1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: Re: I implemented the Model 3 of EPICS motor driver support, but the VAL and RBV of motor record are zero after IOC reboot.
To: LiangChih Chiang <[email protected]>, "[email protected]" <[email protected]>, Torsten Bögershausen <[email protected]>
Date: Wed, 20 Nov 2024 15:04:28 +0000
To explain a little more, it is important that the driver has completed the first poll cycle for the position and status of each axis before iocInit.  This is because the motor record looks at those positions during iocInit, and if there are non-zero it uses those values as the current position.  You can add the following to your startup script after you create the controller and axes to sleep for 1 second.
epicsThreadSleep(1.0)
Let us know if this does not fix the problem.
From: Tech-talk <[email protected]> on behalf of Torsten Bögershausen via Tech-talk <[email protected]>
Sent: Wednesday, November 20, 2024 5:15 AM
To: LiangChih Chiang <[email protected]>; [email protected] <[email protected]>
Hej,
without having seen ypur code, I would speculate that you run
into a not-unknown issue using Model 3 motors, connected via
a serial cable, USB or Ethernet?
The value that the motorRecord needs is read from the driver,
wich must have been able to read it from your hardware.
Here are ESS we have a patched motor, which can handle this.
If you use the upstream version, the easist workaround may be
to add a sleep() after the createController() line in your st.cmd
HTH
/Torsten
On 2024-11-20 09:47, LiangChih Chiang via Tech-talk wrote:
> Hello, EPICS mates.
> I implemented the Model 3 of EPICS motor driver support for some motor
> controller,
> but the VAL and RBV of the motor record are zero after IOC reboot.
> I think the motor record doesn't restore the values of motor pulse and
> encoder count from the motor controller after IOC reboot.
> What member functions of asynMotorController and asynMotorAxis classes
> should I implement?
> Best regards.
Re: I implemented the Model 3 of EPICS motor driver support, but the VAL and RBV of motor record are zero after IOC reboot. LiangChih Chiang via Tech-talk
Re: I implemented the Model 3 of EPICS motor driver support, but the VAL and RBV of motor record are zero after IOC reboot. Torsten Bögershausen via Tech-talk
Prev: Re: I implemented the Model 3 of EPICS motor driver support, but the VAL and RBV of motor record are zero after IOC reboot. Torsten Bögershausen via Tech-talk
Next: QuadEM Update rate limited by lock Iain Marcuson via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Next: Re: I implemented the Model 3 of EPICS motor driver support, but the VAL and RBV of motor record are zero after IOC reboot. LiangChih Chiang via Tech-talk
