Hi, thanks for replying. > without having seen yourcode, I attached the source code. For the Kohzu ARIES/LYNX motor controller. > connected via a serial cable, USB or Ethernet? Ethernet. >To explain a little more, it is important that the driver has completed the first poll cycle for the position and status of each axis before iocInit. >This is because the motor record looks at those positions during iocInit, and if there are non-zero it uses those values as the current position. >You can add the following to your startup script after you create the controller and axes to sleep for 1 second. >epicsThreadSleep(1.0) Thanks a lot. Hope this will fix the issue. It may not be possible to try because it's beam time in my light source facility. On Wed, Nov 20, 2024 at 11:04 PM Mark Rivers <[email protected]> wrote:
FILENAME... KohzuAriesDriver.cpp
USAGE... Motor driver support for the Kohzu ARIES motor controller
LiangChih Chiang
December 20, 20181
#include "KohzuAriesDriver.h"
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
#include <iocsh.h>
#include <epicsThread.h>
#include <asynOctetSyncIO.h>
#include "asynMotorController.h"
#include "asynMotorAxis.h"
#include <epicsExport.h>
#define RSP_PREFIX_SUCCESS 'C'
#define RSP_PREFIX_WARNING 'W'
#define RSP_PREFIX_ERROR 'E'
#define RSP_DELIMITER "\t"
static const char *driverName = "KohzuAriesDriver";
/** Creates a new KohzuAriesController object.
* \param[in] portName The name of the asyn port that will be created for this driver
* \param[in] KohzuAriesPortName The name of the drvAsynIPPPort that was created previously to connect to the KohzuAriesPortName controller
* \param[in] numAxes The number of axes that this controller supports
* \param[in] movingPollPeriod The time between polls when any axis is moving
* \param[in] idlePollPeriod The time between polls when no axis is moving
KohzuAriesController::KohzuAriesController(const char *portName, const char *KohzuAriesPortName, int numAxes,
double movingPollPeriod, double idlePollPeriod)
: asynMotorController(portName, numAxes, NUM_KOHZUARIES_PARAMS,
0,
0,
ASYN_CANBLOCK | ASYN_MULTIDEVICE,
1, // autoconnect
0, 0) // Default priority and stack size
int axis;
asynStatus status;
KohzuAriesAxis *pAxis;
static const char *functionName = "KohzuAriesController";
createParam(KohzuAriesModelVersionString, asynParamOctet, &KohzuAriesModelVersion_);
createParam(KohzuAriesAxisNumTotalString, asynParamInt32, &KohzuAriesAxisNumTotal_);
createParam(KohzuAriesAxisNumControlledString, asynParamInt32, &KohzuAriesAxisNumControlled_);
createParam(KohzuAriesDrivingStateString, asynParamInt32, &KohzuAriesDrivingState_);
createParam(KohzuAriesEmgString, asynParamInt32, &KohzuAriesEmg_);
createParam(KohzuAriesOrgStateString, asynParamInt32, &KohzuAriesOrgState_);
createParam(KohzuAriesNorgStateString, asynParamInt32, &KohzuAriesNorgState_);
createParam(KohzuAriesSoftlimitStateposString, asynParamInt32, &KohzuAriesSoftlimitStatepos_);
createParam(KohzuAriesSoftlimitStatenegString, asynParamInt32, &KohzuAriesSoftlimitStateneg_);
createParam(KohzuAriesFeedbackStateString, asynParamInt32, &KohzuAriesFeedbackState_);
createParam(KohzuAriesReleaseEmgString, asynParamInt32, &KohzuAriesReleaseEmg_);
createParam(KohzuAriesOrgOffsetString, asynParamInt32, &KohzuAriesOrgOffset_);
createParam(KohzuAriesOrgTypeString, asynParamInt32, &KohzuAriesOrgType_);
createParam(KohzuAriesOrgSpeedString, asynParamInt32, &KohzuAriesOrgSpeed_);
createParam(KohzuAriesPmPrescaleString, asynParamInt32, &KohzuAriesPmPrescale_);
createParam(KohzuAriesPmRotateString, asynParamInt32, &KohzuAriesPmRotate_);
createParam(KohzuAriesLimitSwapString, asynParamInt32, &KohzuAriesLimitSwap_);
createParam(KohzuAriesPmClockString, asynParamInt32, &KohzuAriesPmClock_);
createParam(KohzuAriesPmLogicString, asynParamInt32, &KohzuAriesPmLogic_);
createParam(KohzuAriesBacklashPulseString, asynParamInt32, &KohzuAriesBacklashPulse_);
createParam(KohzuAriesBacklashTypeString, asynParamInt32, &KohzuAriesBacklashType_);
createParam(KohzuAriesSoftlimitOnString, asynParamInt32, &KohzuAriesSoftlimitOn_);
createParam(KohzuAriesSoftlimitPosString, asynParamInt32, &KohzuAriesSoftlimitPos_);
