1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Re: MRF kernel modules not seeing hardware
From: Jukka Pietarinen via Tech-talk <[email protected]>
To: [email protected]
Date: Thu, 30 Jan 2025 14:48:05 +0200
Hi Evan,
On the cPCI-EVG-300 and cPCI-EVR-300 the PCI IDs are stored in the FPGA firmware. To me this looks like a hardware error, tied low/open PCI address/data line, but I think in this case you should be seeing PCI bus parity errors. Is your PCI bus configured for 33 MHz operation?
Jukka
On 1/30/2025 6:40 AM, Daykin, Evan via Tech-talk wrote:
Are the PCI IDs supposed to be intrinsic/stored on the card? The odd thing I'm seeing is that the *same* card on the same backplane has a different ID depending on which CPU I use. A known "good" CPU card and kernel module install is seeing 152, the "bad" is seeing 150.
Get Outlook for Android <https://urldefense.us/v3/__https://aka.ms/ AAb9ysg__;!!G_uCfscf7eWS!f9BlP7yLbdRDG9pvOMrXpVBYO_Z- Nu4WsAbHTNtKrsZrw9v7DX5Rw2upXCuxIwU39HUPU5vSIF7yn6KiuE79dZPF$>
*Sent:* Wednesday, January 29, 2025 11:17:30 PM
*To:* Han Lee <[email protected]>; Di Wang <[email protected]>; [email protected] <[email protected]> *Cc:* EPICS tech-talk <[email protected]>; [email protected] <[email protected]>
*Subject:* Re: MRF kernel modules not seeing hardware
[EXTERNAL] This email originated from outside of FRIB
On 1/29/25 18:52, Han Lee via Tech-talk wrote:
FYI, The supported PCI IDs
https://urldefense.us/v3/__https://github.com/epics-modules/mrfioc2/blob/master/mrmShared/linux/__;!!G_uCfscf7eWS!eIt84DuAvD8lvrBYUVeKIWW6oVOU9smlkbov6ZnNB3lGK_Onhu1nhQoj9uqGfP1xG9oQz6GTrXr5lqS3gIYLYj7N-LJoJ-g4$
uio_mrf.c#L41-L74 <https://urldefense.us/v3/__https://github.com/epics- modules/mrfioc2/blob/master/mrmShared/linux/uio_mrf.c*L41-L74__;Iw!! G_uCfscf7eWS!f9BlP7yLbdRDG9pvOMrXpVBYO_Z- Nu4WsAbHTNtKrsZrw9v7DX5Rw2upXCuxIwU39HUPU5vSIF7yn6KiuLd20tPK$> <https ://github.com/epics-modules/mrfioc2/blob/master/mrmShared/linux/ uio_mrf.c#L41-L74>
I think the essential point has already been made, when a PCI device is enumerated, but no loaded driver associates, this is almost always the result of a PCI ID mis-match.
fyi. the 'modinfo' utility can dump the match/alias list from the meta- data stored
in a compiled kernel module.
$ modinfo mrf.ko
alias:          pci:v000010EEd00007011sv00001A3Esd0000232Cbc*sc*i*
alias:          pci:v000010EEd00007011sv00001A3Esd0000132Cbc*sc*i*
alias:          pci:v00001A3Ed0000152Csv00001A3Esd0000152Cbc*sc*i*
alias:          pci:v00001A3Ed0000252Csv00001A3Esd0000252Cbc*sc*i*
alias:          pci:v000010EEd00007011sv00001A3Esd0000172Cbc*sc*i*
alias:          pci:v00001204d0000EC30sv00001A3Esd0000172Cbc*sc*i*
alias:          pci:v000010B5d00009056sv00001A3Esd0000192Cbc*sc*i*
alias:          pci:v000010B5d00009030sv00001A3Esd000011E6bc*sc*i*
alias:          pci:v000010B5d00009030sv00001A3Esd000020E6bc*sc*i*
alias:          pci:v000010B5d00009030sv00001A3Esd000020DCbc*sc*i*
alias:          pci:v000010B5d00009030sv00001A3Esd000010E6bc*sc*i*
These lines decode as key-value pairs with wildcards for some values.
eg. "pci:v000010B5d00009030sv00001A3Esd000010E6bc*sc*i*"
will match a PCI vendor:device 0x10ee:0x9030 sub-vendor:sub-device 0x1a3e:0x10e6
"bc*" and "sc*" match any class/sub-class
"i*" matches any interface.  Although I'm not sure what "interface" means in this context.
Re: MRF kernel modules not seeing hardware Han Lee via Tech-talk
Re: MRF kernel modules not seeing hardware Michael Davidsaver via Tech-talk
Re: MRF kernel modules not seeing hardware Daykin, Evan via Tech-talk
Prev: Re: Archiver Appliance - Limit on PVs Eusebio Naif Al-Soliman Fuentes via Tech-talk
Next: Re: archiver appliance and CA -> PVA Sky Brewer via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Prev: RE: MRF kernel modules not seeing hardware Daykin, Evan via Tech-talk
Next: archiver appliance and CA -> PVA Pierrick M Hanlet via Tech-talk
