Hi Ralph,
Ok thanks for your help, I think well understand the difference now between the PINI field, which does not seem to be implemented with
the OPCUA driver and the bini option.
Best,
Vivien
De : Tech-talk <[email protected]>
De la part de Ralph Lange via Tech-talk
Envoyé : mercredi 11 décembre 2024 14:54
À : EPICS Tech Talk <[email protected]>
Objet : Re: Process Record at ioc initialization with OPCUA module
The bini option (behavior at initialization) determines what the driver is doing when the communication is established.
This is different from the record's PINI field which determines record processing when the IOC initializes.
bini=read (default): When the OPC UA communication is established, the value is read from the device and the EPICS record is updated.
bini=write: When the OPC UA communication is established, the value is written from the EPICS record to the device.
bini=ignore: When the OPC UA communication is established, neither the EPICS record nor the device is updated.
The bini option does not cause the record to process.
The configure action happens every time the connection comes up. (Also if the OPC UA server is started after the IOC boots or when the connection is reestablished after a communication loss.)
In your configuration, the BO gets the value from the device when the connection comes up, silently.
With monitor=y (default) your BO record is bidirectional. Changes on the EPICS side are written to the device, changes in the device update the EPICS record.
Hi everyone,
I’m currently using the OPCUA epics module (with the open62541 librairy) to communicate with a PLC Siemens s7-1500 and I would have a question about the process of a BO record at
initialization.
With OPCUA, it seems possible to process a record at the initialization with defining the option bini inside the OUT field :
But my BO are still not processing during the IOC init. It fonctionne well with the input record (AI and BI). Maybe I didn’t understand well the bini option ?
Does someone already had this problem and have a solution to propose ?
Sinceraly,
![cid:image001.png@01D9F098.F40035D0]()
Vivien LORIOT
Ingénieur Contrôle-Commande
Laboratoire de Développement et d’Intégration des Systèmes de Contrôle
Commissariat à l’énergie atomique et aux énergies alternatives
CEA Paris-Saclay
DRF/IRFU/DIS/LDISC
Bâtiment 472 – Pièce 105
Tel : +33 1 69 08 95 17
- Re: Process Record at ioc initialization with OPCUA module Ralph Lange via Tech-talk
- TR: Process Record at ioc initialization with OPCUA module LORIOT Vivien via Tech-talk
RE: Process Record at ioc initialization with OPCUA module LORIOT Vivien via Tech-talk
<2024>
2025
2026
<2024>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