createParam(KohzuAriesSoftlimitNegString, asynParamInt32, &KohzuAriesSoftlimitNeg_);
createParam(KohzuAriesMaxSpeedString, asynParamInt32, &KohzuAriesMaxSpeed_);
createParam(KohzuAriesLimitLogicString, asynParamInt32, &KohzuAriesLimitLogic_);
createParam(KohzuAriesNorgLogicString, asynParamInt32, &KohzuAriesNorgLogic_);
createParam(KohzuAriesOrgLogicString, asynParamInt32, &KohzuAriesOrgLogic_);
createParam(KohzuAriesEncMulString, asynParamInt32, &KohzuAriesEncMul_);
createParam(KohzuAriesEncPrescaleString, asynParamInt32, &KohzuAriesEncPrescale_);
createParam(KohzuAriesEncNumString, asynParamInt32, &KohzuAriesEncNum_);
createParam(KohzuAriesEncDenString, asynParamInt32, &KohzuAriesEncDen_);
createParam(KohzuAriesEncDirString, asynParamInt32, &KohzuAriesEncDir_);
createParam(KohzuAriesZphaseLogicString, asynParamInt32, &KohzuAriesZphaseLogic_);
createParam(KohzuAriesEncSyncString, asynParamInt32, &KohzuAriesEncSync_);
createParam(KohzuAriesEncFilterString, asynParamInt32, &KohzuAriesEncFilter_);
createParam(KohzuAriesFeedbackTypeString, asynParamInt32, &KohzuAriesFeedbackType_);
createParam(KohzuAriesPermitRangeString, asynParamInt32, &KohzuAriesPermitRange_);
createParam(KohzuAriesRetryCountString, asynParamInt32, &KohzuAriesRetryCount_);
createParam(KohzuAriesWaitTimeString, asynParamInt32, &KohzuAriesWaitTime_);
createParam(KohzuAriesTriggerSouceString, asynParamInt32, &KohzuAriesTriggerSouce_);
createParam(KohzuAriesTriggerEdgeString, asynParamInt32, &KohzuAriesTriggerEdge_);
createParam(KohzuAriesTriggerPmratioString, asynParamInt32, &KohzuAriesTriggerPmratio_);
createParam(KohzuAriesTriggerEncratioString, asynParamInt32, &KohzuAriesTriggerEncratio_);
createParam(KohzuAriesTriggerWidthString, asynParamInt32, &KohzuAriesTriggerWidth_);
createParam(KohzuAriesTriggerLogicString, asynParamInt32, &KohzuAriesTriggerLogic_);
createParam(KohzuAriesExcitationString, asynParamInt32, &KohzuAriesExcitation_);
createParam(KohzuAriesMotorTypeString, asynParamInt32, &KohzuAriesMotorType_);
createParam(KohzuAriesAlarmSignalString, asynParamInt32, &KohzuAriesAlarmSignal_);
createParam(KohzuAriesMicrostepString, asynParamInt32, &KohzuAriesMicrostep_);
createParam(KohzuAriesLimitStoptypeString, asynParamInt32, &KohzuAriesLimitStoptype_);
/* Connect to Kohzu Aries controller */
status = pasynOctetSyncIO->connect(KohzuAriesPortName, 0, &pasynUserController_, NULL);
if (status) {
asynPrint(this->pasynUserSelf, ASYN_TRACE_ERROR,
"%s:%s: cannot connect to Kohzu Aries controller\n",
driverName, functionName);
// Create the axis objects
// todo: should check against MAX_KOHZUARIES_AXES
for (axis = 0; axis < numAxes; axis++) {
pAxis = new KohzuAriesAxis(this, axis);
startPoller(movingPollPeriod, idlePollPeriod, 2);
* Configuration command, called directly or from iocsh
* \param[in] KohzuAriesPortName The name of the drvAsynIPPPort that was created previously to connect to the Kohzu Aries controller
* \param[in] movingPollPeriod The time in ms between polls when any axis is moving
* \param[in] idlePollPeriod The time in ms between polls when no axis is moving
extern "C" int KohzuAriesCreateController(const char *portName, const char *KohzuAriesPortName, int numAxes,
int movingPollPeriod, int idlePollPeriod)
new KohzuAriesController(portName, KohzuAriesPortName, numAxes, movingPollPeriod/1000., idlePollPeriod/1000.);
return(asynSuccess);
/** Reports on status of the driver
* \param[in] fp The file pointer on which report information will be written
* \param[in] level The level of report detail desired
* If details > 0 then information is printed about each axis.
* After printing controller-specific information calls asynMotorController::report()
void KohzuAriesController::report(FILE *fp, int level)
fprintf(fp, "Kohzu Aries motor driver %s, numAxes=%d, moving poll period=%f, idle poll period=%f\n",
this->portName, numAxes_, movingPollPeriod_, idlePollPeriod_);
// Call the base class method
asynMotorController::report(fp, level);
/** Returns a pointer to a KohzuAriesMotorAxis object.
* Returns NULL if the axis number encoded in pasynUser is invalid.
