On 2/11/25 05:31, Neidherr, Dennis Dr. via Tech-talk wrote:
Hi Ziga,
thanks a lot. For ai records I knew about the MDEL field, but I did not know that there is something similar for strings.
Referring to the RRM for the stringout record type [1], you can set MPST
and potentially APST.
field(MPST, "Always")
which is implemented in code at [2]
... Is there a purpose behind that difference? ...
It is inefficient to transmit the same value repeatedly, so the default
is not to do so.
[1] https ://epics.anl.gov/base/R7-0/8-docs/stringoutRecord.html
[2] https ://github.com/epics-base/epics-base/blob/1d19ba4cc2e8c9ab17288b684022a0682e398bde/modules/database/src/std/rec/stringoutRecord.c#L220-L227
Greetings Dennis
-----Original Message-----
Sent: Dienstag, 11. Februar 2025 14:22
To: Neidherr, Dennis Dr. <[email protected]>; [email protected]
Subject: RE: Update behavior of camonitor
Hi Dennis,
Most records will only send out a monitor event when the value changes.
Certain records have dedicated monitor parameter fields such as MDEL (ai record) or MPST (stringin or waveform record).
Here is example from Component Reference Manual for AI record.
Monitor Parameters
These parameters are used to determine when to send monitors placed on the VAL field. The monitors are sent when the current value exceeds the last transmitted value by the appropriate deadband. If these fields are set to zero, a monitor will be triggered every time the value changes; if set to -1, a monitor will be sent every time the record is processed.
The ADEL field sets the deadband for archive monitors (DBE_LOG events), while the MDEL field controls value monitors (DBE_VALUE events).
The remaining fields are used by the record at run-time to implement the record monitoring functionality.
Field Summary Type DCT Default Read Write CA PP
ADEL Archive Deadband DOUBLE Yes Yes Yes No
MDEL Monitor Deadband DOUBLE Yes Yes Yes No
ALST Last Value Archived DOUBLE No Yes No No
MLST Last Val Monitored DOUBLE No Yes No No
ORAW Previous Raw Value LONG No Yes No No
As described above if you set AI record's MDEL to -1 it will update via camonitor each time the record is processed.
Be aware that STRINGIN has a different implementation, so check the Component Reference Manual [1] for the records that you plan to use.
Hope this helps,
Žiga
[1] for EPICS base 7.0.8 https://epics.anl.gov/base/R7-0/8-docs/ComponentReference.html
From: Tech-talk <[email protected]> On Behalf Of Neidherr,
Sent: Tuesday, February 11, 2025 13:51
To: [email protected]
Subject: Update behavior of camonitor
Dear all,
I have a small and very basic question about the behavior of camonitor:
It seems to be that it depends on the type of the record if I get an
update in camonitor or not when I overwrite the record value with
exactly the same value. Simple types like "stringout" do not trigger
an update whereas a waveform for example does. Is there a purpose
behind that difference? And can I somehow reproduce the
"waveform-behavior" also for simple record types? An alternative would
be to use the waveform record for everything, but maybe there is an easier solution.
Thanks a lot
Greetings Dennis
- Re: Update behavior of camonitor Johnson, Andrew N. via Tech-talk
- Update behavior of camonitor Neidherr, Dennis Dr. via Tech-talk
- RE: Update behavior of camonitor Žiga Oven via Tech-talk
- RE: Update behavior of camonitor Neidherr, Dennis Dr. via Tech-talk
Re: Update behavior of camonitor bob dalesio via Tech-talk
<2025>
2026
<2025>
2026
