1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Re: Communicating with Bechoff I/O through EPICS
From: Jure Varlec via Tech-talk <[email protected]>
To: [email protected]
Date: Wed, 28 May 2025 15:37:24 +0200
Hello Sibylle,
Given that you were trying to use EtherCAT to communicate with the PLC, I think some additional explanation might be helpful. EtherCAT is Beckhoff's realtime protocol, and needs special hardware and software like etherlab. Which is why it can be fiddly. ADS, on the other hand, is not a realtime protocol. Inside the PLC, it serves as a boundary between realtime and non-realtime worlds. That's why it is much simpler to use and requires nothing special on the IOC side. Unless you want to do realtime control within the EPICS IOC, I recommend you go with ADS.
Best,
Jure
On 5/28/25 15:30, Žiga Oven via Tech-talk wrote:
Caution: This email originated from outside of Cosylab.
Hi Sibylle,
Regarding your questions about the communicating with Beckhoff I/O, Cosylab has developed an EPICS device support for Beckhoff ADS protocol.
You can find a presentation about it here [1], sources can be downloaded from the GitHub [2] and documentation can be found here [3].
If you have any other questions, don’t hesitate to ask.
Best regards,
Žiga Oven
[1]  https://indico.global/event/7048/contributions/66597/
[2] https://github.com/cosylab/adsDriver
[3] https://epics.cosylab.com/documentation/adsDriver/
From: Tech-talk <[email protected]> On Behalf Of Sibylle Ducroizé via Tech-talk
Sent: Wednesday, May 28, 2025 13:24
Subject: Communicating with Bechoff I/O through EPICS
Hello,
I have just started working on an update of the control system software for an accelerator.
I am still trying out different configurations and learning how to use EPICS. I followed the tutorial of the EPICS documentation so I know basic information about IOCs and have common support modules installed (asyn, calc, streamDevice,...)
I would like to communicate with Beckhoff I/O terminals, both as a way to learn EPICS and to try out configurations for the final project. I have tried following this advice from a previous tech-talk question from 2018.
So far I have installed etherlab's ethercat master and I've tried installing PSI's ecmc which needs e3 to build. Unfortunately, e3-build fails to install epics base so I didn't get very far...I am on ubuntu which might be the problem.
My questions :
1. Are there maintained EPICS drivers for communicating with Beckhoff I/O ?
    1.a. If so, is ecmc a good option ? (As it depends on e3, meant to run on centOS which is obsolete)
    1.b. Are there other similar alternatives ?
2. Should I basically write my own drivers ?
    1.a. An advice / general approach for me to follow as I am new to EPICS ?
Sibylle
Communicating with Bechoff I/O through EPICS Sibylle Ducroizé via Tech-talk
RE: Communicating with Bechoff I/O through EPICS Žiga Oven via Tech-talk
Prev: RE: Communicating with Bechoff I/O through EPICS Žiga Oven via Tech-talk
Next: Re: Communicating with Bechoff I/O through EPICS Timo Korhonen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Next: autosave: pass-0 and pass-1 with a custom device support Andrea Celentano via Tech-talk