* \param[in] pasynUser asynUser structure that encodes the axis index number. */
KohzuAriesAxis* KohzuAriesController::getAxis(asynUser *pasynUser)
return static_cast<KohzuAriesAxis*>(asynMotorController::getAxis(pasynUser));
/** Returns a pointer to a KohzuAriesAxis object.
* \param[in] axisNo Axis index number. */
KohzuAriesAxis* KohzuAriesController::getAxis(int axisNo)
return static_cast<KohzuAriesAxis*>(asynMotorController::getAxis(axisNo));
/* response data is separated by TAB('\t').
* Using strtoke to replace TAB with NULL.
* argument rsp: char array containing response data. Usually it's inString_.
* rsp_segs will contain the pointer to the segments of the response data.
* rsp_segs_num will be the number of the segments.
* For example, response data is "C\tRSY1\t1\t567",
* rsp_segs[0] pointts "C", rsp_segs[1] points to "RSY1",
* rsp_segs[2] points to "1", rsp_segs[3] points to "567"
int KohzuAriesController::rsp_parse(char *rsp)
char *token;
int i = 0;
token = strtok(rsp, RSP_DELIMITER);
while(token != NULL && i < RSP_SEGS_MAX){
rsp_segs[i++] = token;
token = strtok(NULL, RSP_DELIMITER);
rsp_segs_num = i;
for(; i < RSP_SEGS_MAX; i++){
rsp_segs[i] = NULL;
return rsp_segs_num;
// No. of System Settings
// return -1 if not found
int KohzuAriesController::function_to_sysno(int function)
int sysno = -1;
if(function == KohzuAriesOrgOffset_){
sysno = 1;
else if(function == KohzuAriesOrgType_){
sysno = 2;
else if(function == KohzuAriesOrgSpeed_){
sysno = 3;
else if(function == KohzuAriesPmPrescale_){
sysno = 6;
else if(function == KohzuAriesPmRotate_){
sysno = 7;
else if(function == KohzuAriesLimitSwap_){
sysno = 8;
else if(function == KohzuAriesPmClock_){
sysno = 9;
else if(function == KohzuAriesPmLogic_){
sysno = 10;
else if(function == KohzuAriesBacklashPulse_){
sysno = 11;
else if(function == KohzuAriesBacklashType_){
sysno = 12;
else if(function == KohzuAriesSoftlimitOn_){
sysno = 13;
else if(function == KohzuAriesSoftlimitPos_){
sysno = 14;
else if(function == KohzuAriesSoftlimitNeg_){
sysno = 15;
else if(function == KohzuAriesMaxSpeed_){
sysno = 16;
else if(function == KohzuAriesLimitLogic_){
sysno = 21;
else if(function == KohzuAriesNorgLogic_){
sysno = 22;
else if(function == KohzuAriesOrgLogic_){
sysno = 23;
else if(function == KohzuAriesEncMul_){
sysno = 31;
else if(function == KohzuAriesEncPrescale_){
sysno = 32;
else if(function == KohzuAriesEncNum_){
sysno = 33;
else if(function == KohzuAriesEncDen_){
sysno = 34;
else if(function == KohzuAriesEncDir_){
sysno = 35;
else if(function == KohzuAriesZphaseLogic_){
sysno = 36;
else if(function == KohzuAriesEncSync_){
sysno = 37;
else if(function == KohzuAriesEncFilter_){
sysno = 38;
else if(function == KohzuAriesFeedbackType_){
sysno = 41;
else if(function == KohzuAriesPermitRange_){
sysno = 42;
else if(function == KohzuAriesRetryCount_){
sysno = 43;
else if(function == KohzuAriesWaitTime_){
sysno = 44;
else if(function == KohzuAriesTriggerSouce_){
sysno = 51;
else if(function == KohzuAriesTriggerEdge_){
sysno = 52;
else if(function == KohzuAriesTriggerPmratio_){
sysno = 53;
else if(function == KohzuAriesTriggerEncratio_){
sysno = 54;
else if(function == KohzuAriesTriggerWidth_){
sysno = 55;
else if(function == KohzuAriesTriggerLogic_){
sysno = 56;
else if(function == KohzuAriesExcitation_){
sysno = 61;
else if(function == KohzuAriesMotorType_){
sysno = 62;
else if(function == KohzuAriesAlarmSignal_){
sysno = 63;
else if(function == KohzuAriesMicrostep_){
sysno = 65;
else if(function == KohzuAriesLimitStoptype_){
sysno = 99;
else{
sysno = -1;
return sysno;
asynStatus KohzuAriesController::readInt32(asynUser *pasynUser, epicsInt32 *value)
int function = pasynUser->reason;
asynStatus status = asynSuccess;
KohzuAriesAxis *pAxis = getAxis(pasynUser);
static const char *functionName = "readInt32";
if (function == KohzuAriesAxisNumTotal_ || function == KohzuAriesAxisNumControlled_) {
sprintf(outString_, "RAX"); // 0 1 2 3 4 5 6 7 8 9 10 12 segment index
status = writeReadController(); // C\tRAX\t64\t32\tb0\tb1\tb2\tb3\tb4\tb5\tb6\tb7
