1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Re: [EXTERNAL] Re: Channel Access performance with RTEMS on MVME5500
From: Michael Davidsaver via Tech-talk <[email protected]>
To: "Wells, Alex (DLSLtd,RAL,LSCI)" <[email protected]>
Date: Thu, 20 Mar 2025 08:22:32 -0700
Hi Alex,
On 3/20/25 06:39, Kasemir, Kay via Tech-talk wrote:
> EPICS Mutexes in an interrupt context … crashes
No idea about RTEMS in particular, but you can generally not _take_ a mutex in an interrupt context.
Regardless of USE_POSIX_THREAD_PRIORITY_SCHEDULING, locking a contended mutex from interrupt context WILL DEADLOCK.  Disabling priority inheritance may make contention less likely in some situations, but this does not change the fundamentals.  Any use of epicsMutex outside of regular/thread context is Undefined Behavior.
You may be able to _give_ a mutex to wake a thread that’s waiting on that mutex, but details will depend on the OS.
You can use epicsEvent from within an interrupt service routine to signal a thread that it should start doing some work.
If the interrupt context currently uses mutexes, it might be best to rewrite it to use epicsEvent and maybe move work out of the interrupt service routine into a thread that’s woken by the event.
I will second this recommendation.  I also find that using epicsEvent as a tool to hand work to a thread is often the best design.
Alternately, if you are looking of a more direct search/replace fix, then I would recommend looking at epicsSpin (aka. spin-lock) which is a mutual exclusion primitive intended to be IRQ safe.
On 2025-03-20, 9:32AM, "Tech-talk" <[email protected]> wrote:
Hello Alex,
the ‘USE_POSIX_THREAD_PRIORITY_SCHEDULING = NO’' is an EPICS thing.
I don't know exactly what this does as I have never used it with RTEMS.
I think that cancels out the whole point of a priority-based system ;-)
All your jobs have a very low priority 253 (in RTEMS) and priority 2 in Posix.
Based on my gut feeling, I would recommend setting back to USE_POSIX_THREAD_PRIORITY_SCHEDULING=YES and then
in rtems_init for POSIX_Init() to set the priority high. You can use the code element I sent to you in the last tech-talk-reply.
Then all the interrupt handlers will also get a high priority and I assume that the crashes will also go away.
Would you like to try that?
Good luck,
Heinz
> On 20. Mar 2025, at 12:50, Wells, Alex (DLSLtd,RAL,LSCI) <[email protected]> wrote:
> Hi Heinz,
> Thank you for the information. There's definitely something fishy going on with the thread priorities somewhere; it seems that everything is being started with the same priority.
> I will also note that we are building RTEMS with "USE_POSIX_THREAD_PRIORITY_SCHEDULING = NO". This appears to be required, as we use EPICS Mutexes in an interrupt context, and if we leave this set to "YES" we see a crashes. Could this be related to the oddities below?
Re: [EXTERNAL] Re: Channel Access performance with RTEMS on MVME5500 Johnson, Andrew N. via Tech-talk
Channel Access performance with RTEMS on MVME5500 Wells, Alex (DLSLtd,RAL,LSCI) via Tech-talk
Re: Channel Access performance with RTEMS on MVME5500 Michael Davidsaver via Tech-talk
Re: Channel Access performance with RTEMS on MVME5500 Wells, Alex (DLSLtd,RAL,LSCI) via Tech-talk
Re: Channel Access performance with RTEMS on MVME5500 Heinz Junkes via Tech-talk
Re: [EXTERNAL] Re: Channel Access performance with RTEMS on MVME5500 Kasemir, Kay via Tech-talk
Prev: RE: [External] RE: Thermo Fischer FHT 6020 Radiation Monitor Leblanc, Gregory via Tech-talk
Next: Re: [EXTERNAL] Re: Channel Access performance with RTEMS on MVME5500 Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Prev: Re: [EXTERNAL] Re: Channel Access performance with RTEMS on MVME5500 Joel Sherrill via Tech-talk
