1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025
Subject: Warning messages in the Archiver Appliance logs
From: LONG FENG via Tech-talk <tech-talk at aps.anl.gov>
To: tech-talk at aps.anl.gov
Date: Sun, 8 Jun 2025 23:07:35 +0800
Hi all,
When using the install script to set up Archiver Appliance, I was able to successfully access http://flon-sqm2270:17665/mgmt/, and I can store and view historical data without issues.
However, I’m unable to access the following module URLs:
What could be causing this issue? Will it affect subsequent operations? What steps should I take to ensure these pages open correctly?
I'm using the following versions for each module:
  • OS:Ubuntu 22.04.4 LTS,
  • java: openjdk 21.0.7
  • tomcat:apache-tomcat-9.0.105
  • archiver appliance:archappl_v2.0.10
Additionally, I checked the retrieval/logs/catalina.err file, and its contents are as follows:
(The contents of other catalina.err files are similar.).
Jun 08, 2025 10:32:40 PM org.apache.catalina.startup.VersionLoggerListener log
INFO: Server version name:   Apache Tomcat/9.0.105
INFO: Server built:          May 7 2025 18:36:02 UTC
INFO: Server version number: 9.0.105.0
INFO: OS Name:               Linux
INFO: OS Version:            6.8.0-60-generic
INFO: Architecture:          amd64
INFO: Java Home:             /usr/lib/jvm/java-21-openjdk-amd64
INFO: JVM Version:           21.0.7+6-Ubuntu-0ubuntu122.04
INFO: JVM Vendor:            Ubuntu
INFO: CATALINA_BASE:         /ics/tools/archiver-appliance/tomcat/retrieval
INFO: CATALINA_HOME:         /ics/tools/archiver-appliance/tomcat/apache-tomcat-9.0.105
INFO: Command line argument: -Dcatalina.base=/ics/tools/archiver-appliance/tomcat/retrieval
INFO: Command line argument: -Dcatalina.home=/ics/tools/archiver-appliance/tomcat/apache-tomcat-9.0.105
INFO: Command line argument: -Dcommons.daemon.process.id=3717
INFO: Command line argument: -Dcommons.daemon.process.parent=3716
INFO: Command line argument: -Dcommons.daemon.version=1.4.1
INFO: Command line argument: abort
Jun 08, 2025 10:32:40 PM org.apache.catalina.core.AprLifecycleListener lifecycleEvent
INFO: The Apache Tomcat Native library which allows using OpenSSL was not found on the java.library.path: [/ics/tools/archiver-appliance/tomcat/retrieval/webapps/mgmt/WEB-INF/lib/native/linux-x86_64:/ics/tools/archiver-appliance/tomcat/etl/webapps/mgmt/WEB-INF/lib/native/linux-x86_64:/ics/tools/archiver-appliance/tomcat/engine/webapps/mgmt/WEB-INF/lib/native/linux-x86_64:/ics/tools/archiver-appliance/tomcat/mgmt/webapps/mgmt/WEB-INF/lib/native/linux-x86_64::/usr/lib/jvm/java-21-openjdk-amd64/lib/server:/usr/lib/jvm/java-21-openjdk-amd64/lib:/usr/java/packages/lib:/usr/lib/x86_64-linux-gnu/jni:/lib/x86_64-linux-gnu:/usr/lib/x86_64-linux-gnu:/usr/lib/jni:/lib:/usr/lib]
Jun 08, 2025 10:32:42 PM org.apache.coyote.AbstractProtocol init
INFO: Initializing ProtocolHandler ["http-nio-17668"]
Jun 08, 2025 10:32:42 PM org.apache.catalina.startup.Catalina load
INFO: Server initialization in [2050] milliseconds
Jun 08, 2025 10:32:42 PM org.apache.catalina.core.StandardService startInternal
INFO: Starting service [Catalina]
Jun 08, 2025 10:32:42 PM org.apache.catalina.core.StandardEngine startInternal
INFO: Starting Servlet engine: [Apache Tomcat/9.0.105]
Jun 08, 2025 10:32:42 PM org.apache.catalina.startup.HostConfig deployWAR
INFO: Deploying web application archive [/ics/tools/archiver-appliance/tomcat/retrieval/webapps/retrieval.war]
Jun 08, 2025 10:32:49 PM org.apache.jasper.servlet.TldScanner scanJars
INFO: At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time.
