1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: Help operating ADHamamatsuDCAM IOC
From: Marco Filho via Tech-talk <[email protected]>
To: Mark Rivers <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Fri, 11 Jul 2025 07:40:09 +0000
Hi, we changed the camera to another server and managed to get images with both the new and old EPICS module, it worked fine as long as the data type was either int16 uint16.
So it's probably just the driver or api installation.
Thanks for the help!
tbl-det-ipc-ioc-05-1375977 > dbpf 13HAMA1:cam1:TriggerMode 0
DBF_STRING:         "Internal"
tbl-det-ipc-ioc-05-1375977 > dbpf 13HAMA1:cam1:ImageMode 0
DBF_STRING:         "Single"
tbl-det-ipc-ioc-05-1375977 > dbpf 13HAMA1:cam1:Acquire 1
Start Capture pressed
DBF_STRING:         "Acquire"
exposure time 1.000005
minX: 0.000000
sizeX: 2048.000000
minY: 0.000000
sizeY: 2048.000000
binX: 1.000000
Start Capture
Stop Capture
tbl-det-ipc-ioc-05-1375977 > dbgf 13HAMA1:image1:ArrayData
DBF_UCHAR[800]:     94 = 0x5e 101 = 0x65          94 = 0x5e 99 = 0x63 94 = 0x5e
101 = 0x65          100 = 0x64          104 = 0x68          101 = 0x65
Sent: Thursday, July 10, 2025 15:26
To: Marco Filho <[email protected]>; EPICS Tech Talk <[email protected]>
Hi Marco,
I agree, it looks like the SDK is communicating OK and sending frames, but all pixels are 0.
Sent: Thursday, July 10, 2025 4:42 AM
To: Mark Rivers <[email protected]>; EPICS Tech Talk <[email protected]>
Hi, Mark, thanks for the help.
I will attach the images as asked but after running it both with the other ADHamamatsu EPICS module that we had here and with the manufacturer's software and getting the same result, we are suspecting some problems in the hardware or firebird card, not anything wrong with the new EPICS module.
The array counter increases for the plugins, but the statistics doesn't seem to point to any pixel being actually activated.
I sent a message to the manufacturer and will report if I manage to advance.
Sent: Wednesday, July 9, 2025 18:14
Subject: RE: Help operating ADHamamatsuDCAM IOC
Hi Marco,
I suggest setting the region size to the full camera size, 2048, 2048.  Also change the datatype to Int16.
Please send screenshots of the following when the camera is acquiring:
  • Main ADHamamatsuDCAM screen
  • commonPlugins screen showing all plugins
  • Enable the Stats5 plugin, set its array source to HAMA1 and send a screen of that plugin.
Are you using the CameraLink or USB interface?
From: Tech-talk <[email protected]> On Behalf Of Marco Filho via Tech-talk
Sent: Wednesday, July 9, 2025 6:37 AM
To: EPICS Tech Talk <[email protected]>
Subject: Help operating ADHamamatsuDCAM IOC
Good afternoon, all
We are trying out the latest version of the ADHamamatsuDCAM EPICS module (https://github.com/areaDetector/ADHamamatsuDCAM) to operate a C13440 model.
Everything seems to work out mostly fine, except we get an empty image no matter how we configure the camera.
For now, I tried running the following IOC:
epicsEnvSet("PREFIX", "13HAMA1:")
epicsEnvSet("PORT",   "HAMA1")
epicsEnvSet("QSIZE",  "20")
epicsEnvSet("XSIZE",  "1024")
epicsEnvSet("YSIZE",  "1024")
epicsEnvSet("NCHANS", "2048")
epicsEnvSet("CBUFFS", "500")
epicsEnvSet("MAX_THREADS", "8")
epicsEnvSet("EPICS_DB_INCLUDE_PATH", "$(ADCORE)/db")
# Create a hamamatsu driver
# hamamatsuConfig(const char *portName, int camIndex, int maxBuffers, int maxMemory, int priority, int stackSize)
hamamatsuConfig("$(PORT)", 0, 0, 0, 99)
# To have the rate calculation use a non-zero smoothing factor use the following line
dbLoadRecords("$(adhamamatsudcam_DB)/hamamatsu.template","P=$(PREFIX),R=cam1:,PORT=$(PORT),ADDR=0,TIMEOUT=1")
NDStdArraysConfigure("Image1", 20, 0, "$(PORT)", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDStdArrays.template", "P=$(PREFIX),R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT),TYPE=Int8,FTVL=UCHAR,NELEMENTS=12000000")
iocInit
dbpf 13HAMA1:image1:EnableCallbacks 1
dbpf 13HAMA1:cam1:HamaRegionReset 1
dbpf 13HAMA1:cam1:AcquirePeriod 1.1
dbpf 13HAMA1:cam1:SizeX 1024
dbpf 13HAMA1:cam1:SizeY 1024
After that, clicking on acquire start I can see the number of images incrementing both on the driver and on the image plugin, but the image is always empty:
DBF_UCHAR[800]:     0 = 0x0   0 = 0x0   0 = 0x0   0 = 0x0   0 = 0x0   0 = 0x0
0 = 0x0   0 = 0x0   0 = 0x0   0 = 0x0   0 = 0x0   0 = 0x0   0 = 0x0   0 = 0x0 (...)
Does anyone have experience with this camera and knows if we are misconfiguring some parameter?
I attach a picture of the operation screen after acquiring  if that is of any help. I noticed the region size X and Y start as 1, so I guessed that putting some bigger value on that would be needed to make the image work...
Thanks in advance for any help,
Marco
Help operating ADHamamatsuDCAM IOC Marco Filho via Tech-talk
RE: Help operating ADHamamatsuDCAM IOC Mark Rivers via Tech-talk
Re: Help operating ADHamamatsuDCAM IOC Marco Filho via Tech-talk
Re: Help operating ADHamamatsuDCAM IOC Mark Rivers via Tech-talk
Prev: Re: [EXTERNAL] Re: using PI C-863 Mercury motor controller with linux Peterson, Kevin M. via Tech-talk
Next: Re: Issues in MCA module with XFlash detector Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: Re: Help operating ADHamamatsuDCAM IOC Mark Rivers via Tech-talk
Next: EPNix 25.05 released NICOLE Rémi via Tech-talk
