1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025
Subject: Re: EPICS support for device to monitor Digital I/O
From: Gerrit Kühn via Tech-talk <tech-talk at aps.anl.gov>
To: tech-talk at aps.anl.gov
Date: Fri, 20 Jun 2025 12:32:26 +0200
Am Thu, 19 Jun 2025 23:31:06 -0700
schrieb P B via Tech-talk <tech-talk at aps.anl.gov>:
Hello,
> Is there support for something equivalent to this? Or any suggestions on
> a quick and easy way to achieve this within EPICS?
We have been using these deices in the past:
https://taskit.de/en/products/embedded-products/converter?p=rs232-adc-16-im-erw-temperaturbereich
The serial protocol they speak can be processed with streamdevice.
Obviously, you need a serial port to connect this. Their maximum voltage
supported for DIO is 3.3V (I think), but afaicr they are 5V tolerant (or
you need to add a voltage divider, optocoupler or similar).
HTH
cu
  Gerrit
Attachment: smime.p7s
Description: S/MIME cryptographic signature
EPICS support for device to monitor Digital I/O P B via Tech-talk
Prev: Re: EPICS support for device to monitor Digital I/O Eric Norum via Tech-talk
Next: Re: EPICS support for device to monitor Digital I/O Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025
ANJ, 20 Jun 2025 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
