1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: RE: AreaDetector Driver for device that sends back 3 synchronized frames
From: "Pearson, Matthew via Tech-talk" <[email protected]>
To: "Daykin, Evan" <[email protected]>, EPICS tech-talk <[email protected]>
Date: Mon, 9 Jun 2025 20:24:52 +0000
Hi Evan,
I assume you’d be handling/saving each array separately? If so, one way to handle this is to use different Asyn addresses for the output NDArray callbacks. So you would have a single driver that gets the 3 images, and then output the RGB image NDArray on addr=0, the IR image NDArray on addr=1 and the depth image NDArrray on addr=2. Each NDArray type would use a different dims[] size and datatype. Then you can have 3 separate plugin chains to handle the NDArray processing, with the 1st plugin in each chain listening to a different Asyn address.
Cheers,
Matt
From: Tech-talk <[email protected]> On Behalf Of Daykin, Evan via Tech-talk
Sent: Monday, June 9, 2025 4:08 PM
To: EPICS tech-talk <[email protected]>
Subject: [EXTERNAL] AreaDetector Driver for device that sends back 3 synchronized frames
Hi, I am looking to create an AD Driver for Microsoft Kinect v2. The open-source device driver libfreenect2, uses a Synchronized multi-frame listener that awaits the receipt of an RGB image (1920x1080x3 int), an IR image (512x424 float), and
I am looking to create an AD Driver for Microsoft Kinect v2. The open-source device driver libfreenect2, uses a Synchronized multi-frame listener that awaits the receipt of an RGB image (1920x1080x3 int), an IR image (512x424 float), and a depth image (512x424 float). I would like suggestions for the best way to handle this. My first thought is to have three separate ‘sub’-detector drivers and dole out each frame from the main driver according to its type. Are there any existing device support modules that do something similar?
Thanks!
-Evan
RE: AreaDetector Driver for device that sends back 3 synchronized frames Mark Rivers via Tech-talk
AreaDetector Driver for device that sends back 3 synchronized frames Daykin, Evan via Tech-talk
Prev: AreaDetector Driver for device that sends back 3 synchronized frames Daykin, Evan via Tech-talk
Next: RE: AreaDetector Driver for device that sends back 3 synchronized frames Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
