1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: QuadEM Update rate limited by lock
From: Iain Marcuson via Tech-talk <[email protected]>
Date: Wed, 20 Nov 2024 16:58:39 +0000
I am writing EPICS for a QuadEM, based on designs in the distribution.  The data come at 200 Hz, and my benchmarking in EPICS shows that I receive at that rate with very low jitter.  Following the examples of other electrometers, I lock() before computePositions() and callParamCallbacks().  I have observed that the lock() takes about 6 ms, which is too long for the full packet rate.  Is this a normal time for the lock()?  I believe I have eliminated other calls for the lock() in my code, although a calltree shows lock()s in the callbacks.
Thank you,
Iain.
This message has been scanned for malware by Forcepoint. www.forcepoint.com
Re: QuadEM Update rate limited by lock Mark Rivers via Tech-talk
Prev: Re: I implemented the Model 3 of EPICS motor driver support, but the VAL and RBV of motor record are zero after IOC reboot. Mark Rivers via Tech-talk
Next: Re: QuadEM Update rate limited by lock Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: Re: I implemented the Model 3 of EPICS motor driver support, but the VAL and RBV of motor record are zero after IOC reboot. LiangChih Chiang via Tech-talk
