1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025
Subject: Re: EPICS support for device to monitor Digital I/O
From: Jörn Dreyer via Tech-talk <tech-talk at aps.anl.gov>
To: tech-talk at aps.anl.gov
Date: Fri, 20 Jun 2025 09:11:03 +0200
Dear Pra,
I took a quick look at the hardware and have some points to remark:
1) you talk about TTL signals which are defined to be 0 - 5V levels. This board can only handle signal up to 3.3V.
Keep that in mind.
2) If you connect this board to a Linux PC and load the correct driver the GPIO part should show up as /dev/gpiochipX.
I am not aware of a generic driver in EPICS that can handle individual GPIO lines. That would probably need to be written.
3) For such a purpose I used a Texas Instruments DAQ card which has EPICS support, but is quite expensive.
Another option would be a Measurement Computing digital IO card supported by the comedi driver in the Linux kernel. But this requires also
some coding in EPICS. I used that to trigger a camera by software when an TTL input signal fired an input on the card.
Hope that helps,
Jörn
Am Freitag, 20. Juni 2025, 08:31:06 Mitteleuropäische Sommerzeit schrieb P B via Tech-talk:
> Hello,
> I am relatively new to EPICS. I am trying to look for an option to monitor
> a single TTL signal on a Linux PC running EPICS.
> Using something like a DAQ is overkill. Ideally, I am thinking of something
> like the FT232H chip
> <https://urldefense.us/v3/__https://www.adafruit.com/product/2264?srsltid=AfmBOopZMcypFKlrUFJei4oyVXH63L2NtuB1rB5JlEEYTbAG-Ag7uO-Y__;!!G_uCfscf7eWS!d4RnFD_jM2oa4yAdin11b0BgqS9IAnXW4ytLQizY2Hb9tFQRwhJLF7tyPlQ6HDjy34L0QnptkYMgIz883SnZbUE$ >.
> Is there support for something equivalent to this? Or any suggestions on a
> quick and easy way to achieve this within EPICS?
> Thanks.
> Pra
EPICS support for device to monitor Digital I/O P B via Tech-talk
Prev: EPICS support for device to monitor Digital I/O P B via Tech-talk
Next: Re: EPICS support for device to monitor Digital I/O Eric Norum via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025
ANJ, 20 Jun 2025 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
