1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Smaract MCS2 position polling issue
From: Jeffrey Gamsby via Tech-talk <[email protected]>
To: [email protected]
Date: Thu, 3 Oct 2024 22:24:33 -0700
This is my first post and I'm relatively new to EPICS.
I am trying to use an MCS2 Smaract Controller with 9 axes, the issue I am having right now is the performance on the position information.
The relevant config file seems to be the smaractmcs2.iocsh and this is what I'm using:
# PORT, MCS_PORT, number of axes, active poll period (ms), idle poll period (ms)
MCS2CreateController("MCS2", "MCS2_ETH", 9, 100, 100)
It's taking more than 30 seconds for moves to complete (using DMOV), even for repeat moves that should not go anywhere.
Ideally I would want position updates for each axis in the ms range, how can I troubleshoot and solve this problem?
Jeff
Re: Smaract MCS2 position polling issue Jeffrey Gamsby via Tech-talk
Prev: RE: OPCUA SSL problem Majer Karel via Tech-talk
Next: Re: OPCUA SSL problem Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: Re: Phoebus Olog and Web Client Wang, Lin via Tech-talk
Next: Re: Smaract MCS2 position polling issue Jeffrey Gamsby via Tech-talk
