Hello, Mark,
> Are these stepper motors or DC servos stepper motors.
> Do they have encoders? Yes.
>Can you try temporarily removing the pseudo motor for energy, so there is only the real motor. Does the problem exist? I'll try after weekend.
>Before resorting to wireshark, I recommend just turning on ASYN_TRACE_ERROR, ASYN_TRACE_FLOW, and ASYN_TRACEIO_DRIVER in your startup script right after creating the driver. I turned them on before. There will be many messages; I don't know where to look at.
>That may help to understand what is happening. >You may also want to add additional asynPrint statements in your driver to see what it is doing. I'll try after weekend. But the question is that I don't know where in the code to add asynPrint.
I (we all) know it's extremely difficult to debug others' problems. Any suggestions are appreciated.
Thanks for your helping and replying.
I don't think you have told us:
Before resorting to wireshark, I recommend just turning on ASYN_TRACE_ERROR, ASYN_TRACE_FLOW, and ASYN_TRACEIO_DRIVER in your startup script right after creating the driver. That may help to understand what is happening. You may also want to add additional
> What is special with DCM:Z1.V ?
Not special.
ThetaM axis is the most important.
>The polling, if it works for motor 1,2,3...,
>shouldn't it work for motor 0 as well ?
Yeah. That bothers me a lot.
>Did you mention that you are using a "soft motor" here ?
There is pseudo motor representing the energy of x-ray beam,
whose value is converted to and from ThetaM(Bragg angle).
>If not, it may be an idea to use wireshark to see what is
>going on between the EPICS IOC and the motion controller.
Well, by using wireshark, I don't know what parts or messages I need to see.
Thinking about it:
On 2025-01-03 09:09, Torsten Bögershausen wrote:
> Hej again,
> happy new year !
> Thanks for reporting back and sharing your experiences.
> I think that there are 2 problems/phenomenon :
> a) The read back position of "DCM:ThetaM.RBV" is flickering.
> You see this already when the IOC is running.
> Why is that ?
> Mechanics are suspected to be a contributer.
> Mechanical load, high-precision encoder ?
> Is the controller running in closed loop ?
> b) The initialisation is still flaky - sometimes RBV has a value of 0.0
> I can see 3 ways to improve it:
> b1) Increase the sleep() even more, 5.0 seconds ??
> b2) Use the patched version of the motor from ESS,
> which has been improved to handle this.
> And comes with log-prints, which allow a better remote-debug
> using this log-prints
https://github.com/EuropeanSpallationSource/motor
> b3) I have seen the use of an EPICS (?) hook somewhere in one
> of the motor-drivers. But after searching for hooks I still
> can not find an example here on my disk or in old emails.
> Another question:
> How much is the motor moving ?
> /Torsten
> On 2025-01-03 02:54, LiangChih Chiang wrote:
>> I added epicsThreadSleep(1.0) after creating motor controller and axes.
>> I use camonitor to trace the VAL/RBV of motor records of three axes.
>> I rebooted ioc nine times.
>> Please see the following log.
>> I noticed that axes Z1 and Z2 successfully restored the VAL/RBV from
>> the controller every time.
>> But the behavior of axis ThetaM is strange.
>> Two out of nine reboots, the VAL field of ThetaM record is
>> successfully restored.
>> One out of nine reboots, the VAL field of ThetaM record is set to zero.
>> Six out of nine reboots, the VAL field of ThetaM record is set to
>> (previous value - 0.02).
>> Why -0.02?
