Hi Lesley,
Already at least 2 solutions for ADS EPICS drivers exist in the community:
https://github.com/epics-modules/twincat-ads/
https://epics.cosylab.com/documentation/adsDriver/
Why not using those ones ?
At minimum it can maybe be used as an example if you want to keep going on your solution
J
Cheers
Alexis
CEA/Irfu/DIS
I developed a Beckhoff ADS IOC application using this ADS driver (https://github.com/Beckhoff/ADS).
After the IOC runs for some time, the following issue occurs: "WARNING dbEvent possible queue stall". Concurrently, the PVs in the OPI will disconnect and then automatically reconnect after a short period.
Here's a code snippet for reading data from the PLC using the ADS driver:
struct WaterStatusStruct adsReadWaterStatusValue(){
WaterStatusStruct CWStatusVar;
const std::string handleName = "GVL_RFQ.water_status";
//Use mutex locks to protect access
std::lock_guard<std::mutex> lock(plcMutex);
const long handleStatus = AdsSyncReadWriteReqEx2(port,
printf("adsReadWaterStatusValue Create handle failed with: %8lX\n", handleStatus);
//out << "Create handle for '" << handleName << "' failed with: 0x" << std::hex << handleStatus << '\n';
const long status2 = AdsSyncReadReqEx2(port,
printf("adsReadWaterStatusValue ADS read failed with: %8lX\n", status2);
//out << "ADS read failed with: " << std::dec << status << '\n';
const long releaseHandle = AdsSyncWriteReqEx(port, &plcAddress, ADSIGRP_SYM_RELEASEHND, 0, sizeof(handle), &handle);
//out << "Release handle 0x" << std::hex << handle << "' failed with: 0x" << releaseHandle << '\n';
printf("adsReadWaterStatusValue Release handle failed\n");
What can I do to fix this?Thank you for your time.
- Beckhoff ADS to EPICS IOC Lesley via Tech-talk
How to update combo box items with subset of PV items Alessandra Palazzo via Tech-talk
Warning messages in the Archiver Appliance logs LONG FENG via Tech-talk
<2025>
2026
PVXS programmatically create pvalinks Dave Bracey via Tech-talk
<2025>
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
