1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: RE: Writing array data in an AreaDetector application
To: Iain Marcuson <[email protected]>, Ralph Lange <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Thu, 1 May 2025 18:13:22 +0000
I should add that if you use the first choice in my previous message then you also need to add asynFloat64ArrayMask to the “interruptMask” argument to the base class.  That is the argument right after the one you just modified.  That tells asynPortDriver that you want to enable interrupt callbacks on the asynFloat64 interface.
Sent: Thursday, May 1, 2025 1:10 PM
To: Iain Marcuson <[email protected]>; Ralph Lange <[email protected]>; EPICS Tech Talk <[email protected]>
  • As a related question, what records would I use if I wanted to have a waveform of readback values?  I do not see an array equivalent to setDoubleParam().
You have 2 choices:
  • If you want the driver to decide when the waveform input record should processes then you set SCAN=I/O Intr and your driver calls doCallbacksFloat64Array().
  • If you want the record to be processed periodically or otherwise from the outside then you implement readFloat64Array() which will be called when you process the record.
Sent: Thursday, May 1, 2025 1:05 PM
To: Mark Rivers <[email protected]>; Ralph Lange <[email protected]>; EPICS Tech Talk <[email protected]>
That was indeed the problem; thank you.  As a related question, what records would I use if I wanted to have a waveform of readback values?  I do not see an array equivalent to setDoubleParam().
Iain.
Sent: Thursday, May 01, 2025 1:56 PM
The problem is in your constructor.  When you call the base class constructor you give it a bit mask of what interfaces to implement.  You need to add asynFloat64Array to that.
Here is an example of a driver that does that:
https://github.com/areaDetector/NDDriverStdArrays/blob/e21b2f2f74feb217a0e67ba8f8fc4bfd7efe58e0/NDDriverStdArraysApp/src/NDDriverStdArrays.cpp#L49
From: Tech-talk <[email protected]> On Behalf Of Iain Marcuson via Tech-talk
Sent: Thursday, May 1, 2025 12:48 PM
To: Ralph Lange <[email protected]>; EPICS Tech Talk <[email protected]>
I do see a message I had overlooked before:
devAsynFloat64Array::initCommon, 13PIL1:cam1:PADDigiCorr find asynFloat64Array interface failed
I think I have the function names and signatures right, from looking at file asynPortDriver.h, if that is what you mean.
From: Tech-talk <[email protected]> On Behalf Of Ralph Lange via Tech-talk
Sent: Thursday, May 01, 2025 12:54 PM
To: EPICS Tech Talk <[email protected]>
Subject: Re: Writing array data in an AreaDetector application
Hi Iain,
Looking at the documentation [1] and your record, it all seems fine.
The waveform record type was created as an input - that's why the configuration field is INP. Unrelated to your problem.
It's most probably a code issue. Is your additional method properly declared in the class declaration, so that the default implementation of the method is overridden?
Cheers,
~Ralph
Click here to report this email as spam.
This message has been scanned for malware by Forcepoint. www.forcepoint.com
Writing array data in an AreaDetector application Iain Marcuson via Tech-talk
Re: Writing array data in an AreaDetector application Ralph Lange via Tech-talk
RE: Writing array data in an AreaDetector application Iain Marcuson via Tech-talk
RE: Writing array data in an AreaDetector application Mark Rivers via Tech-talk
Prev: RE: Writing array data in an AreaDetector application Mark Rivers via Tech-talk
Next: EPICS app, Db Makefile, rule for python-generated Db file Andrea Celentano via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