>> DCM:Z1.VAL 2025-01-02 16:28:46.483683 -0.04
>> DCM:Z1.RBV 2025-01-02 16:28:46.483683 -0.0401
>> DCM:Z2.VAL 2025-01-02 20:41:47.713687 0.0657
>> DCM:Z2.RBV 2025-01-02 20:41:47.713687 0.0653
>> DCM:ThetaM.VAL 2025-01-02 16:28:50.353358 7.53376 <--
>> DCM:ThetaM.RBV 2025-01-02 16:28:50.353358 7.53376
>> ioc reboot
>> DCM:Z1.VAL 2025-01-03 08:46:20.410653 -0.0401
>> DCM:Z1.RBV 2025-01-03 08:46:20.410653 -0.04
>> DCM:Z2.VAL 2025-01-03 08:46:20.350513 0.0653
>> DCM:Z2.RBV 2025-01-03 08:46:20.350513 0.0657
>> DCM:ThetaM.VAL 2025-01-03 08:46:20.500699 7.53376 <--
>> same as previous
>> DCM:ThetaM.RBV 2025-01-03 08:46:20.500699 7.53376
>> ioc reboot
>> DCM:Z1.VAL 2025-01-03 08:54:04.045355 -0.04
>> DCM:Z1.RBV 2025-01-03 08:54:04.045355 -0.0401
>> DCM:Z2.VAL 2025-01-03 08:54:03.985246 0.0657
>> DCM:Z2.RBV 2025-01-03 08:54:03.985246 0.0653
>> DCM:ThetaM.VAL 2025-01-03 08:54:05.156115 7.51376 <--
>> different -0.02
>> DCM:ThetaM.RBV 2025-01-03 08:54:05.156115 7.52741 <--
>> motor move
>> DCM:ThetaM.RBV 2025-01-03 08:54:05.335235 7.52131
>> DCM:ThetaM.RBV 2025-01-03 08:54:05.505113 7.51621
>> DCM:ThetaM.RBV 2025-01-03 08:54:05.675255 7.51376
>> DCM:ThetaM.RBV 2025-01-03 08:54:05.845205 7.51361
>> DCM:ThetaM.VAL 2025-01-03 08:54:05.845205 7.51376
>> DCM:ThetaM.RBV 2025-01-03 08:54:05.995251 7.51356
>> DCM:ThetaM.RBV 2025-01-03 08:54:06.495140 7.51371
>> DCM:ThetaM.RBV 2025-01-03 08:54:06.795186 7.51376
>> DCM:ThetaM.RBV 2025-01-03 08:54:06.965241 7.51381
>> ioc reboot
>> DCM:Z1.VAL 2025-01-03 09:00:47.829590 -0.0401
>> DCM:Z1.RBV 2025-01-03 09:00:47.829590 -0.04
>> DCM:Z2.VAL 2025-01-03 09:00:47.769508 0.0653
>> DCM:Z2.RBV 2025-01-03 09:00:47.769508 0.0657
>> DCM:ThetaM.VAL 2025-01-03 09:00:49.279478 7.49377 <--
>> different -0.01999
>> DCM:ThetaM.RBV 2025-01-03 09:00:49.279478 7.49611 <--
>> motor move
>> DCM:ThetaM.RBV 2025-01-03 09:00:49.449660 7.49371
>> DCM:ThetaM.RBV 2025-01-03 09:00:49.619596 7.49351
>> DCM:ThetaM.VAL 2025-01-03 09:00:49.619596 7.49377
>> DCM:ThetaM.RBV 2025-01-03 09:00:49.939543 7.49356
>> DCM:ThetaM.RBV 2025-01-03 09:00:50.269661 7.49376
>> Manually move ThetaM to 7.553761
>> DCM:ThetaM.VAL 2025-01-03 09:04:05.044900 7.55378
>> DCM:ThetaM.VAL 2025-01-03 09:04:05.045646 7.55376
>> DCM:ThetaM.RBV 2025-01-03 09:04:05.371519 7.49566
>> DCM:ThetaM.RBV 2025-01-03 09:04:05.541574 7.50071
>> DCM:ThetaM.RBV 2025-01-03 09:04:05.711567 7.50711
>> DCM:ThetaM.RBV 2025-01-03 09:04:05.881592 7.51536
>> DCM:ThetaM.RBV 2025-01-03 09:04:06.061484 7.52551
>> DCM:ThetaM.RBV 2025-01-03 09:04:06.231575 7.53506
>> DCM:ThetaM.RBV 2025-01-03 09:04:06.402009 7.54296
>> DCM:ThetaM.RBV 2025-01-03 09:04:06.571571 7.54866
