1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: Process Record at ioc initialization with OPCUA module
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Wed, 11 Dec 2024 14:53:40 +0100
Hi Vivien,
The bini option (behavior at initialization) determines what the driver is doing when the communication is established.
This is different from the record's PINI field which determines record processing when the IOC initializes.
bini=read (default): When the OPC UA communication is established, the value is read from the device and the EPICS record is updated.
bini=write: When the OPC UA communication is established, the value is written from the EPICS record to the device.
bini=ignore: When the OPC UA communication is established, neither the EPICS record nor the device is updated.
The bini option does not cause the record to process.
The configure action happens every time the connection comes up. (Also if the OPC UA server is started after the IOC boots or when the connection is reestablished after a communication loss.)
In your configuration, the BO gets the value from the device when the connection comes up, silently.
With monitor=y (default) your BO record is bidirectional. Changes on the EPICS side are written to the device, changes in the device update the EPICS record.
Cheers,
~Ralph
On Wed, 11 Dec 2024 at 13:12, LORIOT Vivien via Tech-talk <[email protected]> wrote:
De : LORIOT Vivien
Envoyé : mercredi 11 décembre 2024 11:48
À : '[email protected]' <[email protected]>
Objet : Process Record at ioc initialization with OPCUA module
Hi everyone,
I’m currently using the OPCUA epics module (with the open62541 librairy) to communicate with a PLC Siemens s7-1500 and I would have a question about the process of a BO record at initialization.
With OPCUA, it seems possible to process a record at the initialization with defining the option bini inside the OUT field :
But my BO are still not processing during the IOC init. It fonctionne well with the input record (AI and BI). Maybe I didn’t understand well the bini option ?
Does someone already had this problem and have a solution to propose ?
Sinceraly,
cid:image001.png@01D9F098.F40035D0
Vivien LORIOT
Ingénieur Contrôle-Commande
Laboratoire de Développement et d’Intégration des Systèmes de Contrôle
Commissariat à l’énergie atomique et aux énergies alternatives
CEA Paris-Saclay
DRF/IRFU/DIS/LDISC
Bâtiment 472 – Pièce 105
Tel : +33 1 69 08 95 17
PNG image
RE: Process Record at ioc initialization with OPCUA module LORIOT Vivien via Tech-talk
TR: Process Record at ioc initialization with OPCUA module LORIOT Vivien via Tech-talk
Prev: Re: Process Record at ioc initialization with OPCUA module Hu, Yong via Tech-talk
Next: runtime error Pierrick M Hanlet via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: RE: Process Record at ioc initialization with OPCUA module LORIOT Vivien via Tech-talk
Next: RE: Process Record at ioc initialization with OPCUA module LORIOT Vivien via Tech-talk
