1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: Phoebus Olog and Web Client
From: "Wang, Lin via Tech-talk" <[email protected]>
To: "Dr. Simon Friederich" <[email protected]>
Cc: [email protected]
Date: Thu, 3 Oct 2024 23:02:40 +0800 (GMT+08:00)
Hello Simon,
I can answer part of the questions and am also expecting more accurate and complete answers from experts.
> - If I run the olog-docker I am in a demo mode with a user admin and user?
The user info for Olog Docker deployment is from phoebus-olog\src\main\resources\olog.ldif, which also includes "logbook", "tag" and "property" users.
> - Can I change these properties any time? (e.g. I need more logbooks, different users or tags?)
If the web client does not provide the interfaces, logbooks and tags can be managed via the REST API described in "Managing Logbooks & Tags" part of the following link,
https://urldefense.us/v3/__https://olog.readthedocs.io/en/latest/index.html__;!!G_uCfscf7eWS!fXISSw8iSiO1eaJ4sg_HJ3k49QwOu0nHUZSbj1DW1oXOcoDq2jh0xB6-l-jUBAi0xXS7zRNeJWBIcYpv8pDFp44$
> - How do I add/remove users and/or groups?
In production environment, the users and groups should be stored and managed in the LDAP service.
> - E.g. I want admin, operator, rfeng, cryoeng. If it's not mandatory, I don't want to use the LDAP service, unless it makes everything easier.
If Olog only supports LDAP authentication, a LDAP servce like Active Directory or OpenLDAP is necessary for production deployment.
> - Where are the logbooks stored and how would you backup them?
Logbooks, tags and logs are stored in Elasticsearch.
> - Can I use a mongo-GUI like mongodb compass to manage the logbook or is mongo only a backend?
No, Olog stores only attachment files in MongoDB GridFS (which supports binary larger than 16MB), and other data like logs and logbooks are stored in Elasticsearch.
Lin
> -----原始邮件-----
> 发件人: "Dr. Simon Friederich via Tech-talk" <[email protected]>
> 发送时间:2024-10-03 03:59:21 (星期四)
> 收件人: [email protected]
> 主题: [SPAM] Phoebus Olog and Web Client
> Dear Kunal,
> Dear George,
> Dear Phoebus-Olog-Team,
> Phoebus Olog:
> I am currently testing olog as your modern alternative for elog.
> Thanks to your example from the repository [1], I have now a running
> elasticsearch, mongo and olog service.
> I can access it via Phoebus with the settings.ini:
>      # Package org.phoebus.olog.es.api
>      org.phoebus.logbook/logbook_factory=olog-es
>      org.phoebus.olog.es.api/olog_url=https://urldefense.us/v3/__http://testmesaolog:8080/Olog__;!!G_uCfscf7eWS!dso4dmkrF-LWpZlpdNz3MRexqz8vRrLcyJnfweqt58VzNYt-zlwPQTyYVFpwEeDeXJQs8xSu-UMk4ZV4BLuBn_nBCHrJ8zzX$
>      org.phoebus.olog.es.api/username=user
>      org.phoebus.olog.es.api/password=userPass
> But I have some further questions I was not able to figure out for myself:
> - How do I customize my olog? I have found a cuple of files in
> phoebus-olog/src/main/resources. You mention a special github repository
> where only application.properties is used for this [2].
> - How do I add/remove users and/or groups? I do not quite understand the
> correct syntax in application.properties. Could you provide an example?
> - I have these two docker-managed volumes esdata and mongodata in the
> docker-compose.yml file. Are these important to backup?
> mongo only a backend? (Sorry for such questions, but I am not familiar
> with this yet)
> Web client:
> Then I need to access the logbooks via webbrowser. Hence, I've looked at
> your phoebus-olog-web-client [3].
> Based on your Dockerfile I've set up a docker container in the same
> network "olognet" where elastic, monogo and olog reside (though the
> ports are published on localhost) with a docker-compose file:
> Dockerfile:
>      # Node 18
>      FROM node:22-alpine
>      # FROM node:18-alpine
>      RUN apk update && apk add curl bash
>      WORKDIR /app
>      ENV PATH=/app/node_modules/.bin:$PATH
>      COPY . ./
>      RUN npm ci --silent \
>          && npx update-browserslist-db@latest
>          # && npm run build \
>          # && npm install -g serve
>      # start app
>      CMD ["npm", "start"]
>      # CMD ["serve", "-s", "build"]
> docker-compose.yml
>      networks:
>        olognet:
>          external: true
>      services:
>        olog-web:
>          container_name: "olog-web"
>          build: .