if(status != asynSuccess)
return status;
rsp_parse(inString_);
setIntegerParam(KohzuAriesAxisNumTotal_, atoi(rsp_segs[2]));
setIntegerParam(KohzuAriesAxisNumControlled_, atoi(rsp_segs[3]));
else if(function_to_sysno(function) != -1){
sprintf(outString_, "RSY%s/%d", pAxis->axisName_, function_to_sysno(function));
status = writeReadController(); // C\tRSY1\t1\t0
// 0 1 2 3 segment index
// test, start
asynPrint(this->pasynUserSelf, ASYN_TRACE_WARNING,
" zxy readInt32 axis %s, f %d, sysno %d, value %d, status %d, %s\n",
pAxis->axisName_, function, function_to_sysno(function), *value, status, inString_);
// test, end
return status;
pAxis->setIntegerParam(function, atoi(rsp_segs[3]));
/* Call base class method */
status = asynMotorController::readInt32(pasynUser, value);
/* Do callbacks so higher layers see any changes */
callParamCallbacks(pAxis->axisNo_);
return status;
asynStatus KohzuAriesController::writeInt32(asynUser *pasynUser, epicsInt32 value)
static const char *functionName = "writeInt32";
int sysno;
sprintf(outString_, "WSY%s/%d/%d", pAxis->axisName_, function_to_sysno(function), value);
// test, start
" xzy writeInt32 axis %s, f %d, sysno %d, value %d, status %d, %s\n",
pAxis->axisName_, function, function_to_sysno(function), value, status, inString_);
// test, end
return status;
else if(function == KohzuAriesReleaseEmg_){
sprintf(outString_, "REM");
return status;
/* todo: how to sync? CNEN and Sys.62 excitation
else if(function == motorClosedLoop_){
asynPrint(pasynUser, ASYN_TRACEIO_DRIVER,
"zzyyxx closedLoop %s:%s: function=%d, value=%d\n",
driverName, functionName, function, value);
status = asynMotorController::writeInt32(pasynUser, value);
return status;
asynStatus KohzuAriesController::readOctet(asynUser *pasynUser,
char *value, size_t maxChars, size_t *nActual,
int *eomReason)
static const char *functionName = "readOctet";
char temp[128]; // magic number
if (function == KohzuAriesModelVersion_) {
sprintf(outString_, "IDN"); // 0 1 2 3 4 5 segment index
status = writeReadController(); // C\tIDN\tARIES\t1\t4\t3
return status;
sprintf(temp, "%s %s.%s.%s", rsp_segs[2], rsp_segs[3], rsp_segs[4], rsp_segs[5]);
setStringParam(function, temp);
status = asynMotorController::readOctet(pasynUser, value, maxChars, nActual, eomReason);
return status;
// These are the KohzuAriesAxis methods
/** Creates a new KohzuAriesAxis object.
* \param[in] pC Pointer to the KohzuAriesController to which this axis belongs.
* \param[in] axisNo Index number of this axis, range 0 to pC->numAxes_-1.
* Initializes register numbers, etc.
KohzuAriesAxis::KohzuAriesAxis(KohzuAriesController *pC, int axisNo)
: asynMotorAxis(pC, axisNo),
pC_(pC)
asynStatus status;
sprintf(axisName_, "%d", axisNo+1); // note: base's axisNo_ is 0-based; axis no. in ARIES command is 1-based
setIntegerParam(pC->motorStatusGainSupport_, 1);
setIntegerParam(pC->motorStatusHasEncoder_, 1);
callParamCallbacks();
void KohzuAriesAxis::report(FILE *fp, int level)
if (level > 0) {
fprintf(fp, " axis no.(0-based) %d\n"
" encoder position=%f\n"
" theory position=%f\n"
" limitCW=%d\n"
" limitCCW=%d\n"
" homed=%d\n",
axisNo_,
encoderPosition_, theoryPosition_,
currentLimitCW, currentLimitCCW, currentHomed);
asynMotorAxis::report(fp, level);
// speed table row 0 for move, 1 for jogging, 2 for homing
// unit of position, pulse
// unit of minVelocity and maxVelocity, pulse/second
// unit of acceleration, pulse/second^2, = (maxV - minV) / ACCL
// note: VBAS -> minVelocity -> speedtable start speed, VELO -> maxVelocity -> speedtable max speed
// start speed must be <= (50% of max speed)
asynStatus KohzuAriesAxis::move(double position, int relative, double minVelocity, double maxVelocity, double acceleration)
asynStatus status;
int t;
// static const char *functionName = "moveAxis";
if(minVelocity >= maxVelocity / 2){
minVelocity = maxVelocity / 2 - 1;
t = (maxVelocity - minVelocity) / acceleration * 100; // unit: 10 msec
sprintf(pC_->outString_, "WTB%s/0/%.0f/%.0f/%d/%d/2", axisName_, minVelocity, maxVelocity, t, t);