>> DCM:ThetaM.RBV 2025-01-03 09:04:06.741529 7.55221
>> DCM:ThetaM.RBV 2025-01-03 09:04:06.911574 7.55296
>> DCM:ThetaM.VAL 2025-01-03 09:04:06.911574 7.55376
>> DCM:ThetaM.RBV 2025-01-03 09:04:07.071671 7.55301
>> DCM:ThetaM.RBV 2025-01-03 09:04:07.241982 7.55326
>> DCM:ThetaM.RBV 2025-01-03 09:04:07.561637 7.55381
>> DCM:ThetaM.RBV 2025-01-03 09:04:07.881647 7.55346
>> DCM:ThetaM.RBV 2025-01-03 09:04:08.211724 7.55356
>> DCM:ThetaM.RBV 2025-01-03 09:04:08.531501 7.55376
>> ioc reboot
>> DCM:Z1.VAL 2025-01-03 09:05:56.102804 -0.04
>> DCM:Z1.RBV 2025-01-03 09:05:56.102804 -0.0401
>> DCM:Z2.VAL 2025-01-03 09:05:56.042681 0.0657
>> DCM:Z2.RBV 2025-01-03 09:05:56.042681 0.0653
>> DCM:ThetaM.VAL 2025-01-03 09:05:56.174482 7.55376 <--
>> same as previous
>> DCM:ThetaM.RBV 2025-01-03 09:05:56.174482 7.55376 <--
>> but motor move
>> DCM:ThetaM.RBV 2025-01-03 09:05:57.012778 7.55206
>> DCM:ThetaM.RBV 2025-01-03 09:05:57.502889 7.54196
>> DCM:ThetaM.RBV 2025-01-03 09:05:57.822823 7.54366
>> DCM:ThetaM.RBV 2025-01-03 09:05:57.992678 7.54791
>> DCM:ThetaM.RBV 2025-01-03 09:05:58.162720 7.55171
>> DCM:ThetaM.RBV 2025-01-03 09:05:58.342759 7.55266
>> DCM:ThetaM.RBV 2025-01-03 09:05:58.492806 7.55271
>> DCM:ThetaM.RBV 2025-01-03 09:05:58.662711 7.55371
>> DCM:ThetaM.RBV 2025-01-03 09:05:58.962828 7.55376
>> DCM:ThetaM.RBV 2025-01-03 09:05:59.132771 7.55381
>> DCM:ThetaM.RBV 2025-01-03 09:06:02.762853 7.55386
>> ioc reboot
>> DCM:Z1.VAL 2025-01-03 09:09:37.385148 -0.0401
>> DCM:Z1.RBV 2025-01-03 09:09:37.385148 -0.04
>> DCM:Z2.VAL 2025-01-03 09:09:37.325204 0.0653
>> DCM:Z2.RBV 2025-01-03 09:09:37.325204 0.0657
>> DCM:ThetaM.VAL 2025-01-03 09:09:38.354986 0 <--
>> different, zero!
>> DCM:ThetaM.RBV 2025-01-03 09:09:38.354986 7.55181 <--
>> motor move
>> DCM:ThetaM.RBV 2025-01-03 09:09:38.535008 7.54706
>> DCM:ThetaM.RBV 2025-01-03 09:09:38.704917 7.54026
>> DCM:ThetaM.RBV 2025-01-03 09:09:38.875048 7.53131
>> DCM:ThetaM.RBV 2025-01-03 09:09:39.045385 7.52046
>> DCM:ThetaM.RBV 2025-01-03 09:09:39.215134 7.50731
>> DCM:ThetaM.RBV 2025-01-03 09:09:39.385166 7.49361
>> DCM:ThetaM.RBV 2025-01-03 09:09:39.555112 7.48036
>> DCM:ThetaM.RBV 2025-01-03 09:09:39.725153 7.46636
>> DCM:ThetaM.RBV 2025-01-03 09:09:39.894942 7.45281
>> DCM:ThetaM.RBV 2025-01-03 09:09:40.064989 7.43961
>> DCM:ThetaM.RBV 2025-01-03 09:09:40.234971 7.42526
>> DCM:ThetaM.RBV 2025-01-03 09:09:40.405113 7.41221
>> DCM:ThetaM.RBV 2025-01-03 09:09:40.585072 7.39761
>> DCM:ThetaM.RBV 2025-01-03 09:09:40.755044 7.38401
>> DCM:ThetaM.RBV 2025-01-03 09:09:40.925113 7.37066
>> DCM:ThetaM.RBV 2025-01-03 09:09:42.095077 7.31426
>> DCM:ThetaM.VAL 2025-01-03 09:09:42.095077 7.31426 <-- I
>> stop the motor.
