1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: EPICS build problem
From: Federico Galdenzi via Tech-talk <[email protected]>
To: Freddie Akeroyd - STFC UKRI <[email protected]>
Cc: [email protected]
Date: Wed, 16 Apr 2025 15:18:02 +0200
Hi Freddie,
I've followed this part of the tutorial:
Download the distribution from e.g. https://urldefense.us/v3/__https://epics-controls.org/download/base/base-7.0.4.1.tar.gz__;!!G_uCfscf7eWS!f_jetzd-K2r1G-0E_Zv9zjtYiGo8BXPMtqLcSDchZBqTZpbQiAip-iIgDvINnl8VtGXPn7xXVeNDYSAvmHfXSULPBoc$ .
Unpack it into a work directory.
Open a Windows command prompt and change into the directory you unpacked EPICS Base into.
Note: The complete path of the current directory mustn’t contain any spaces or parentheses. If your working directory path does, you can do another cd into the same directory, replacing every path component containing spaces or parentheses with its Windows short path (that can be displayed with dir /x).
Set the EPICS host architecture EPICS_HOST_ARCH (windows-x64 for 64bit builds, win32-x86 for 32bit builds).
Run the vcvarsall.bat script of your installation (the exact path depends on the type and language of installation) to set the environment for your build.
Run make (or gmake if using the version from Strawberry Perl).
When i cd to my folder, and typed "where cl" it doesnt' return anything not even after i ran the vcvarsall.bat. I didnt' ran the windows.bat because it wasn't written.
Should i do it directly from the folder?
Il 2025-04-16 13:39 Freddie Akeroyd - STFC UKRI ha scritto:
In the startup directory of epics there are two bat files "win32.bat" and "windows.bat" - which did you use to setup the compiler path etc. ? win32.bat choses the compiler for 32bit builds and windows.bat for 64bit builds. Your EPICS_HOST_ARCH environment variable is set for a 64bit builds, but the error message suggests your build may be using the 32bit compiler instead as the linker cannot target x64. If you type
    where cl
do you see a path with x64 in it like
C:\Program Files\Microsoft Visual Studio\2022\Enterprise\VC\Tools\MSVC\14.41.34120\bin\Hostx64\x64\cl.exe
Or do you see x86 present instead?
Freddie
-----Original Message-----
Sent: 16 April 2025 08:15
To: Akeroyd, Freddie (STFC,RAL,ISIS) <[email protected]>; Rivers <[email protected]>
Thanks in advance for the help. I made the log for make and also i can tell that i'm following by letter the tutorial that i've linked to download and build epic base. I've installed perl and make manually.
Best regards.
Il 2025-04-15 14:07 Freddie Akeroyd - STFC UKRI ha scritto:
We'll need to see a bit more of your build log to see exactly which
libraries it is having a problem with, can you please post the whole
build log by doing  something like
    make clean uninstall
    make > make.log 2>&1
And posting make.log
Freddie
From: Tech-talk <[email protected]> On Behalf Of Federico
Sent: 15 April 2025 12:36
To: [email protected]
Subject: EPICS build problem
Good morning all,
I have a problem for installing EPICS on my machine. I've followed
the instruction given in this site:
https://urldefense.us/v3/__https://docs.epics-
controls.org/en/latest/getting-started/installation-windows-
plain.html__;!!G_uCfscf7eWS!a8JQwg02mRdcrkywW5dKHGcNsNeXLRf67b5
q5862JV6Ua7PGUqoY-cZfs9LwLV3OMeJndOUxaevRC33Kk58OGeOCCW8$
but it seems that i'm missing something, because i get the "make"
fatal error
LNK1112: module machine type 'x86' conflicts with target machine type
'x64'.
I'm kinda new to this world but i cant' manage to understand what i'm
doing wrong. It seems that i'm using 32 bit libraries on a 64 bit
environment, but i'm using Visual Studio latests kit's for developing
in C++ in both 64 and
32 bit.
What can i do?
RE: EPICS build problem Freddie Akeroyd - STFC UKRI via Tech-talk
EPICS build problem Federico Galdenzi via Tech-talk
Re: EPICS build problem Federico Galdenzi via Tech-talk
Prev: RE: Problem with Sequencer Dudley, David via Tech-talk
Next: RE: EPICS build problem Freddie Akeroyd - STFC UKRI via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: RE: EPICS build problem Freddie Akeroyd - STFC UKRI via Tech-talk
