1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: Re: ADSpinnaker::grabImage error GetImageStatus
To: Mrinal Bera <[email protected]>
Cc: "Evans, Richard K. \(GRC-H000\) via Tech-talk" <[email protected]>
Date: Fri, 13 Dec 2024 18:01:31 +0000
Hi Mrinal,
You are running the camera very close to the limit of 1 Gbit Ethernet.  The camera dimensions are 2048x1536, and you are using Mono16 mode, so 2 bytes/pixel.  At 16 frames/s that is 96 MB/s.  Other traffic on that network could cause an occasional lost frame.
The camera ADC is only 12 bits.  Does the camera have a Mono12Packed mode?  If you use that you can get 16-bit data with 25% less network bandwidth.  Or 8-bit mode may be sufficient for your application.
Sent: Friday, December 13, 2024 12:01 PM
To: Mark Rivers <[email protected]>
Cc: Evans, Richard K. (GRC-H000) via Tech-talk <[email protected]>
Hi Mark,
Even after executing the commands to increase the net.core.rmem_max and net.core.rmem_default to 8MB, I saw the same error message. Attached is the image of the medm screen for the camera after I increased the memory variables. I saw the error message twice so far and in the medm screen I see that the Images Complete in the Collect tab are 2 less than the Started and Delivered frames in the Status tab.
Mrinal
Mrinal Kanti Bera, PhD
Beamline Scientist and Research Associate Professor
NSF’s ChemMatCARS, Pritzker School of Molecular Engineering
University of Chicago
9700 S Cass Ave Bldg 434D
Argonne, IL-60439
United States
Phone: +1-630-252-0472
On Dec 13, 2024, at 10:07 AM, Mark Rivers <[email protected]> wrote:
Hi Mrinal,
Have you changed the Linux buffer settings as documented here:
Is there more than 1 camera running on this machine?  Can you send a screenshot of the camera screen under the conditions where it is happening.
Sent: Friday, December 13, 2024 10:50 AM
Subject: ADSpinnaker::grabImage error GetImageStatus
Hi Mark,
While using the FLIR camera with ADSpinnaker, I am getting this error intermittently and after sometime the camera stops acquisition.
2024/12/13 09:48:01.083 ADSpinnaker::grabImage error GetImageStatus  3, description:  Image has missing packets. Potential fixes include enabling jumbo packets and adjusting packet size/delay. For more information see https://www.flir.com/support-center/iis/machine-vision/application-note/troubleshooting-image-consistency-errors/
Do you know how I can fix this?
Best regards,
Mrinal
Argonne, IL-60439
United States
ADSpinnaker::grabImage error GetImageStatus Mrinal Bera via Tech-talk
Re: ADSpinnaker::grabImage error GetImageStatus Mark Rivers via Tech-talk
Re: ADSpinnaker::grabImage error GetImageStatus Mrinal Bera via Tech-talk
Prev: Re: ADSpinnaker::grabImage error GetImageStatus Mrinal Bera via Tech-talk
Next: Building AreaDetector Vimba driver V 1.5 Steven Hunt via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