status = pC_->writeReadController();
// test, start
asynPrint(pasynUser_, ASYN_TRACE_WARNING,
"xzy axis %d move(pos %f, relative %d, minV %f, maxV %f, acc %f, t %d) return %d, %s\n",
axisNo_, position, relative, minVelocity, maxVelocity, acceleration, t, status, pC_->inString_);
// test, end
sprintf(pC_->outString_, "%s%s/0/%.0f/1", relative ? "RPS" : "APS", axisName_, position);
return status;
// jog
asynStatus KohzuAriesAxis::moveVelocity(double minVelocity, double maxVelocity, double acceleration)
asynStatus status;
int dir=0; // 0: CW, 1: CCW
int t;
// static const char *functionName = "moveVelocityAxis";
if(maxVelocity < 0){
maxVelocity = -maxVelocity;
dir = 1;
sprintf(pC_->outString_, "WTB%s/1/%.0f/%.0f/%d/%d/2", axisName_, minVelocity, maxVelocity, t, t);
// test, start
"xzy axis %d moveVelocity(minV %f, maxV %f, acc %f, t %d) return %d, %s\n",
axisNo_, minVelocity, maxVelocity, acceleration, t, status, pC_->inString_);
// test, end
sprintf(pC_->outString_, "FRP%s/1/%d", axisName_, dir); // FRP axis no./speed table no./0:CW 1:CCW
return status;
// forwards: 1 if HOMF, 0 if HOMR
asynStatus KohzuAriesAxis::home(double minVelocity, double maxVelocity, double acceleration, int forwards)
asynStatus status;
int t;
int orgtype = -1;
// static const char *functionName = "homeAxis";
status = pC_->getIntegerParam(axisNo_, pC_->KohzuAriesOrgType_, &orgtype);
if(orgtype == 5 || orgtype == 7 || orgtype == 14){
if(forwards != 1){
"Warning: axis %d homing direction(forwards %d) is inconsistent with ORG type(%d)\n",
axisNo_, forwards, orgtype);
else if(orgtype == 6 || orgtype == 8 || orgtype == 15 || orgtype == 11){
if(forwards != 0){
sprintf(pC_->outString_, "WTB%s/2/%.0f/%.0f/%d/%d/2", axisName_, minVelocity, maxVelocity, t, t);
// test, start
"xzy axis %d home(minV %f, maxV %f, acc %f, forwards %d, t %d, orgtype %d) return %d, %s\n",
axisNo_, minVelocity, maxVelocity, acceleration, forwards, t, orgtype, status, pC_->inString_);
// test, end
sprintf(pC_->outString_, "ORG%s/2/1", axisName_);
return status;
asynStatus KohzuAriesAxis::stop(double acceleration)
asynStatus status;
//static const char *functionName = "stopAxis";
sprintf(pC_->outString_, "STP%s/0", axisName_); // 0: decelerate and stop; 1: emergency(no-decelerate) stop
return status;
asynStatus KohzuAriesAxis::setPosition(double position)
asynStatus status;
double mres = 9.487;
double enc_ratio;
//pC_->getDoubleParam(axisNo_, pC_->motorResolution_, &mres);
pC_->getDoubleParam(axisNo_, pC_->motorEncoderRatio_, &enc_ratio);
// pC_->getDoubleParam(axisNo_, pC_->GalilEncoderResolution_, &eres);
"xzy axis %d, mres %f, enc_ratio %f\n",
axisNo_, mres, enc_ratio);
setEncoderPosition(position * enc_ratio);
sprintf(pC_->outString_, "WRP%s/%.0f", axisName_, position);
// test, start
"xzy axis %d setPosition (pos %f), WRP status %d\n",
axisNo_, position, status);
// test, end
return status;
asynStatus KohzuAriesAxis::setEncoderPosition(double position)
asynStatus status;
sprintf(pC_->outString_, "WRE%s/%.0f", axisName_, position);
// test, start
"xzy axis %d setEncoderPosition(pos %f), WRE status %d, inString %s\n",
axisNo_, position, status, pC_->inString_);
// test, end
//sprintf(pC_->outString_, "WRE%s/%.0f", axisName_, position);
//status = pC_->writeReadController();
//asynPrint(pasynUser_, ASYN_TRACE_WARNING,
// "xzy axis %d setEncoderPosition(pos %f), WRE status %d, inString %s\n",
// axisNo_, position, status, pC_->inString_);
// test, end
return status;
asynStatus KohzuAriesAxis::setClosedLoop(bool closedLoop)
asynStatus status;
// System Setting No. 61 excitation, used in setClosedLoop
sprintf(pC_->outString_, "WSY%s/61/%d", axisName_, closedLoop ? 1 : 0);
return status;
return status;
/** Polls the axis.
* This function reads the controller position, encoder position, the limit status, the moving status,
* and the drive power-on status. It does not current detect following error, etc. but this could be
* added.
* It calls setIntegerParam() and setDoubleParam() for each item that it polls,
* and then calls callParamCallbacks() at the end.
