1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: RE: concat multiple waveform records [SEC=OFFICIAL]
From: Jignesh Patel via Tech-talk <[email protected]>
To: "'STARRITT, Andrew'" <[email protected]>, "'Johnson, Andrew N.'" <[email protected]>
Cc: [email protected]
Date: Tue, 21 Jan 2025 12:58:06 +0530
Hi Andrew,
Thanks for the link, I will explore both options concat and aCalcout.
Best regards,
Jignesh
Sent: 21 January 2025 11:43
To: Johnson, Andrew N. <[email protected]>; Jignesh Patel <[email protected]>; [email protected]
Hi Jignesh,
You could also try the concat record, which is available here:
https://github.com/AustralianSynchrotron/concat-record
Cheers
Andrew Starritt
Australian Synchrotron
OFFICIAL
From: Tech-talk <[email protected]> On Behalf Of Johnson, Andrew N. via Tech-talk
Sent: Saturday, January 18, 2025 6:13 AM
To: Jignesh Patel <[email protected]>; [email protected]
Subject: Re: concat multiple waveform records
CAUTION, EXTERNAL EMAIL: This message has come from outside of ANSTO. Do not take action, click links or open attachments unless you trust the source of this message and know the content is safe. Report spam and phishing using the Report Message button or if unsure, forward this message to [email protected] as an attachment.
Hi Jignesh,
I haven’t used it myself, but it looks like the aynApps aCalcout record type should be able to do this, using the CAT operator, although it might not be the most efficient way. The other approach I would look at would be to write a subroutine for the aSub record type to combine your input array values into an output array — this requires you to be able to write C code.
Hope this helps, please reply to tech-talk with any follow-up questions you have.
- Andrew
Complexity comes for free, Simplicity you have to work for.
On 1/17/25, 2:13 AM, "Tech-talk" <[email protected]> wrote:
I have requirement to concat multiple waveform records received from Modbus device to single waveform.
Please suggest aConcat or joinArray is suitable for this, though I have never used it.
Please guide.
Thanks and best regards,
Jignesh
RE: concat multiple waveform records [SEC=OFFICIAL] Jignesh Patel via Tech-talk
concat multiple waveform records Jignesh Patel via Tech-talk
Re: concat multiple waveform records Johnson, Andrew N. via Tech-talk
RE: concat multiple waveform records [SEC=OFFICIAL] STARRITT, Andrew via Tech-talk
Prev: RE: concat multiple waveform records [SEC=OFFICIAL] STARRITT, Andrew via Tech-talk
Next: Re: EPICS INSTALL_LOCATION/FINAL_LOCATION doesn't work? Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Next: RE: concat multiple waveform records [SEC=OFFICIAL] Jignesh Patel via Tech-talk
