1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Re: documentation for new epics 7 dbLock usage and Redundant IOC software
From: Timo Korhonen via Tech-talk <[email protected]>
To: "Johnson, Andrew N." <[email protected]>, "Baily, Scott A" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 11 Aug 2025 13:23:29 +0000
The changes that Andrew mentions below have in fact been carried to docs.epics-controls site; however, the corresponding section has not yet been included in the navigation as this is a part of a larger set of modifications that is still WIP.
In the meantime, the updated text is available here: https://docs.epics-controls.org/en/latest/appdevguide/lockScanProcess.html
I am slowly adding and updating the sections from the Application Developer’s Guide to the docs site. Unfortunately, my time available for this work is somewhat limited.
Cheers,
Timo
From: Tech-talk <[email protected]> on behalf of "Johnson, Andrew N. via Tech-talk" <[email protected]>
Reply to: "Johnson, Andrew N." <[email protected]>
Date: Thursday, 17 July 2025 at 21:58
To: "Baily, Scott A" <[email protected]>, "[email protected]" <[email protected]>
Hi Scott,
I suggest you look at the latest dbPutFieldLink() routine in the modules/database/src/ioc/db/dbAccess.c file, which does exactly this including taking and releasing the necessary locks. It gets called by dbPutField() when a client writes to any INP/OUT/FWD link field.
The global lock as been removed. The new API allows locks to be taken on multiple records at once even if they currently belong to different lock-sets, allowing other threads to continue processing records while this thread combines or splits existing lock-sets as needed by the change requested. The locking changes were merged into 3.16 back in 2015 from this launchpad merge request, but there have likely been additional code changes since then. There is documentation to be found in section 5.4 of the 3.16 version of the appDevGuide; those changes were added in this appDevGuide merge but the details haven’t obviously been carried forward into the new documents on the docs.epics-controls.org website.
HTH,
- Andrew
Complexity comes for free, Simplicity you have to work for.
On 7/17/25, 1:32PM, "Tech-talk" <[email protected]> wrote:
I’m attempting to update the redundant IOC software to build with EPICS 7. The API for record locking has been changed completely.  One component of the software needs to have the ability to change database links. With EPICS 3.15 this means calling a global lock function and some Add/remove link functions as well as dbLockSetSplit and dbLockSetMerge.  Many of these no longer exist, the new interface to lock a record or multiple records is much simpler, but what functions need to be called when modifying database links? Is there any documentation or examples I can look at?
Are the split and merge calls no longer needed?  Do I need to lock and unlock one or both records before adding or removing links, or do the epics 7 versions of dbAddLink and dbRemoveLink take care of the locking and lockset management?
documentation for new epics 7 dbLock usage and Redundant IOC software Baily, Scott A via Tech-talk
Re: documentation for new epics 7 dbLock usage and Redundant IOC software Johnson, Andrew N. via Tech-talk
Prev: Re: CS-Studio Phoebus Deployment-Only Version Blomley, Edmund (IBPT) via Tech-talk
Next: Galil IOC GalilAddCode Command Parameters Jonathan Hai via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Prev: Re: documentation for new epics 7 dbLock usage and Redundant IOC software Michael Davidsaver via Tech-talk
Next: Using AD plugins on asyn port Abdalla Ahmad via Tech-talk
