Hello again.
After trying to configure the Archiver Appliance on the VM without success, I got myself a test PC to install the Archiver Appliance natively. It has an Intel i7-4790 and 16 GB of RAM.
I have made a single machine installation and I am running the 4 Tomcats with 2GB for each one. With the default parameters I have encountered that I can barely archive 10000 PVs. I don't know if anyone can tell me which parameters I need to change in order to archive at least 50000 PVs updating every 500ms.
I have also noticed that the problem I had with the root partition filling up with memory in a short time is due to the archappl_install/engine/logs/catalina.out. Does anyone know what can be done to keep that file size under control?
Thanks in advance.
Eusebio.
Saludos/Best regards
University of Granada
Eusebio Naif Al-Soliman Fuentes
PhD student
eunaif at correo.ugr.es
El 2025-02-03 12:16, Eusebio Naif Al-Soliman Fuentes escribió:
Hello Sky.
Regarding the disk speed, I've tested it with "hdparm" and the "/dev/sdb" partition (in which the "/var" directory is mounted) has the following results:
sudo hdparm -Tt /dev/sdb
/dev/sdb: Timing cached reads: 19774 MB in 1.99 seconds = 9935.12 MB/sec Timing buffered disk reads: 4084 MB in 3.00 seconds = 1361.22 MB/sec Also, the STS is, in theory, mounted in the "/var" disk, along side the MTS and the LTS. In the sampleStartup.sh file I've the following lines:
# Set the location of short term and long term stores; this is necessary only if your policy demands it export ARCHAPPL_SHORT_TERM_FOLDER=/var/arch/sts/ export ARCHAPPL_MEDIUM_TERM_FOLDER=/var/arch/mts/ export ARCHAPPL_LONG_TERM_FOLDER=/var/arch/lts/
I don't know if there is another file which overwrites this configuration.
Finally, thanks for the advise with the JVM memory. I thought there was only 1 instance of Java instead of 4.
Thanks, Eusebio.
--- Saludos/Best regards
Eusebio Naif Al-Soliman Fuentes MSc. Data Science and Computer Engineering
El 2025-01-31 14:32, Sky Brewer via Tech-talk escribió:
Hi Eusebio,
You shouldn't have any performance problems with that setup for the Archiver Appliance, and you shouldn't need more appliances unless you are in the 100 000 PV range (on a larger machine).
It's very hard to debug performance problems, even harder from a distance. Some initial ideas
* How fast is the write interface to the var disk * Is the STS on the var disk? Using RAM or the primary disk might help here. * The JVM I believe takes whatever you give it, if you are running out of memory you should reduce what you gave it here. The sampleStartup.sh creates a tomcat per war file, so that's 4x whatever memory you changed in the script. Since you have 8GB, probably 1GB is a safe number.
Deployments of the Archiver Appliance unfortunately is still quite site dependent and varied. Something I hope to improve by providing docker containers etc.
Some ideas: There is a docker container version with all webapps in one instance https://urldefense.com/v3/__https://urldefense.us/v3/__https:/*github.com/archiver-appliance/epicsarchiverap/pkgs/container/epicsarchiverap/336979389?tag=singletomcat-61c7442__;!!G_uCfscf7eWS!ZB5ixC9H9C2CsDUMxdsywR6idGZy4zDBWSUwLuOmWoPyYfQAJ_pV37sgR7lQIGSjEEbabw1POYKd8RRrqkao4Ugg$__;Lw!!D9dNQwwGXtA!X6m_pUxk0nwIIbWXuig5HBrRAi2e6B4-pHmrbV8JWWP0JlUp_g-qx481_gQB5aqMtwUa7k64dI64FkiUqXAMQSVq$
A variety of startup scripts in https://urldefense.com/v3/__https://urldefense.us/v3/__https:/*github.com/archiver-appliance/epicsarchiverap/tree/master/docs/docs/source/samples__;!!G_uCfscf7eWS!ZB5ixC9H9C2CsDUMxdsywR6idGZy4zDBWSUwLuOmWoPyYfQAJ_pV37sgR7lQIGSjEEbabw1POYKd8RRrqnP_f8Fw$__;Lw!!D9dNQwwGXtA!X6m_pUxk0nwIIbWXuig5HBrRAi2e6B4-pHmrbV8JWWP0JlUp_g-qx481_gQB5aqMtwUa7k64dI64FkiUqS8AYc95$
Can't remember if this is accessible outside of Sweden/Denmark, but ESS ansible deployment repository https://urldefense.com/v3/__https://urldefense.us/v3/__https:/*gitlab.esss.lu.se/ics-ansible-galaxy/ics-ans-role-epicsarchiverap__;!!G_uCfscf7eWS!ZB5ixC9H9C2CsDUMxdsywR6idGZy4zDBWSUwLuOmWoPyYfQAJ_pV37sgR7lQIGSjEEbabw1POYKd8RRrqsME4Gdv$__;Lw!!D9dNQwwGXtA!X6m_pUxk0nwIIbWXuig5HBrRAi2e6B4-pHmrbV8JWWP0JlUp_g-qx481_gQB5aqMtwUa7k64dI64FkiUqTM3EKxW$ (not updated for 2.05)
Hope that helps
Sky
- RE: Re: Archiver Appliance - Limit on PVs Sky Brewer via Tech-talk
- Re: Archiver Appliance - Limit on PVs Eusebio Naif Al-Soliman Fuentes via Tech-talk
Last call for EPICS on Microsoft VS2010 and VS2012 Compilers Johnson, Andrew N. via Tech-talk
IOC, QServ, and AMSG / alarm.message Ivan Finch - STFC UKRI via Tech-talk
<2025>
Re: Archiver Appliance - Limit on PVs Shankar, Murali via Tech-talk
<2025>
ANJ, 13 Feb 2025 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
