1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: Help with bumpless IOC reboot, record linking and initialization concepts
From: Maren Purves via Tech-talk <[email protected]>
To: Michael Davidsaver <[email protected]>
Date: Thu, 18 Sep 2025 17:31:26 -1000
We often use dbpf for temporary changes of alarm thresholds for
instrument temperatures and pressures.
The db contains what they should be if everything was working properly.
I  don't see how that is bad coding.
Maren
On Thu, Sep 18, 2025 at 7:10 AM Michael Davidsaver via Tech-talk
<[email protected]> wrote:
> On 9/18/25 07:54, Johnson, Andrew N. via Tech-talk wrote:
> Many of our IOCs use one or more “dbpf” commands in their startup script (sometimes after an epicsThreadSleep) ...
> Nooooooo!
> Finding a bunch of random, rarely commented, dbpf calls in an IOC start script is to me a bad code smell.  The same goes for sleeps, only more so.  Please investigate 'field(PINI, "RUNNING")', or look at other ways to actually synchronize startup.
> ... it should even be possible to handle disconnections and later reconnections for links to remote IOCs if you want to do that.
> imo. any well written driver for an ethernet attached device __needs__ to do this.
> Generally, I have found that the more effective way to coordinate connect/disconnect is at the driver level.  Generally with a special device support to drive on-connect processing.
Re: Help with bumpless IOC reboot, record linking and initialization concepts Marco Filho via Tech-talk
Re: Help with bumpless IOC reboot, record linking and initialization concepts Timo Korhonen via Tech-talk
Re: Help with bumpless IOC reboot, record linking and initialization concepts Ralph Lange via Tech-talk
Re: Help with bumpless IOC reboot, record linking and initialization concepts Johnson, Andrew N. via Tech-talk
Re: Help with bumpless IOC reboot, record linking and initialization concepts Michael Davidsaver via Tech-talk
Prev: Re: Problem with drvAsynIPPortConfigure Ralph Lange via Tech-talk
Next: Re: Help with bumpless IOC reboot, record linking and initialization concepts Marco Filho via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: Re: Help with bumpless IOC reboot, record linking and initialization concepts Michael Davidsaver via Tech-talk