* \param[out] moving A flag that is set indicating that the axis is moving (1) or done (0). */
asynStatus KohzuAriesAxis::poll(bool *moving)
int done;
int driveOn;
int limit;
asynStatus comStatus;
// Read the current encoder position
sprintf(pC_->outString_, "RDE%s", axisName_);
comStatus = pC_->writeReadController();
if (comStatus) goto skip;
encoderPosition_ = atof(pC_->inString_ + 7); // C[TAB]RDE1[TAB]123456
setDoubleParam(pC_->motorEncoderPosition_, encoderPosition_);
// Read the current theoretical position
sprintf(pC_->outString_, "RDP%s", axisName_);
theoryPosition_ = atof(pC_->inString_ + 7); // C[TAB]RDE1[TAB]123456
setDoubleParam(pC_->motorPosition_, theoryPosition_);
// Read the current status, example: C\tSTR1\t0\t0\t0\t0\t0\t0
// 0 2 5 7 9 11 13 15 17 index
sprintf(pC_->outString_, "STR%s", axisName_);
done = pC_->inString_[7] == '0';
setIntegerParam(pC_->motorStatusDone_, done);
*moving = done ? false:true;
setIntegerParam(pC_->KohzuAriesDrivingState_, pC_->inString_[7] - '0');
setIntegerParam(pC_->KohzuAriesEmg_, pC_->inString_[9] - '0');
setIntegerParam(pC_->KohzuAriesOrgState_, (pC_->inString_[11] - '0') & 0x2);
setIntegerParam(pC_->KohzuAriesNorgState_, (pC_->inString_[11] - '0') & 0x1);
// the current limit status
switch (pC_->inString_[13]) {
case '0':
currentLimitCW = 0;
currentLimitCCW = 0;
break;
case '1':
currentLimitCW = 0;
currentLimitCCW = 1;
break;
case '2':
currentLimitCW = 1;
break;
case '3':
currentLimitCW = 1;
break;
default:
currentLimitCW = 0;
break;
setIntegerParam(pC_->motorStatusHighLimit_, currentLimitCW);
setIntegerParam(pC_->motorStatusLowLimit_, currentLimitCCW);
setIntegerParam(pC_->KohzuAriesSoftlimitStatepos_, pC_->inString_[15] == '1' ? 1 : 0);
setIntegerParam(pC_->KohzuAriesSoftlimitStateneg_, pC_->inString_[15] == '2' ? 1 : 0);
setIntegerParam(pC_->KohzuAriesFeedbackState_, pC_->inString_[17] == '1' ? 1 : 0);
sprintf(pC_->outString_, "ROG%s", axisName_);
currentHomed = pC_->inString_[7] == '1' ? 1 : 0; // C[TAB]ROG1[TAB]1
setIntegerParam(pC_->motorStatusHomed_, currentHomed);
// Read the drive power on status
// System Setting No. 61 excitation, also used in setClosedLoop
sprintf(pC_->outString_, "RSY%s/61", axisName_);
driveOn = pC_->inString_[10] == '1' ? 1 : 0; // C[TAB]RSY1[TAB]61[TAB]1
setIntegerParam(pC_->motorStatusPowerOn_, driveOn);
setIntegerParam(pC_->motorStatusProblem_, 0);
skip:
setIntegerParam(pC_->motorStatusProblem_, comStatus ? 1:0);
return comStatus ? asynError : asynSuccess;
/** Code for iocsh registration */
static const iocshArg KohzuAriesCreateControllerArg0 = {"Port name", iocshArgString};
static const iocshArg KohzuAriesCreateControllerArg1 = {"Kohzu Aries port name", iocshArgString};
static const iocshArg KohzuAriesCreateControllerArg2 = {"Number of axes", iocshArgInt};
static const iocshArg KohzuAriesCreateControllerArg3 = {"Moving poll period (ms)", iocshArgInt};
static const iocshArg KohzuAriesCreateControllerArg4 = {"Idle poll period (ms)", iocshArgInt};
static const iocshArg * const KohzuAriesCreateControllerArgs[] = {&KohzuAriesCreateControllerArg0,
&KohzuAriesCreateControllerArg1,
&KohzuAriesCreateControllerArg2,
&KohzuAriesCreateControllerArg3,
&KohzuAriesCreateControllerArg4};
static const iocshFuncDef KohzuAriesCreateControllerDef = {"KohzuAriesCreateController", 5, KohzuAriesCreateControllerArgs};
static void KohzuAriesCreateContollerCallFunc(const iocshArgBuf *args)
KohzuAriesCreateController(args[0].sval, args[1].sval, args[2].ival, args[3].ival, args[4].ival);
static void KohzuAriesRegister(void)
iocshRegister(&KohzuAriesCreateControllerDef, KohzuAriesCreateContollerCallFunc);
extern "C" {
epicsExportRegistrar(KohzuAriesRegister);
FILENAME... KohzuAriesrDriver.h
LiangChih Chiang
December 20, 2018
#define MAX_KOHZUARIES_AXES 32
// The number of segments of response data:
// RTB, WTB commands: 10
// RAX commands: 12 (max), example: C\tRAX\t64\t32\tb0\tb1\tb2\tb3\tb4\tb5\tb6\tb7
#define RSP_SEGS_MAX 12
#define KohzuAriesModelVersionString "KOHZUARIES_MODEL_VERSION" //70
