1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: pvxs Access/list problem
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: "Heinz Junkes (FHI)" <[email protected]>, EPICS Tech-Talk <[email protected]>
Date: Tue, 11 Nov 2025 17:39:20 +0000
Hello Heinz,
Is there some way to make the RTEMS NTP startup to do a jump synchronization on boot-up first, then start the slower ntpd sync process? The time synchronization approach that we’ve been using on VxWorks for a long time sets the clock as soon as it connects, and I've seen a similar configuration on some older embedded Linux systems. This is from one of our rc.local files:
# Synchronize with time server
ntpclient -s -h timserv
ntpclient -l -h timserv -q 400 >&/dev/null&
The first line above jumps the clock, the second line starts ntpd or its equivalent to maintain sync. I suspect this approach will prevent similar issues in other subsystems, so I’d like the EPICS code in RTEMS to do this if possible.
- Andrew
Complexity comes for free, Simplicity you have to work for.
On 11/11/25, 10:48 AM, "Tech-talk" <[email protected]> wrote:
It must have something to do with clock synchronization/NTP (that's my guess).
Immediately after booting, when NTP is not yet synchronized, pvlist and pvget PV work, for example.
(base) hactar:~ junkes$ pvget my:custom:pv
my:custom:pv <undefined>              42
I'll take another look tomorrow.
Danke Heinz
Begin forwarded message:
From: "Heinz Junkes \(FHI\) via Tech-talk" <[email protected]>
Date: 11. November 2025 at 13:55:42 CET
To: EPICS Tech-Talk <[email protected]>
Reply-To: "Heinz Junkes \(FHI\)" <[email protected]>
It seems to be an RTEMS issue. I have tested it extensively on Debian and OS X.
Everything is going as expected. Sorry for the noise here.
I need to take a look at what the problem is with RTEMS.
Danke Heinz
On 10. Nov 2025, at 21:07, Heinz Junkes via Tech-talk <[email protected]> wrote:
HI,
On 10. Nov 2025, at 17:17, Michael Davidsaver <[email protected]> wrote:
On 11/10/25 1:34 AM, Heinz Junkes (FHI) via Tech-talk wrote:
Unfortunately, reading the PVs doesn't work either:
(base) hactar:~ junkes$ env |grep EPICS_PVA
EPICS_PVA_ADDR_LIST=141.14.128.12
EPICS_PVA_AUTO_ADDR_LIST=NO
(base) hactar:~ junkes$ pvget rtems:aiExample
Timeout
rtems:aiExample (base) hactar:~ junkes$ pvget my:custom:pv
Timeout
Does anyone have any idea what I'm overlooking?
Are you able to ping the IOC (141.14.128.12) from this host (141.14.128.70)?
(base) hactar:~ junkes$ ifconfig en0
en0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
options=50b<RXCSUM,TXCSUM,VLAN_HWTAGGING,AV,CHANNEL_IO>
ether 38:f9:d3:09:e8:15
inet6 fe80::14bb:5995:e241:143e%en0 prefixlen 64 secured scopeid 0x4
inet 141.14.128.70 netmask 0xfffff000 broadcast 141.14.143.255
nd6 options=201<PERFORMNUD,DAD>
media: autoselect (1000baseT <full-duplex,flow-control>)
status: active
(base) hactar:~ junkes$ ping gonzo
PING gonzo.rz-berlin.mpg.de (141.14.128.12): 56 data bytes
64 bytes from 141.14.128.12: icmp_seq=0 ttl=64 time=0.264 ms
64 bytes from 141.14.128.12: icmp_seq=1 ttl=64 time=0.295 ms
64 bytes from 141.14.128.12: icmp_seq=2 ttl=64 time=0.404 ms
^C
--- gonzo.rz-berlin.mpg.de ping statistics ---
3 packets transmitted, 3 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 0.264/0.321/0.404/0.060 ms
Can you connect to TCP 5076?  eg. with:
telnet 141.14.128.12 5075
(base) hactar:~ junkes$ telnet 141.14.128.12 5075
Trying 141.14.128.12...
Connected to 141.14.128.12.
Escape character is '^]'.
���� anonymousca
Also, you might setup a PVA link on this IOC with a distinctive PV name, then use 'pvxvct' on the host to look for those search broadcasts.
rrtems@rtems-dev:~/MVME6100_7/EPICS/epics-support/pvxs/bin/linux-x86_64$ ./pvxget my:custom:pv
Timeout with 1 outstanding
leads to :
rtems@rtems-dev:~/MVME6100_7/EPICS/epics-support/pvxs/bin/linux-x86_64$ ./pvxvct -P my:custom:pv
2025-11-10T21:05:52.932458937 INFO pvxvct 141.14.131.228:39384 Beacon 0x0d5dc20423f82d6367a9991d 141.14.131.228:42479
2025-11-10T21:05:56.103177244 INFO pvxvct 141.14.128.65:36209 Searching for:
2025-11-10T21:05:56.103207467 INFO pvxvct   "my:custom:pv"
2025-11-10T21:05:56.103213055 INFO pvxvct 10.1.2.3:36209 Searching for:
2025-11-10T21:05:56.103215518 INFO pvxvct   "my:custom:pv"
2025-11-10T21:05:56.291459974 INFO pvxvct 141.14.128.65:36209 Searching for:
2025-11-10T21:05:56.291488184 INFO pvxvct   "my:custom:pv"
2025-11-10T21:05:56.291494840 INFO pvxvct 10.1.2.3:36209 Searching for:
2025-11-10T21:05:56.291505468 INFO pvxvct   "my:custom:pv"
2025-11-10T21:06:03.523642481 INFO pvxvct 141.14.136.101:44036 Beacon 0x412ce9bbb99971c4925b7f98 141.14.136.101:5075
2025-11-10T21:06:04.212423500 INFO pvxvct 141.14.135.248:60008 Beacon 0x3d28c96800000000332cf600 141.14.135.248:5075
^C2025-11-10T21:06:05.395957864 INFO pvxvct Done
Danke, Heinz
Re: pvxs Access/list problem Heinz Junkes via Tech-talk
Re: pvxs Access/list problem Heinz Junkes (FHI) via Tech-talk
Fwd: pvxs Access/list problem Heinz Junkes (FHI) via Tech-talk
Prev: Fwd: pvxs Access/list problem Heinz Junkes (FHI) via Tech-talk
Next: Re: caget: Identical process variable names on multiple servers Guruswamy, Tejas via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Next: Re: pvxs Access/list problem Heinz Junkes via Tech-talk
