Subject: |
autosave: pass-0 and pass-1 with a custom device support |
Andrea Celentano via Tech-talk <[email protected]> |
To: |
[email protected] |
Date: |
Wed, 28 May 2025 13:49:02 +0200 |
Dear colleagues,
I have an analog output record, with a custom device support.
The record reads:
record(ao,
"$(HOST):C0:IOB:set")
field(DRVH, "31")
field(DRVL, "0")
field(DTYP, "WAVEBOARD_ZYNQ")
field(FLNK, "$(HOST):C0:FanOut")
field(OUT, "@writeIOB_0")
info(autosaveFields, "VAL")
The init_record function is reported below. I am not modifying
here in any way the prec->val.
static long
init_record_ao(void *arg) {
aoRecord *prec = (aoRecord*) (arg);
printf("init record_ao %s start (eventual value: %f)\n",
prec->name,prec->val);
std::string str;
if (!AxiMM.GetInitialized()) {
printf("AXI controller not initialized! Exiting...\n");
return -1;
str = std::string(prec->out.value.constantStr);
struct privRecordData *priv = new privRecordData;
/*A.C. here we need to decode the string "str", that should
be: COMMAND_CHANNEL - or just COMMAND*/
priv->raw=str;
getCommandChannel(str, priv->command, priv->channel);
prec->dpvt = priv;
return 0;
I am experimenting with the autosave module. The value to be
retrieved is 13.
If I set VAL to be retreived at pass-1 (AFTER record
initialization), I see in the output:
init
record_ao waveboard201:C0:IOB:set start (eventual value:
0.000000)
while if I set it at pass-0, I see:
init
13.000000)
This is expected, and I understand this: pass-0 means before
record initialization, hence the value is available to
init_record_ao.
However, if I set VAL to be retrieved at pass-0, the value of
this PV, at the end of record initialization, as obtained from
caget is 0. I do not understand this - is it there a default
initialization step occurring after my init_record_ao function is
called, but before the instant at which pass-1 variables are
retrieved?
Bests,
Andrea
Communicating with Bechoff I/O through EPICS Sibylle Ducroizé via Tech-talk
Re: Communicating with Bechoff I/O through EPICS Jörn Dreyer via Tech-talk
<2025>
2026
Re: Communicating with Bechoff I/O through EPICS Jure Varlec via Tech-talk
Epics Driver for Hamamatsu X-ray Source Dariush Hampai via Tech-talk
<2025>
2026