#define KohzuAriesAxisNumTotalString "KOHZUARIES_AXISNUM_TOTAL" // total number of devices
#define KohzuAriesAxisNumControlledString "KOHZUARIES_AXISNUM_CONTROLLED" // number of axes that can be controlled
#define KohzuAriesDrivingStateString "KOHZUARIES_DRIVING_STATE"
#define KohzuAriesEmgString "KOHZUARIES_EMG"
#define KohzuAriesOrgStateString "KOHZUARIES_ORG_STATE"
#define KohzuAriesNorgStateString "KOHZUARIES_NORG_STATE"
#define KohzuAriesSoftlimitStateposString "KOHZUARIES_SOFTLIMIT_STATEPOS"
#define KohzuAriesSoftlimitStatenegString "KOHZUARIES_SOFTLIMIT_STATENEG"
#define KohzuAriesFeedbackStateString "KOHZUARIES_FEEDBACK_STATE"
#define KohzuAriesReleaseEmgString "KOHZUARIES_RELEASE_EMG"
// start, System settings
#define KohzuAriesOrgOffsetString "KOHZUARIES_ORG_OFFSET" //81
#define KohzuAriesOrgTypeString "KOHZUARIES_ORG_TYPE"
#define KohzuAriesOrgSpeedString "KOHZUARIES_ORG_SPEED"
#define KohzuAriesPmPrescaleString "KOHZUARIES_PM_PRESCALE"
#define KohzuAriesPmRotateString "KOHZUARIES_PM_ROTATE"
#define KohzuAriesLimitSwapString "KOHZUARIES_LIMIT_SWAP"
#define KohzuAriesPmClockString "KOHZUARIES_PM_CLOCK"
#define KohzuAriesPmLogicString "KOHZUARIES_PM_LOGGIC"
#define KohzuAriesBacklashPulseString "KOHZUARIES_BACKLASH_PULSE"
#define KohzuAriesBacklashTypeString "KOHZUARIES_BACKLASH_TYPE"
#define KohzuAriesSoftlimitOnString "KOHZUARIES_SOFTLIMIT_ON"
#define KohzuAriesSoftlimitPosString "KOHZUARIES_SOFTLIMIT_POS"
#define KohzuAriesSoftlimitNegString "KOHZUARIES_SOFTLIMIT_NEG"
#define KohzuAriesMaxSpeedString "KOHZUARIES_MAX_SPEED" //94
#define KohzuAriesLimitLogicString "KOHZUARIES_LIMIT_LOGIC"
#define KohzuAriesNorgLogicString "KOHZUARIES_NORG_LOGIC"
#define KohzuAriesOrgLogicString "KOHZUARIES_ORG_LOGIC"
#define KohzuAriesEncMulString "KOHZUARIES_ENC_MUL"
#define KohzuAriesEncPrescaleString "KOHZUARIES_ENC_PRESCALE"
#define KohzuAriesEncNumString "KOHZUARIES_ENC_NUM" //100
#define KohzuAriesEncDenString "KOHZUARIES_ENC_DEN"
#define KohzuAriesEncDirString "KOHZUARIES_ENC_DIR"
#define KohzuAriesZphaseLogicString "KOHZUARIES_ZPHASE_LOGIC"
#define KohzuAriesEncSyncString "KOHZUARIES_ENC_SYNC"
#define KohzuAriesEncFilterString "KOHZUARIES_ENC_FILTER"
#define KohzuAriesFeedbackTypeString "KOHZUARIES_FEEDBACK_TYPE"
#define KohzuAriesPermitRangeString "KOHZUARIES_PERMIT_RANGE"
#define KohzuAriesRetryCountString "KOHZUARIES_RETRY_COUNT"
#define KohzuAriesWaitTimeString "KOHZUARIES_WAIT_TIME"
#define KohzuAriesTriggerSouceString "KOHZUARIES_TRIGGER_SOURCE"
#define KohzuAriesTriggerEdgeString "KOHZUARIES_TRIGGER_EDGE"
#define KohzuAriesTriggerPmratioString "KOHZUARIES_TRIGGER_PMRATIO"
#define KohzuAriesTriggerEncratioString "KOHZUARIES_TRIGGER_ENCRATIO"
#define KohzuAriesTriggerWidthString "KOHZUARIES_TRIGGER_WIDTH"
#define KohzuAriesTriggerLogicString "KOHZUARIES_TRIGGER_LOGIC"
#define KohzuAriesExcitationString "KOHZUARIES_EXCITATION"
#define KohzuAriesMotorTypeString "KOHZUARIES_MOTOR_TYPE"
#define KohzuAriesAlarmSignalString "KOHZUARIES_ALARM_SIGNAL"
#define KohzuAriesMicrostepString "KOHZUARIES_MICROSTEP"
#define KohzuAriesLimitStoptypeString "KOHZUARIES_LIMIT_STOPTYPE"
// end, System settings
class epicsShareClass KohzuAriesAxis : public asynMotorAxis
public:
/* These are the methods we override from the base class */
KohzuAriesAxis(class KohzuAriesController *pC, int axis);
void report(FILE *fp, int level);
asynStatus move(double position, int relative, double min_velocity, double max_velocity, double acceleration);
asynStatus moveVelocity(double min_velocity, double max_velocity, double acceleration);
asynStatus home(double min_velocity, double max_velocity, double acceleration, int forwards);
asynStatus stop(double acceleration);
asynStatus poll(bool *moving);
asynStatus setPosition(double position);
asynStatus setEncoderPosition(double position);
asynStatus setClosedLoop(bool closedLoop);
private:
KohzuAriesController *pC_; /**< Pointer to the asynMotorController to which this axis belongs.
