1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Re: Help with bumpless IOC reboot, record linking and initialization concepts
To: Michael Davidsaver <[email protected]>, "Dmitry Yu. Bolkhovityanov" <[email protected]>
Date: Sun, 21 Sep 2025 16:49:21 +0000
Yes.
asynManager provides the following methods that are used use for connection management:
    asynStatus (*exceptionConnect)(asynUser *pasynUser);
    asynStatus (*exceptionDisconnect)(asynUser *pasynUser);
    asynStatus (*autoConnect)(asynUser *pasynUser,int yesNo);
    asynStatus (*isConnected)(asynUser *pasynUser,int *yesNo);
    asynStatus (*isAutoConnect)(asynUser *pasynUser,int *yesNo);
Those are documented here:
The asynCommon interface provides the following methods that asynManager and asyn clients use for connection management:
typedef struct  asynCommon {
    asynStatus (*connect)(void *drvPvt,asynUser *pasynUser);
    asynStatus (*disconnect)(void *drvPvt,asynUser *pasynUser);
}asynCommon;
These methods must be implemented by all drivers.  They are documented here:
It is always good practice to load an asyn record for each port.  That provides the following PVs:
Name
Access
Prompt
Data type
Description
AUCT
R/W
“Autoconnect”
DBF_MENU
Sets the autoconnect option. Choices are “noAutoConnect” and “autoConnect”. The value read reflects current state of the autoconnect flag, i.e. the value returned from isAutoConnect().
ENBL
R/W
“Disable/Enable”
DBF_MENU
Disables or enables the port. Choices are “Disable” and “Enable”. The value read reflects current state of the enabled flag, i.e. the value returned from isEnabled().
CNCT
R/W
“Connect/Disconnect”
DBF_MENU
Disconnects or connects the device. Choices are “Disconnect” and “Connect”. The value read reflects current state of the connected flag, i.e. the value returned from isConnected().
The asyn TCP driver (drvAsynIPPort) implements connection management.  It connects (opens the socket) when the pasynCommon->connect() method is called.  If the socket open is successful, then the driver calls pasynManager->exceptionConnect to indicate that it is connected.  If isAutoConnect is true then asynManager will call this method when the port is created, and whenever it is disconnected and a client queues an I/O request.  If isAutoConnect is false  then pasynCommon->connect() method must be called by the client.  Whenever the driver detects that the socket is disconnected it calls pasynManager->exceptionDisconnect to indicate that state.
It can take a long time for the OS to close a socket for a non-responsive device, and I/O operations only return the disconnected status once that happens.  The asynOption disconnectOnReadTimeout can be used to force the driver to disconnect whenever an I/O operation times out.  Michael Davidsaver has asked whether that should be the default behavior.  I would be interested to hear whether that would be acceptable, or would break expected behavior.
From: Tech-talk <[email protected]> on behalf of Dmitry Yu. Bolkhovityanov via Tech-talk <[email protected]>
Sent: Sunday, September 21, 2025 2:39 AM
Hi Michael!
On Sat, 20 Sep 2025, Michael Davidsaver via Tech-talk wrote:
> On 9/19/25 00:35, Marco Filho wrote:
>>  Ah, I think I didn't properly understand this email on the first read.
>> >  Generally, I have found that the more effective way to coordinate
>> >  connect/disconnect is at the driver level.  Generally with a special
>> >  device support to drive on-connect processing.
IMHO, it isn't a "more effective" but is rather the ONLY reliable way.
As only the driver code, which issues a connect() call and is directly
notified about connect success or failure, thus has first-hand knowledge
of the connection status and is able to perform connect/disconnect.
All the other ways use some form of side effects, which are unreliable
and can change with time.
>>  You mean disconnecting from the actual equipment before the PVs are
>>  initialized and then only connecting once all the links are properly
>>  initialized?
>>  If so, how do you detect at driver level that that has happened?
> I think you have right idea, although the other way around.  My thinking is
> that a driver initializes into a latched "error" state, which is cleared by
> processing a record.  I like this approach because it naturally leads to
> handling the initial connection the same as a re-connect.
For me it seems obvious to use 2 boolean PVs:
         1. "isConnected", which is SCAN="I/O intr" and is updated by the
            driver upon change of connection state to be 1 (connected) or 0
            (disconnected); initially value is 0.  (It can be naturally
            monitored by code and DB links; multiple "isConnected" values
            can be ANDed).
         2. "doConnect", which can be written to, =1 means "connect if not
            connected" and =0 means "disconnect".
Isn't such a thing already done somewhere in asyn, streamDevice etc.?
Re: Help with bumpless IOC reboot, record linking and initialization concepts Ralph Lange via Tech-talk
Re: Help with bumpless IOC reboot, record linking and initialization concepts Marco Filho via Tech-talk
Re: Help with bumpless IOC reboot, record linking and initialization concepts Johnson, Andrew N. via Tech-talk
Re: Help with bumpless IOC reboot, record linking and initialization concepts Michael Davidsaver via Tech-talk
Re: Help with bumpless IOC reboot, record linking and initialization concepts Dmitry Yu. Bolkhovityanov via Tech-talk
Prev: Re: Help with bumpless IOC reboot, record linking and initialization concepts Dmitry Yu. Bolkhovityanov via Tech-talk
Next: Re: Help with bumpless IOC reboot, record linking and initialization concepts Timo Korhonen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Next: Re: Help with bumpless IOC reboot, record linking and initialization concepts Marco Filho via Tech-talk
