Hi all,
Furthermore, even explicity archiving them with
pva:// they still won't
connect. Apart from reverting back to CA, what can I do so that they
connect to the AA with PVA?
Resubmitting should work, but the PVs need to be removed from the archiver first, via delete for example. We currently don’t have a feature to migrate from CA to PVA or vice versa. Sounds like a good idea though, made
an issue:
https://github.com/archiver-appliance/epicsarchiverap/issues/325
For fun, I tried simply changing this key for a couple of
scalar double PVs. I was a little concerned that these
might show up as Type Change events, which AA does not
handle. However, in this case it did not. So all is well.
This I think should work, but probably you want to do a restart of the archiver after rather than doing this live.
An alternative is:
Pause the pv
Use the /getPVTypeInfo endpoint to get the type info
Edit the json output to have pvAccess set to True
Use the /putPVTypeInfo endpoint
https://epicsarchiver.readthedocs.io/en/latest/developer/mgmt_scriptables.html
to update the pvTypeInfo.
Resume the PV
I don’t particularly want to encourage this , as it isn’t much different to manually changing in the db. And just as risky. Resubmission I think is the safest method.
Hope that helps
Sky