>> DCM:ThetaM.RBV 2025-01-03 09:09:46.705116 7.31421
>> ioc reboot
>> DCM:Z1.VAL 2025-01-03 09:12:18.906995 -0.04
>> DCM:Z1.RBV 2025-01-03 09:12:18.906995 -0.0401
>> DCM:Z2.VAL 2025-01-03 09:12:18.846984 0.0657
>> DCM:Z2.RBV 2025-01-03 09:12:18.846984 0.0653
>> DCM:ThetaM.VAL 2025-01-03 09:12:21.346979 7.29431 <--
>> different −0.01995
>> DCM:ThetaM.RBV 2025-01-03 09:12:21.346979 7.29431 <--
>> motor move
>> ioc reboot
>> DCM:Z1.VAL 2025-01-03 09:18:20.230656 -0.0401
>> DCM:Z1.RBV 2025-01-03 09:18:20.230656 -0.04
>> DCM:Z2.VAL 2025-01-03 09:18:20.170608 0.0653
>> DCM:Z2.RBV 2025-01-03 09:18:20.170608 0.0657
>> DCM:ThetaM.VAL 2025-01-03 09:18:20.311337 7.27437 <--
>> different −0.01994
>> DCM:ThetaM.RBV 2025-01-03 09:18:20.311337 7.29431 <--
>> motor move
>> DCM:ThetaM.RBV 2025-01-03 09:18:21.150538 7.29231
>> DCM:ThetaM.RBV 2025-01-03 09:18:21.320404 7.28771
>> DCM:ThetaM.RBV 2025-01-03 09:18:21.500407 7.28171
>> DCM:ThetaM.RBV 2025-01-03 09:18:21.670389 7.27681
>> DCM:ThetaM.RBV 2025-01-03 09:18:21.840686 7.27421
>> DCM:ThetaM.RBV 2025-01-03 09:18:22.010457 7.27406
>> DCM:ThetaM.VAL 2025-01-03 09:18:22.010457 7.27437
>> DCM:ThetaM.RBV 2025-01-03 09:18:22.330451 7.27421
>> DCM:ThetaM.RBV 2025-01-03 09:18:22.660350 7.27431
>> DCM:ThetaM.RBV 2025-01-03 09:18:22.960309 7.27436
>> DCM:ThetaM.RBV 2025-01-03 09:18:23.130896 7.27441
>> ioc reboot
>> DCM:Z1.VAL 2025-01-03 09:22:00.722740 -0.04
>> DCM:Z1.RBV 2025-01-03 09:22:00.722740 -0.0401
>> DCM:Z2.VAL 2025-01-03 09:22:00.662695 0.0657
>> DCM:Z2.RBV 2025-01-03 09:22:00.662695 0.0653
>> DCM:ThetaM.VAL 2025-01-03 09:22:02.912859 7.25442 <--
>> different −0.01995
>> DCM:ThetaM.RBV 2025-01-03 09:22:02.912859 7.25441 <--
>> motor move
>> ioc reboot
>> DCM:Z1.VAL 2025-01-03 09:33:58.400417 -0.0401
>> DCM:Z1.RBV 2025-01-03 09:33:58.400417 -0.04
>> DCM:Z2.VAL 2025-01-03 09:33:58.340350 0.0653
>> DCM:Z2.RBV 2025-01-03 09:33:58.340350 0.0657
>> DCM:ThetaM.VAL 2025-01-03 09:33:59.330344 7.23447 <--
>> different −0.01995
>> DCM:ThetaM.RBV 2025-01-03 09:33:59.330344 7.25241 <--
>> motor move
>> DCM:ThetaM.RBV 2025-01-03 09:33:59.500272 7.24781
>> DCM:ThetaM.RBV 2025-01-03 09:33:59.680584 7.24186
>> DCM:ThetaM.RBV 2025-01-03 09:33:59.850291 7.23701
>> DCM:ThetaM.RBV 2025-01-03 09:34:00.020355 7.23431
>> DCM:ThetaM.RBV 2025-01-03 09:34:00.190267 7.23416
>> DCM:ThetaM.VAL 2025-01-03 09:34:00.190267 7.23447
>> DCM:ThetaM.RBV 2025-01-03 09:34:00.510337 7.23431
>> DCM:ThetaM.RBV 2025-01-03 09:34:00.840415 7.23441
>> DCM:ThetaM.RBV 2025-01-03 09:34:01.140389 7.23446
>> DCM:ThetaM.RBV 2025-01-03 09:34:01.310255 7.23451
>> On Thu, Jan 2, 2025 at 11:26 AM LiangChih Chiang <yehnan174 at gmail.com
>> <mailto:yehnan174 at gmail.com>> wrote:
>> Hi,
>> >To explain a little more, it is important that the driver has
>> completed the first poll cycle for the position and status of each
>> axis before iocInit.
