1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: HTTP PUT Request - StreamDevice
From: Zimoch Dirk via Tech-talk <[email protected]>
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 12 Sep 2024 13:06:28 +0000
Kyle,
If you are in doubt what the StreamDevice protocol really sends (" or \") I
suggest you start on your local (Linux) pc:
ncat -l -p 8080
(ncat may also be installed as netcat or nc)
and then connect to your PC port 8080 instead of your device port 80.
You should then see what exactly is sent.
Dirk
On Thu, 2024-09-12 at 15:00 +0200, Zimoch Dirk wrote:
> Hi Kyle,
> No need to escape " inside '. For the curl command, '...' simply tells the shell
> to pass the inner "..." to curl as part of the string. The same works in the
> StreamDevice Protocol.
> I suspect the problem somewhere else: Asyn does not disconnect as curl does. I
> think, the device may wait for further input.
> Try to add a disconnect command at the end of the protocol:
> set_host{    out 'PUT /io/net/hostname/value.json HTTP/1.1';
>              out '"New-Hostname"';
>              disconnect; }
> And call drvAsynIPPortConfigure with the "http" option:
> drvAsynIPPortConfigure "fx4","129.57.203.137:80 http"
> This will let asyn expect the connection to disconnect and will automatically
> re-connect with the next call without generating error messages.
> You may need disconnect for any http protocol that ends with an 'out' command
> rather than an 'in'. (In case of an 'in', the device closes the http connection
> after it finished sending. That's why reading the host name worked.)
> Dirk
> On Thu, 2024-09-12 at 12:31 +0000, Kyle Hesse wrote:
> > Hi Dirk,
> > Thank you for your response. I tried both of your suggested methods of
> > set_host{
> >     out 'PUT /io/net/hostname/value.json HTTP/1.1\r\n\r\n"New-Hostname"';
> > and
> > OutTerminator = CR LF CR LF;
> >              out '"New-Hostname"';}
> > I am getting a response of HTTP/1.1 200 OK, however the hostname will not change. I also tried to add in some of the other header lines but had the same result.
> > I noticed when using curl, the hostname had to be supplied with two sets of quotes:
> >      curl -X PUT -d '"New-Hostname"' https://urldefense.us/v3/__http://129.57.203.137/io/net/hostname/value.json__;!!G_uCfscf7eWS!f2iCiQGHLCo4zirNKT8KV6eoJ9zO-WPIZ3eoam1rcP19duepfpWJg0ciIQuPi42G_MTHQSyoMp56tzkq96A3vBzyzQ$
> > When I send the previously mentioned requests I noticed in the console the quotes are escaped:
> > Command:
> >      set_host{ out 'PUT /io/net/hostname/value.json HTTP/1.1\r\n\r\n"New-Hostname"'; }
> > Console:
> >      asynSetTraceMask("fx4",-1,0x9)
> >      asynSetTraceIOMask("fx4",-1,0x2)
> >      2024/09/11 16:02:41.166 129.57.203.137:80 HTTP write 57
> >      PUT io/net/hostname/value.json HTTP/1.1\r\n\r\n\"New-Hostname\"
> > If I send a curl command with escaped quotes, the name will not change:
> > curl -X PUT -d '\"New-Hostname\"' https://urldefense.us/v3/__http://129.57.203.137/io/net/hostname/value.json__;!!G_uCfscf7eWS!f2iCiQGHLCo4zirNKT8KV6eoJ9zO-WPIZ3eoam1rcP19duepfpWJg0ciIQuPi42G_MTHQSyoMp56tzkq96A3vBzyzQ$
> > Any suggestions on the way the quotes are escaped in StreamDevice?
