The
waveform record also now has the fields MPST and APST, but their default value is "Always". The implementation of the "On Change" choice calculates a 32-bit hash of the array data buffer and only sends updates if the hash value has changed since the last
monitor was sent. Since there is a 1 in 2**32 chance that two different subsequent array values
might hash to the same value, using "On change" isn't recommended for all systems.
- Andrew
Complexity comes for free, Simplicity you have to work for.
On 2/11/25 05:31, Neidherr, Dennis Dr. via Tech-talk wrote:
> Hi Ziga,
> thanks a lot. For ai records I knew about the MDEL field, but I did not know that there is something similar for strings.
Referring to the RRM for the stringout record type [1], you can set MPST
and potentially APST.
> field(MPST, "Always")
which is implemented in code at [2]
> ... Is there a purpose behind that difference? ...
It is inefficient to transmit the same value repeatedly, so the default
is not to do so.
[1] https ://epics.anl.gov/base/R7-0/8-docs/stringoutRecord.html
[2] https ://github.com/epics-base/epics-base/blob/1d19ba4cc2e8c9ab17288b684022a0682e398bde/modules/database/src/std/rec/stringoutRecord.c#L220-L227
> Greetings Dennis
> -----Original Message-----
> From: Žiga Oven <[email protected]>
> Sent: Dienstag, 11. Februar 2025 14:22
> To: Neidherr, Dennis Dr. <[email protected]>; [email protected]
> Subject: RE: Update behavior of camonitor
> Hi Dennis,
> Most records will only send out a monitor event when the value changes.
> Certain records have dedicated monitor parameter fields such as MDEL (ai record) or MPST (stringin or waveform record).
> Here is example from Component Reference Manual for AI record.
> Monitor Parameters
> These parameters are used to determine when to send monitors placed on the VAL field. The monitors are sent when the current value exceeds the last transmitted value by the appropriate deadband. If these fields are set to zero, a monitor will be triggered
every time the value changes; if set to -1, a monitor will be sent every time the record is processed.
> The ADEL field sets the deadband for archive monitors (DBE_LOG events), while the MDEL field controls value monitors (DBE_VALUE events).
> The remaining fields are used by the record at run-time to implement the record monitoring functionality.
> Field Summary Type DCT Default Read Write CA PP
> ADEL Archive Deadband DOUBLE Yes Yes Yes No
> MDEL Monitor Deadband DOUBLE Yes Yes Yes No
> ALST Last Value Archived DOUBLE No Yes No No
> MLST Last Val Monitored DOUBLE No Yes No No
> ORAW Previous Raw Value LONG No Yes No No
> As described above if you set AI record's MDEL to -1 it will update via camonitor each time the record is processed.
> Be aware that STRINGIN has a different implementation, so check the Component Reference Manual [1] for the records that you plan to use.
> Hope this helps,
> Žiga
> [1] for EPICS base 7.0.8
https://epics.anl.gov/base/R7-0/8-docs/ComponentReference.html
>> From: Tech-talk <[email protected]> On Behalf Of Neidherr,
>> Sent: Tuesday, February 11, 2025 13:51
>> To: [email protected]
>> Subject: Update behavior of camonitor
>> Dear all,
>> I have a small and very basic question about the behavior of camonitor:
>> It seems to be that it depends on the type of the record if I get an
>> update in camonitor or not when I overwrite the record value with
>> exactly the same value. Simple types like "stringout" do not trigger
>> an update whereas a waveform for example does. Is there a purpose
>> behind that difference? And can I somehow reproduce the
>> "waveform-behavior" also for simple record types? An alternative would
>> be to use the waveform record for everything, but maybe there is an easier solution.
>> Thanks a lot
>> Greetings Dennis
- Update behavior of camonitor Neidherr, Dennis Dr. via Tech-talk
- RE: Update behavior of camonitor Žiga Oven via Tech-talk
- RE: Update behavior of camonitor Neidherr, Dennis Dr. via Tech-talk
- Re: Update behavior of camonitor Michael Davidsaver via Tech-talk
Exporting EPICS archiver as a H5 file. Wang, Andrew via Tech-talk
<2025>
2026
Re: Update behavior of camonitor bob dalesio via Tech-talk
<2025>
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
