1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: RE: EPICS build problem
From: Freddie Akeroyd - STFC UKRI via Tech-talk <[email protected]>
To: Federico Galdenzi <[email protected]>
Date: Wed, 16 Apr 2025 15:42:32 +0000
The windows.bat / win32.bat files just run vcvarsall.bat, set EPICS_HOST_ARCH and add perl to the PATH, so are just convenient shortcuts and not strictly necessary
When vcvarsall.bat is run it needs an argument to tell it the build architecture, and this needs to match your intended EPICS_HOST_ARCH.   So try
    vcvarsall.bat x64
    set EPICS_HOST_ARCH=windows-x64
for a 64bit build. If you needed a 32bit built it would be:
    vcvarsall.bat x86
    set EPICS_HOST_ARCH=win32-x86
Freddie
-----Original Message-----
Sent: 16 April 2025 14:18
To: Akeroyd, Freddie (STFC,RAL,ISIS) <[email protected]>
Cc: Rivers <[email protected]>; [email protected]
Subject: Re: EPICS build problem
Hi Freddie,
I've followed this part of the tutorial:
Download the distribution from e.g.
https://urldefense.us/v3/__https://epics-controls.org/download/base/base-7.0.4.1.tar.gz__;!!G_uCfscf7eWS!c1lDfN5t1iRCDMbpVMwmC-GZ5qPmuQYEH9RJybLPsLuQGWe9a5pN0eCOFX1yf2XlZNTPHS1tQ4y-UlBgaEDkeH_vT8mEQyTlQG4$ .
Unpack it into a work directory.
Open a Windows command prompt and change into the directory you unpacked EPICS Base into.
Note: The complete path of the current directory mustn’t contain any spaces or parentheses. If your working directory path does, you can do another cd into the same directory, replacing every path component containing spaces or parentheses with its Windows short path (that can be displayed with dir /x).
Set the EPICS host architecture EPICS_HOST_ARCH (windows-x64 for 64bit builds, win32-x86 for 32bit builds).
Run the vcvarsall.bat script of your installation (the exact path depends on the type and language of installation) to set the environment for your build.
Run make (or gmake if using the version from Strawberry Perl).
When i cd to my folder, and typed "where cl" it doesnt' return anything not even after i ran the vcvarsall.bat. I didnt' ran the windows.bat because it wasn't written.
Should i do it directly from the folder?
Il 2025-04-16 13:39 Freddie Akeroyd - STFC UKRI ha scritto:
> Hi,
> In the startup directory of epics there are two bat files  "win32.bat"
> and "windows.bat" - which did you use to setup the compiler path etc. ?
>  win32.bat choses the compiler for 32bit builds and windows.bat for
> 64bit builds. Your EPICS_HOST_ARCH environment variable is set for a
> 64bit builds, but the error message suggests your build may be using
> the 32bit compiler instead as the linker cannot target x64. If you
> type
>     where cl
> do you see a path with x64 in it like
>     C:\Program Files\Microsoft Visual
> Studio\2022\Enterprise\VC\Tools\MSVC\14.41.34120\bin\Hostx64\x64\cl.ex
> e
> Or do you see x86 present instead?
> Regards,
> Freddie
> From: Federico Galdenzi <[email protected]>
> Sent: 16 April 2025 08:15
> To: Akeroyd, Freddie (STFC,RAL,ISIS) <[email protected]>;
> Cc: [email protected]
> Thanks in advance for the help. I made the log for make and also i can
> tell that i'm following by letter the tutorial that i've linked to
> download and build epic base. I've installed perl and make manually.
> Best regards.
> Il 2025-04-15 14:07 Freddie Akeroyd - STFC UKRI ha scritto:
>> Hi,
>> We'll need to see a bit more of your build log to see exactly which
>> libraries it is having a problem with, can you please post the whole
>> build log by doing  something like
>>     make clean uninstall
>>     make > make.log 2>&1
>> And posting make.log
>> Thanks,
>> Freddie
>>> From: Tech-talk <[email protected]> On Behalf Of
>>> Federico Galdenzi via Tech-talk
>>> Sent: 15 April 2025 12:36
>>> To: [email protected]
>>> Subject: EPICS build problem
>>> Good morning all,
>>> I have a problem for installing EPICS on my machine. I've followed
>>> the instruction given in this site:
>>> https://urldefense.us/v3/__https://docs.epics-
>>> controls.org/en/latest/getting-started/installation-windows-
>>> plain.html__;!!G_uCfscf7eWS!a8JQwg02mRdcrkywW5dKHGcNsNeXLRf67b5
>>> q5862JV6Ua7PGUqoY-cZfs9LwLV3OMeJndOUxaevRC33Kk58OGeOCCW8$
>>> but it seems that i'm missing something, because i get the "make"
>>> fatal error
>>> LNK1112: module machine type 'x86' conflicts with target machine
>>> type 'x64'.
>>> I'm kinda new to this world but i cant' manage to understand what
>>> i'm doing wrong. It seems that i'm using 32 bit libraries on a 64
>>> bit environment, but i'm using Visual Studio latests kit's for
>>> developing in C++ in both 64 and
>>> 32 bit.
>>> What can i do?
Re: EPICS build problem Federico Galdenzi via Tech-talk
RE: EPICS build problem Freddie Akeroyd - STFC UKRI via Tech-talk
Prev: Re: EPICS build problem Federico Galdenzi via Tech-talk
Next: CaLab - strange replies Dariush Hampai via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Next: Re: EPICS build problem Federico Galdenzi via Tech-talk