> > Thanks,
> > Kyle
> > From: Zimoch Dirk <[email protected]>
> > Sent: Wednesday, September 11, 2024 10:51 AM
> > To: Kyle Hesse <[email protected]>; [email protected] <[email protected]>
> > Subject: [EXTERNAL] Re: HTTP PUT Request - StreamDevice
> > Hello Kyle,
> > For testing, I have started a fake server with:
> > ncat -l -p 8080
> > And have sent the command to it:
> > curl -X PUT -d '"New-Hostname"' \
> > https://urldefense.proofpoint.com/v2/url?u=http-3A__fakeserver-3A8080_ioc_net_hostname_value.json&d=DwIGaQ&c=CJqEzB1piLOyyvZjb8YUQw&r=XoO1MAWp671dzq4GtQTw9Q&m=pruKbDwo_Ww12xZBNKqD_nl0qd9_KdK7lo963LHk6QsNWd0CuqhdAsaMbOecVx3N&s=rdFe2srdAMqV1w77G326beUJgCVs9s0rdRZjRtfs5R8&e=
> > What I see in ncat is:
> > PUT /ioc/net/hostname/value.json HTTP/1.1
> > Host: fakeserver:8080
> > User-Agent: curl/7.61.1
> > Accept: */*
> > Content-Length: 14
> > Content-Type: application/x-www-form-urlencoded
> > "New-Hostname"[no newline!]
> > I guess some lines may be optional, but one thing is important:
> > There is an empty line between header and content. Be aware that your
> > OutTerminator is only added at the end or out commands (where curl did not
> > bother to add any terminator).
> > Thus I suggest you either add the empty line manually:
> > set_host{
> > Or alternatively use 2 out commands, each will be terminated with CR LF CR LF.
> > If that is still not sufficient, try to add some of the other header lines, but
> > have an empty line only directly before the content.
> > Dirk
> > On Wed, 2024-09-11 at 14:26 +0000, Zimoch Dirk via Tech-talk wrote:
> > > Hi Kyle,
> > > I will have a look...
> > > Dirk
> > > On Wed, 2024-09-11 at 14:19 +0000, Kyle Hesse via Tech-talk wrote:
> > > > Hello,
> > > > I'm working with a Pyramid FX4 Device. I'd like to use HTTP requests to communicate using StreamDevice. I'm having success using GETs, however I'm running into issues with the PUTs.
> > > > The programmer manual states to do the following:
> > > > PUT /io/net/hostname.json HTTP/1.1
> > > > "New-Hostname"
> > > > Below I've listed my configuration as well as examples for the GET and PUT requests for getting and setting the hostname.
> > > > Any help to properly form the HTTP PUT request would be greatly appreciated.
> > > > Thanks,
> > > > Kyle
> > > > Configuration:
> > > > drvAsynIPPortConfigure("fx4", "129.57.203.137:80 HTTP", 0, 0, 0)
> > > > PUT Request Example (Unsuccessful):
> > > > set_host{
> > > >     out 'PUT /io/net/hostname/value.json HTTP/1.1 "New-Hostname"';
> > > > Get Request (Successful):
> > > > hostname {
> > > >         out "GET /io/net/hostname/value.json HTTP/1.1";
> > > >                in "%*182c%[_a-zA-Z0-9]%*2c";
> > > > PS
> > > > I am able to use curl from command line to successfully set the hostname.
> > > > curl -X PUT -d '"New-Hostname"' https://urldefense.proofpoint.com/v2/url?u=https-3A__urldefense.us_v3_-5F-5Fhttp-3A__129.57.203.137_io_net_hostname_value.json-5F-5F-3B-21-21G-5FuCfscf7eWS-21f01ayFSJNsXqAAqGmOKGPXH4SuSPR-5F8UAlf8IXiWd-2DJuQtDWoFGjoDqT-2DFV3qjx0n8nkLhDvsD1Dx35nhsUmiKf7Ug-24&d=DwIGaQ&c=CJqEzB1piLOyyvZjb8YUQw&r=XoO1MAWp671dzq4GtQTw9Q&m=pruKbDwo_Ww12xZBNKqD_nl0qd9_KdK7lo963LHk6QsNWd0CuqhdAsaMbOecVx3N&s=1IQyXgaS5UUSfCyByWhQ6eRwXFXEBDKfGSpg_q4skjA&e=
HTTP PUT Request - StreamDevice Kyle Hesse via Tech-talk
Re: HTTP PUT Request - StreamDevice Zimoch Dirk via Tech-talk
Re: HTTP PUT Request - StreamDevice Kyle Hesse via Tech-talk
Prev: Re: HTTP PUT Request - StreamDevice Zimoch Dirk via Tech-talk
Next: Re: HTTP PUT Request - StreamDevice Zimoch Dirk via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
