1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: New to EPICS - wants to use motorMotorSim - Python client
From: Guijarro Mathias Charles via Tech-talk <[email protected]>
Date: Tue, 17 Sep 2024 14:36:38 +0000
Hi there,
I am new to EPICS. I would like to run a motor simulation driver (or is it IOC ? Or "server", well something I can use
to connect to, that would simulate the behaviour of a motor), and to test it with Python.
I do not want to try with Docker, as I prefer to have individual processes running locally, to learn about the
basics first.
Here is what I did so far:
- made a new Conda environment
- installed Epics from Conda , to have EPICS_BASE in $CONDA_PREFIX/epics
    - cloned submodule "motorMotorSim"
- compiled all those (first asyn, then sequencer, then motor)
    - had to guess a bit where to put EPICS_BASE directory in various configure/RULES etc
    - had to install "sun rpc" on my system, and "re2c" from conda-forge (if I remember correctly)
    - at the end I had to manually copy the include, lib, bin, dbd, db files ; is it the normal way ?
- I managed to set IOCS to True to have IOC compiled
So now I have 4 executables with the same name:
./motor/bin/linux-x86_64/motorSim
./motor/modules/motorMotorSim/iocs/motorSimIOC/bin/linux-x86_64/motorSim
./motor/modules/motorMotorSim/iocs/motorSimIOC/motorSimApp/src/O.linux-x86_64/motorSim
./motor/modules/motorMotorSim/motorSimApp/src/O.linux-x86_64/motorSim
They are different (not the same md5sum).
Running any of those gives me an "epics>" prompt.
What should I do, to run it to be able to test something with a Python client ? Or at least with caput/caget ?
How to configure it (limits, velocity, etc) ?
I could not find any guide for this on internet, or at least it was not as easy as I thought... So I prefer
to ask in order to get the "minimum viable information".
Later on I will try to run other simulated devices probably... So better to learn about the system "the hard
way" !
Any help would be appreciated.
Thanks in advance,
Matias.
RE: New to EPICS - wants to use motorMotorSim - Python client Mark Rivers via Tech-talk
Prev: Initializing lsi or waveform with long string in 3.15.9 Barrett (US), Patrick E via Tech-talk
Next: Re: Initializing lsi or waveform with long string in 3.15.9 Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: Re: Initializing lsi or waveform with long string in 3.15.9 Michael Davidsaver via Tech-talk
Next: RE: New to EPICS - wants to use motorMotorSim - Python client Mark Rivers via Tech-talk