Jun 08, 2025 10:32:51 PM org.apache.catalina.startup.HostConfig deployWAR
INFO: Deployment of web application archive [/ics/tools/archiver-appliance/tomcat/retrieval/webapps/retrieval.war] has finished in [9,429] ms
Jun 08, 2025 10:32:51 PM org.apache.catalina.startup.HostConfig deployDirectory
INFO: Deploying web application directory [/ics/tools/archiver-appliance/tomcat/retrieval/webapps/docs]
Jun 08, 2025 10:32:52 PM org.apache.jasper.servlet.TldScanner scanJars
Jun 08, 2025 10:32:52 PM org.apache.catalina.startup.HostConfig deployDirectory
INFO: Deployment of web application directory [/ics/tools/archiver-appliance/tomcat/retrieval/webapps/docs] has finished in [534] ms
INFO: Deploying web application directory [/ics/tools/archiver-appliance/tomcat/retrieval/webapps/examples]
Jun 08, 2025 10:32:53 PM org.apache.jasper.servlet.TldScanner scanJars
Jun 08, 2025 10:32:53 PM org.apache.catalina.core.ApplicationContext log
INFO: ContextListener: contextInitialized()
INFO: SessionListener: contextInitialized()
INFO: ContextListener: attributeAdded('StockTicker', 'async.Stockticker@589b0049')
Jun 08, 2025 10:32:53 PM org.apache.catalina.startup.HostConfig deployDirectory
INFO: Deployment of web application directory [/ics/tools/archiver-appliance/tomcat/retrieval/webapps/examples] has finished in [1,082] ms
INFO: Deploying web application directory [/ics/tools/archiver-appliance/tomcat/retrieval/webapps/manager]
INFO: Deployment of web application directory [/ics/tools/archiver-appliance/tomcat/retrieval/webapps/manager] has finished in [461] ms
INFO: Deploying web application directory [/ics/tools/archiver-appliance/tomcat/retrieval/webapps/host-manager]
Jun 08, 2025 10:32:54 PM org.apache.jasper.servlet.TldScanner scanJars
Jun 08, 2025 10:32:54 PM org.apache.catalina.startup.HostConfig deployDirectory
INFO: Deployment of web application directory [/ics/tools/archiver-appliance/tomcat/retrieval/webapps/host-manager] has finished in [290] ms
INFO: Deploying web application directory [/ics/tools/archiver-appliance/tomcat/retrieval/webapps/ROOT]
INFO: Deployment of web application directory [/ics/tools/archiver-appliance/tomcat/retrieval/webapps/ROOT] has finished in [243] ms
Jun 08, 2025 10:32:54 PM org.apache.coyote.AbstractProtocol start
INFO: Starting ProtocolHandler ["http-nio-17668"]
Jun 08, 2025 10:32:54 PM org.apache.catalina.startup.Catalina start
INFO: Server startup in [12336] milliseconds
Jun 08, 2025 10:33:21 PM com.hazelcast.internal.config.AbstractConfigLocator
INFO: Loading 'hazelcast-client-default.xml' from the classpath.
Jun 08, 2025 10:33:21 PM com.hazelcast.config.AbstractXmlConfigHelper
WARNING: Name of the hazelcast schema location[http://www.hazelcast.com/schema/client-config/hazelcast-client-config-5.3.xsd] is incorrect, using default
Feng
Prev: RE: Beckhoff ADS to EPICS IOC GAGET Alexis via Tech-talk
Next: Re: Warning messages in the Archiver Appliance logs Shankar, Murali via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025
Prev: Re: How to update combo box items with subset of PV items Michael Davidsaver via Tech-talk
ANJ, 09 Jun 2025 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
