Hi Maren,
I guess there are use cases where dbpf is a good solution. However, we have tried to root out dbpf's from startup scripts. Main reasons:
-dbpf does not play well with autosave. If the PVs were changed by operators, and the IOC restarts, the autosaved values will be overwritten, and you get a nice surprise __
-putting system configuration in dbpf's scatters the configuration parameters in places which are hard to track and find - unless you are very familiar with the whole system.
The main reason why people have used dbpf has been to overload default values from community templates.
There is a clear and understandable need for this; we do not want to fork and diverge from the upstream.
However, as a better (IMO) alternative, we use overloading of the records, as described here: https://urldefense.us/v3/__https://docs.epics-controls.org/en/latest/appdevguide/databaseDefinition.html*definitions-8__;Iw!!G_uCfscf7eWS!c5Iul-6qd9gvOLS8bKautlTg46ra1LRyWLkP83MkR8OF8t9quvtdonZ8I9Vg1VJ4d3dqt4-deHfcrw6254K-XaaJo1vR$
(I see some need for documentation improvement here...not the most obvious place to look for this feature).
Best regards,
Timo
On 2025-09-19, 05:32, "Tech-talk on behalf of Maren Purves via Tech-talk" <[email protected] <mailto:[email protected]> on behalf of [email protected] <mailto:[email protected]>> wrote:
We often use dbpf for temporary changes of alarm thresholds for
instrument temperatures and pressures.
The db contains what they should be if everything was working properly.
I don't see how that is bad coding.
Maren
On Thu, Sep 18, 2025 at 7:10 AM Michael Davidsaver via Tech-talk
<[email protected] <mailto:[email protected]>> wrote:
> On 9/18/25 07:54, Johnson, Andrew N. via Tech-talk wrote:
> Many of our IOCs use one or more “dbpf” commands in their startup script (sometimes after an epicsThreadSleep) ...
> Nooooooo!
> Finding a bunch of random, rarely commented, dbpf calls in an IOC start script is to me a bad code smell. The same goes for sleeps, only more so. Please investigate 'field(PINI, "RUNNING")', or look at other ways to actually synchronize startup.
> ... it should even be possible to handle disconnections and later reconnections for links to remote IOCs if you want to do that.
> imo. any well written driver for an ethernet attached device __needs__ to do this.
> Generally, I have found that the more effective way to coordinate connect/disconnect is at the driver level. Generally with a special device support to drive on-connect processing.
- Re: Help with bumpless IOC reboot, record linking and initialization concepts Maren Purves via Tech-talk
- Re: Help with bumpless IOC reboot, record linking and initialization concepts Ralph Lange via Tech-talk
- Re: Help with bumpless IOC reboot, record linking and initialization concepts Marco Filho via Tech-talk
- Re: Help with bumpless IOC reboot, record linking and initialization concepts Johnson, Andrew N. via Tech-talk
- Re: Help with bumpless IOC reboot, record linking and initialization concepts Michael Davidsaver via Tech-talk
Re: Help with bumpless IOC reboot, record linking and initialization concepts Mark Rivers via Tech-talk
EPICS core survey Pierrick Hanlet via Tech-talk
<2025>
2026
<2025>
2026
