On 7/17/25 14:57, Johnson, Andrew N.
via Tech-talk wrote:
Hi Scott,
I suggest you
look at the latest dbPutFieldLink() routine in the
modules/database/src/ioc/db/dbAccess.c file, which does
exactly this including taking and releasing the necessary
locks. It gets called by dbPutField() when a client writes to
any INP/OUT/FWD link
field.
The
global lock as been removed.
I suppose the same effect could be achieved by calling
dbLockerAlloc() with an array including every record in the IOC.
https://github.com/epics-base/epics-base/blob/f29137b98532233c6154bf88defd5f1d203962e9/modules/database/src/ioc/db/dbLock.h#L56-L65
The
new API
allows
locks to be taken on
multiple
records at once even if
they currently belong to different lock-sets, allowing
other threads to continue processing records while this thread
combines or splits existing lock-sets as needed by the change
requested. The locking changes were merged into 3.16 back in
2015 from
this launchpad merge request, but there have likely been
additional code changes since then. There is documentation to be
found in section 5.4 of the
3.16 version of the appDevGuide; those changes were added
in
this appDevGuide merge but the details haven’t obviously
been carried forward into the new documents on the
docs.epics-controls.org website.
HTH,
- Andrew
Complexity comes for free,
Simplicity you have to work for.
I’m attempting to update the
redundant IOC software to build with EPICS 7. The API for
record locking has been changed completely. One component
of the software needs to have the ability to change database
links. With EPICS 3.15 this means calling a global lock
function and some Add/remove link functions as well as
dbLockSetSplit and dbLockSetMerge. Many of these no longer
exist, the new interface to lock a record or multiple
records is much simpler, but what functions need to be
called when modifying database links? Is there any
documentation or examples I can look at?
Are the split and merge calls
no longer needed? Do I need to lock and unlock one or both
records before adding or removing links, or do the epics 7
versions of dbAddLink and dbRemoveLink take care of the
locking and lockset management?
- documentation for new epics 7 dbLock usage and Redundant IOC software Baily, Scott A via Tech-talk
- Re: documentation for new epics 7 dbLock usage and Redundant IOC software Johnson, Andrew N. via Tech-talk
Using AD plugins on asyn port Abdalla Ahmad via Tech-talk
<2025>
2026
Re: documentation for new epics 7 dbLock usage and Redundant IOC software Timo Korhonen via Tech-talk
<2025>
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