>          ports:
>            - "3000:3000"
>            # - "6006:6006" # storybook for testing
>          environment:
>            TZ: Europe/Berlin
>            # REACT_APP_BASE_URL: https://urldefense.us/v3/__http://olog:8080/Olog__;!!G_uCfscf7eWS!dso4dmkrF-LWpZlpdNz3MRexqz8vRrLcyJnfweqt58VzNYt-zlwPQTyYVFpwEeDeXJQs8xSu-UMk4ZV4BLuBn_nBCK794Uuc$  # specified in
> .env file
>          stdin_open: true # docker run -i, debug
>          tty: true        # docker run -t, debug
>          networks:
>            - olognet
>          # command: ["/bin/bash"] # debug
> I've also copied .env.example to .env and adopted to
> REACT_APP_BASE_URL=https://urldefense.us/v3/__http://olog:8080/Olog__;!!G_uCfscf7eWS!dso4dmkrF-LWpZlpdNz3MRexqz8vRrLcyJnfweqt58VzNYt-zlwPQTyYVFpwEeDeXJQs8xSu-UMk4ZV4BLuBn_nBCK794Uuc$ .
>  From within the olog-web-container I can ping the olog container and
> see the expected answer when running curl:
>      21e0630b20ba:/app# curl https://urldefense.us/v3/__http://olog:8080/Olog__;!!G_uCfscf7eWS!dso4dmkrF-LWpZlpdNz3MRexqz8vRrLcyJnfweqt58VzNYt-zlwPQTyYVFpwEeDeXJQs8xSu-UMk4ZV4BLuBn_nBCK794Uuc$
>        "name" : "Olog Service",
>        "version" : "5.0.0-SNAPSHOT",
>        "elastic" : {
>          "status" : "Connected",
>          "clusterName" : "elasticsearch",
>          "clusterUuid" : "h-dKVMuFTJSlXb0gxeFn2w",
>          "version" :
> "co.elastic.clients.elasticsearch._types.ElasticsearchVersionInfo@78b8c4e7",
>          "elasticHost" : "elastic",
>          "elasticPort" : "9200"
>        "mongoDB" : "{type=STANDALONE, servers=[{address=mongo:27017,
> type=STANDALONE, roundTripTime=0.5 ms, state=CONNECTED}]",
>        "serverConfig" : {
>          "maxFileSize" : 50.0,
>          "maxRequestSize" : 100.0
> Yet, if I access the web view on port 3000 it show the error message:
>      Search Error
>      Could not reach the logbook service
> So my question is do you see my mistake or can you tell me how to debug
> my issue?
> Thank you very much in advance
> Best regards
> Simon
> [1] https://urldefense.us/v3/__https://github.com/Olog/phoebus-olog__;!!G_uCfscf7eWS!dso4dmkrF-LWpZlpdNz3MRexqz8vRrLcyJnfweqt58VzNYt-zlwPQTyYVFpwEeDeXJQs8xSu-UMk4ZV4BLuBn_nBCAMBxssS$
> [2] https://urldefense.us/v3/__https://github.com/willrogers/olog-es-docker__;!!G_uCfscf7eWS!dso4dmkrF-LWpZlpdNz3MRexqz8vRrLcyJnfweqt58VzNYt-zlwPQTyYVFpwEeDeXJQs8xSu-UMk4ZV4BLuBn_nBCAEkg_SM$
> [3] https://urldefense.us/v3/__https://github.com/Olog/phoebus-olog-web-client__;!!G_uCfscf7eWS!dso4dmkrF-LWpZlpdNz3MRexqz8vRrLcyJnfweqt58VzNYt-zlwPQTyYVFpwEeDeXJQs8xSu-UMk4ZV4BLuBn_nBCDdGhnsq$
> Institute of Nuclear Physics
> Collaboration B | MESA
> Johannes Gutenberg-Universität Mainz
> Johann-Joachim-Becherweg 45
> 55128 Mainz, Germany
> phone: +49 (0)6131 39-23160
> E-Mail: [email protected]
Phoebus Olog and Web Client Dr. Simon Friederich via Tech-talk
Prev: Re: OPCUA SSL problem Ralph Lange via Tech-talk
Next: Re: Access to EPICS Collaboratory Meeting Recordings Kasemir, Kay via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: Re: Phoebus Olog and Web Client Wang, Lin via Tech-talk
Next: Smaract MCS2 position polling issue Jeffrey Gamsby via Tech-talk
