1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: RE: Problem with Sequencer
From: "Dudley, David via Tech-talk" <[email protected]>
Date: Wed, 16 Apr 2025 13:07:01 +0000
OK< discovered my error.
Amazing what one line in the Makefile can cause.
I had forgotten to command the creation of the support library.
David
From: Tech-talk <[email protected]> On Behalf Of Dudley, David via Tech-talk
Sent: Tuesday, April 15, 2025 1:42 PM
To: [email protected]
Subject: Problem with Sequencer
[EXTERNAL] This email originated from outside of FRIB
OK,
Now I’m back to the error that started this whole thing.
I have a *.stt file to be added to an IOC.
The file will comple and operate correctly as a program …. Sort of-
Now, is where the fun begins-
I want to add the program into the IOC.
Went through the stuff on getting it included, and setup to compile in.
It compiles correctly, but when the makefile gets down to linking………..
It says it can’t find the “registrar” function, I think…
Here is the make log  I’m also including the sequencer program, the Makefile, and the .dbd file as well.
Help would be appreciated.
Later-
David
Problem with Sequencer Dudley, David via Tech-talk
Prev: RE: EPICS build problem Freddie Akeroyd - STFC UKRI via Tech-talk
Next: Re: EPICS build problem Federico Galdenzi via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: RE: Problem with Sequencer Mark Rivers via Tech-talk
Next: CaLab - strange replies Dariush Hampai via Tech-talk