>> >This is because the motor record looks at those positions during
>> iocInit, and if there are non-zero it uses those values as the
>> current position.
>> >You can add the following to your startup script after you create
>> the controller and axes to sleep for 1 second.
>> I did add epicsThreadSleep(1.0).
>> There are 5 motors(axis 1 to 5) connected to the motor controller.
>> After epicsThreadSleep(1.0) added, it seems that the VAL/RBV of
>> motor records of axis 2 to 5 can be successfully loaded back from
>> the controller after IOC reboot.
>> But the behavior of axis 0 (this axis is the most important) is
>> strange.
>> After IOC reboot, the motor record of axis 0 will move.
>> It seems that the VAL field is set to a new value
>> and I can't figure out the relationship between the new and old
>> values.
>> The axis 0 is the main axis(Bragg angle) of a double crystal
>> monochromator,
>> and it has corresponding pseudo motor to represent the Energy of x-
>> ray beam.
>> On Wed, Nov 20, 2024 at 11:04 PM Mark Rivers
>> <rivers at cars.uchicago.edu <mailto:rivers at cars.uchicago.edu>>
>> each axis before iocInit. This is because the motor record
>> looks at those positions during iocInit, and if there are non-
>> zero it uses those values as the current position. You can add
>> the following to your startup script after you create the
>> Let us know if this does not fix the problem.
>> Mark
>> *From:* Tech-talk <tech-talk-bounces at aps.anl.gov <mailto:tech-
talk-bounces at aps.anl.gov>> on behalf of Torsten Bögershausen via
>> Tech-talk <tech-talk at aps.anl.gov <mailto:tech-talk at aps.anl.gov>>
>> *Sent:* Wednesday, November 20, 2024 5:15 AM
>> *To:* LiangChih Chiang <yehnan174 at gmail.com
>> <mailto:yehnan174 at gmail.com>>;
>> <mailto:tech-talk at aps.anl.gov> <tech-talk at aps.anl.gov
>> *Subject:* Re: I implemented the Model 3 of EPICS motor driver
>> support, but the VAL and RBV of motor record are zero after IOC
>> reboot.
>> Hej,
>> without having seen ypur code, I would speculate that you run
>> into a not-unknown issue using Model 3 motors, connected via
>> a serial cable, USB or Ethernet?
>> The value that the motorRecord needs is read from the driver,
>> wich must have been able to read it from your hardware.
>> Here are ESS we have a patched motor, which can handle this.
>> If you use the upstream version, the easist workaround may be
>> to add a sleep() after the createController() line in your st.cmd
>> HTH
>> /Torsten
>> On 2024-11-20 09:47, LiangChih Chiang via Tech-talk wrote:
>> > Hello, EPICS mates.
>> > I implemented the Model 3 of EPICS motor driver support for
>> some motor
>> > controller,
>> > but the VAL and RBV of the motor record are zero after IOC
>> reboot.
>> > I think the motor record doesn't restore the values of motor
>> pulse and
>> > encoder count from the motor controller after IOC reboot.
>> > What member functions of asynMotorController and
>> asynMotorAxis classes
>> > should I implement?
>> > Best regards.
- RE: I implemented the Model 3 of EPICS motor driver support, but the VAL and RBV of motor record are zero after IOC reboot. Mark Rivers via Tech-talk
- Re: I implemented the Model 3 of EPICS motor driver support, but the VAL and RBV of motor record are zero after IOC reboot. LiangChih Chiang via Tech-talk
- Re: I implemented the Model 3 of EPICS motor driver support, but the VAL and RBV of motor record are zero after IOC reboot. Torsten Bögershausen via Tech-talk
- Re: I implemented the Model 3 of EPICS motor driver support, but the VAL and RBV of motor record are zero after IOC reboot. Mark Rivers via Tech-talk
<2025>
<2025>