* Abbreviated because it is used very frequently */
char axisName_[3]; /**< Name of each axis, used in commands to Kohzu ARIES controller */
double encoderPosition_; /**< Cached copy of the encoder position */
double theoryPosition_; /**< Cached copy of the theoretical position */
int currentLimitCW; /**< Cached copy of the current limits */
int currentLimitCCW;
int currentHomed;
friend class KohzuAriesController;
class epicsShareClass KohzuAriesController : public asynMotorController {
public:
KohzuAriesController(const char *portName, const char *KohzuAriesPortName, int numAxes, double movingPollPeriod, double idlePollPeriod);
/* These are the methods that we override from asynPortDriver */
//asynStatus writeUInt32Digital(asynUser *pasynUser, epicsUInt32 value, epicsUInt32 mask);
asynStatus readInt32(asynUser *pasynUser, epicsInt32 *value);
asynStatus writeInt32(asynUser *pasynUser, epicsInt32 value);
asynStatus readOctet(asynUser *pasynUser, char *value, size_t maxChars, size_t *nActual, int *eomReason);
/* These are the methods that we override from asynMotorDriver */
//asynStatus writeInt32(asynUser *pasynUser, epicsInt32 value);
//asynStatus writeFloat64(asynUser *pasynUser, epicsFloat64 value);
KohzuAriesAxis* getAxis(asynUser *pasynUser);
KohzuAriesAxis* getAxis(int axisNo);
protected:
#define FIRST_KOHZUARIES_PARAM KohzuAriesModelVersion_
int KohzuAriesModelVersion_; /* example: ARIES 1.4.3 */
int KohzuAriesAxisNumTotal_; /* total number of devices(axes?) */
int KohzuAriesAxisNumControlled_; /* number of axes that can be controlled */
int KohzuAriesDrivingState_;
int KohzuAriesEmg_;
int KohzuAriesOrgState_;
int KohzuAriesNorgState_;
int KohzuAriesSoftlimitStatepos_;
int KohzuAriesSoftlimitStateneg_;
int KohzuAriesFeedbackState_;
int KohzuAriesReleaseEmg_;
int KohzuAriesOrgOffset_; /* start, System settings */
int KohzuAriesOrgType_;
int KohzuAriesOrgSpeed_;
int KohzuAriesPmPrescale_;
int KohzuAriesPmRotate_;
int KohzuAriesLimitSwap_;
int KohzuAriesPmClock_;
int KohzuAriesPmLogic_;
int KohzuAriesBacklashPulse_;
int KohzuAriesBacklashType_;
int KohzuAriesSoftlimitOn_;
int KohzuAriesSoftlimitPos_;
int KohzuAriesSoftlimitNeg_;
int KohzuAriesMaxSpeed_;
int KohzuAriesLimitLogic_;
int KohzuAriesNorgLogic_;
int KohzuAriesOrgLogic_;
int KohzuAriesEncMul_;
int KohzuAriesEncPrescale_;
int KohzuAriesEncNum_;
int KohzuAriesEncDen_;
int KohzuAriesEncDir_;
int KohzuAriesZphaseLogic_;
int KohzuAriesEncSync_;
int KohzuAriesEncFilter_;
int KohzuAriesFeedbackType_;
int KohzuAriesPermitRange_;
int KohzuAriesRetryCount_;
int KohzuAriesWaitTime_;
int KohzuAriesTriggerSouce_;
int KohzuAriesTriggerEdge_;
int KohzuAriesTriggerPmratio_;
int KohzuAriesTriggerEncratio_;
int KohzuAriesTriggerWidth_;
int KohzuAriesTriggerLogic_;
int KohzuAriesExcitation_;
int KohzuAriesMotorType_;
int KohzuAriesAlarmSignal_;
int KohzuAriesMicrostep_;
int KohzuAriesLimitStoptype_; /* end, System settings */
#define LAST_KOHZUARIES_PARAM KohzuAriesLimitStoptype_
#define NUM_KOHZUARIES_PARAMS (&LAST_KOHZUARIES_PARAM - &FIRST_KOHZUARIES_PARAM + 1)
private:
char *rsp_segs[RSP_SEGS_MAX];
int rsp_segs_num;
int rsp_parse(char *rsp);
int function_to_sysno(int function);
friend class KohzuAriesAxis;
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
