLtd,RAL,LSCI\) via Tech-talk" <[email protected]>
To: Chris Johns <[email protected]>, "[email protected]" <[email protected]>, "Miceli, Antonino" <[email protected]>
Cc: "Malowany, Alex \(DLSLtd,RAL,LSCI\)" <[email protected]>
Date: Mon, 9 Sep 2024 06:16:02 +0000
Hi Chris,
Re RTEMS 6 and libbsd - there are some issues with using this on the M7400 processor we are using. Some of the folk in accelerator controls at DLS have been looking into resolving that. We are using your patched epics-base with legacy networking in the interim.
Cheers,
giles
Sent: 08 September 2024 22:19
To: Knap, Giles (DLSLtd,RAL,LSCI) <[email protected]>; [email protected] <[email protected]>; Miceli, Antonino <[email protected]>
Cc: Malowany, Alex (DLSLtd,RAL,LSCI) <[email protected]>
[You don't often get email from [email protected]. Learn why this is important at https://aka.ms/LearnAboutSenderIdentification ]
On 7/9/2024 7:15 am, Knap, Giles (DLSLtd,RAL,LSCI) via Tech-talk wrote:
> I can't help with the debugging but I have made RTEMS5 and 6 connect to NFSv2
> using a user space NFSv2 driver running on RHEL8.
> At DLS we are still running RHEL 7 to serve NFSv2 to our VxWorks and RTEMS IOCs.
> However we have been looking to retire those servers.
RTEMS 6 with libbsd supports NFSv4.
Chris
> I have had success with the user space NFSv2 running in a container in
> Kubernetes. However you could also try compiling the driver natively using the
> steps in the Dockerfile. See epics-containers/nfsv2-tftp-server: User space
> NFSv2 and TFTP server for experimenting with RTEMS booting (github.com)
> <https://eur03.safelinks.protection.outlook.com/?url="">>
> Copying Alex: as you were planning to test switching on NFSv2 on RHEL8 I thought
> you might be interested to hear that there may be issues.
> Cheers,
> giles
> *From:* Tech-talk <[email protected]> on behalf of Miceli, Antonino
> via Tech-talk <[email protected]>
> *Sent:* 06 September 2024 21:27
> *To:* [email protected] <[email protected]>
> *Subject:* Help with rtems nfs mounting
> Hi,
> I have some legacy rtems IOCs. I can't get the NFS mount to work after our IT
> upgraded to RHEL9. So, they setup an RHEL8 VM with nfs v2 activated.  They say
> it is working:
> [root@dplab ~]# mount -o vers=2 rtems-dserv:/xorApps  /mnt
> [root@dplab ~]# mount | grep mnt
> rtems-dserv:/xorApps on /mnt type nfs (rw,vers=2,addr=10.54.100.9)
> But not of the IOC below....
> Any advices on debugging this?
> B$ printenv
> FACTORY=Arcturus Networks Inc.
> REVISION=uC5282-16E16C64
> SERIAL=X4CB88918-01660
> CONSOLE=ttyS0
> KERNEL=0:linux.bin
> KERNEL_ARGS=root=/dev/mtdblock0 quiet
> HWADDR0=00:06:3b:01:36:60
> FW_VERSION=010809000
> RAMIMAGE=yes
> CACHE=on
> _0=10000000:400000:RW
> BOOTFILE=/xorApps/epics/synApps_5_3/ioc/dth/bin/RTEMS-uC5282/dthApp.boot
> CMDLINE=/xorApps/epics/synApps_5_3/ioc/dth/iocBoot/iocdth3/st.rtems.cmd
> NETMASK=255.255.255.0
> AUTOBOOT=20
> HOSTNAME=iocdth3
> IPADDR0=10.54.112.70
> GATEWAY=10.54.112.1
> NAMESERVER=10.54.100.9
> SERVER=10.54.100.9
> NTPSERVER=10.54.100.9
> NFSMOUNT=10.54.100.9:/xorApps:/xorApps
> B$ go!
> go!: command not found
> B$ go
> Copy...done
> go! 0x40000
> ***** Initializing network *****
> Startup after Software reset.
> fs1: Ethernet address: 00:06:3b:01:36:60
> ***** Initializing NFS *****
> This is RTEMS-RPCIOD Release $Name: rtems-addon-packages-4-7-1 $
> ($Id: rpcio.c,v 1.4 2006/08/30 13:52:10 joel Exp $)
> Till Straumann, Stanford/SLAC/SSRL 2002
> See LICENSE file for licensing info
> This is RTEMS-NFS Release $Name: rtems-addon-packages-4-7-1 $
> ($Id: nfs.c,v 1.3 2006/06/20 00:36:25 ericn Exp $)
> Trying to mount 10.54.100.9:/xorApps on /xorApps
> RPCIO: server '10.54.100.9' not responding - still trying
> ***** Initializing NTP *****
>     *************** WARNING ***************
>     ***** NO RESPONSE FROM NTP SERVER *****
>     *****  TIME SET TO DEFAULT VALUE  *****
> ***** Starting EPICS application *****
> # RTEMS startup file for the uCDIMM
> # NFS mount external file systems
> < ../nfsCommands
> #nfsMount s100dserv.xray.aps.anl.gov /APSshare /APSshare
> nfsMount rtems-dserv.xray.aps.anl.gov /APSshare /APSshare
> nfsMount: host 'rtems-dserv.xray.aps.anl.gov' not found
> Thanks,
> Nino
> This e-mail and any attachments may contain confidential, copyright and or
> privileged material, and are for the use of the intended addressee only. If you
> are not the intended addressee or an authorised recipient of the addressee
> please notify us of receipt by returning the e-mail and do not use, copy,
> retain, distribute or disclose the information in or attached to the e-mail. Any
> opinions expressed within this e-mail are those of the individual and not
> necessarily of Diamond Light Source Ltd.
> Diamond Light Source Ltd. cannot guarantee that this e-mail or any attachments
> are free from viruses and we cannot accept liability for any damage which you
> may sustain as a result of software viruses which may be transmitted in or with
> the message.
> Diamond Light Source Limited (company no. 4375679). Registered in England and
> Wales with its registered office at Diamond House, Harwell Science and
> Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United Kingdom.
This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee please notify us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail. Any opinions expressed within this e-mail are those of the individual and not necessarily of Diamond Light Source Ltd.
Diamond Light Source Limited (company no. 4375679). Registered in England and Wales with its registered office at Diamond House, Harwell Science and Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United Kingdom.
Re: Help with rtems nfs mounting Chris Johns via Tech-talk
Help with rtems nfs mounting Miceli, Antonino via Tech-talk
Re: Help with rtems nfs mounting Knap, Giles (DLSLtd,RAL,LSCI) via Tech-talk
Prev: Re: Help with rtems nfs mounting Chris Johns via Tech-talk
Next: Re: Adding additional fields to be archived in "policies.py" Gerrit Kühn via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: Re: Help with rtems nfs mounting Johnson, Andrew N. via Tech-talk
Next: Re: Help with rtems nfs mounting Chris Johns via Tech-talk
