1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: RE: New to EPICS - wants to use motorMotorSim - Python client
To: Guijarro Mathias Charles <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 17 Sep 2024 15:58:34 +0000
Hi Matias,
I would recommend installing EPICS base with a git clone, rather than from Conda.  Then you have the full installation with RULES, test programs, etc.
  •     - had to guess a bit where to put EPICS_BASE directory in various configure/RULES etc
You should only edit [module]/configure/RELEASE
  • Define the location of EPICS_BASE for all modules
  • Define the path to the sequencer for asyn and motor
  • Define the path to asyn for motor
  •     - had to install "sun rpc" on my system, and "re2c" from conda-forge (if I remember correctly)
Depending on the version of Linux that is now typically tirpc, e.g. package libtirpc-devel on RHEL 9.
  •     - at the end I had to manually copy the include, lib, bin, dbd, db files ; is it the normal way ?
No, that is not normal.  If things are installed correctly “make” will do all of that for you.
From: Tech-talk <[email protected]> On Behalf Of Guijarro Mathias Charles via Tech-talk
Sent: Tuesday, September 17, 2024 9:37 AM
To: [email protected]
Subject: New to EPICS - wants to use motorMotorSim - Python client
Hi there,
I am new to EPICS. I would like to run a motor simulation driver (or is it IOC ? Or "server", well something I can use
to connect to, that would simulate the behaviour of a motor), and to test it with Python.
I do not want to try with Docker, as I prefer to have individual processes running locally, to learn about the
basics first.
Here is what I did so far:
- made a new Conda environment
- installed Epics from Conda , to have EPICS_BASE in $CONDA_PREFIX/epics
    - cloned submodule "motorMotorSim"
- compiled all those (first asyn, then sequencer, then motor)
- I managed to set IOCS to True to have IOC compiled
So now I have 4 executables with the same name:
./motor/bin/linux-x86_64/motorSim
./motor/modules/motorMotorSim/iocs/motorSimIOC/bin/linux-x86_64/motorSim
./motor/modules/motorMotorSim/iocs/motorSimIOC/motorSimApp/src/O.linux-x86_64/motorSim
./motor/modules/motorMotorSim/motorSimApp/src/O.linux-x86_64/motorSim
They are different (not the same md5sum).
Running any of those gives me an "epics>" prompt.
What should I do, to run it to be able to test something with a Python client ? Or at least with caput/caget ?
How to configure it (limits, velocity, etc) ?
I could not find any guide for this on internet, or at least it was not as easy as I thought... So I prefer
to ask in order to get the "minimum viable information".
Later on I will try to run other simulated devices probably... So better to learn about the system "the hard
way" !
Any help would be appreciated.
Thanks in advance,
Matias.
New to EPICS - wants to use motorMotorSim - Python client Guijarro Mathias Charles via Tech-talk
Prev: Re: Initializing lsi or waveform with long string in 3.15.9 Michael Davidsaver via Tech-talk
Next: RE: New to EPICS - wants to use motorMotorSim - Python client Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: New to EPICS - wants to use motorMotorSim - Python client Guijarro Mathias Charles via Tech-talk
