Hi Lewis,
The message you quoted (Warning: "Identical process variable names on multiple servers") is a warning and is not fatal. By itself it does not indicate that caget will return a non-zero status. However the fact that it appeared once and then disappeared again
suggests something had temporarily changed about your network configuration or access (a gateway started/stopped responding, a router forwarded something it usually doesn't, ...), which could be the underlying reason for the failure.
Did your message really refer to the ip:port
0.0.0.1:5 ?
Almost exclusively the 0.0.0.0/8 subnet is used by hosts which are trying to discover their correct address (for example, DHCP requests always come from 0.0.0.0). But I've never seen 0.0.0.1, nor an application intentionally running on port 5.
Is it possible something had a momentary glitch and you got a corrupted packet? It would have to be something like the packet data being interpreted as the header. Not sure how that could happen and still pass checksums, but I also don't see how you can get
that weird ip/port combo through any intentional network configuration.
(Proof the warning is harmless to caget's exit status:
$ caget Eiger4m:alive ; echo $?
Eiger4m:alive 57105
CA.Client.Exception...............................................
Context: "Channel: "Eiger4m:alive", Connecting to: zzz:5064, Ignored: yyy:5064"
Source File: ../cac.cpp line 1321
Current Time: Tue Nov 11 2025 12:06:15.117025996
Current Time: Tue Nov 11 2025 12:06:15.117080077
0
Tejas Guruswamy
APS, XSD-DET
Argonne National Laboratory
On 11/10, Paul Sichta wrote:
> Lewis,
Hi, Paul!
Thank you for your reply.
> For the "Identical PV" message:
> Is there a gateway on the 10.0.9 subnet that could be using ioc23 as a
> client?
No. However, there is a CA gateway on 192.168.0.2, which is provided by
the APS, and which is listed in EPICS_CA_ADDR_LIST; ioc23 connects to
that for some PVs. Could that be a problem?
(And of course, the strange thing is that this is very rare. Out of
thousands of times running this command, it failed just this one time.)
> Your 10.0.9.255 is a broadcast.
> 0.0.0.2:5, is not in your ADDR_LIST, so why is it answering your call?
Indeed. And the same for 0.0.0.1:5. I have no idea what that is. The
0.0.0.0/8 network doesn't even exist on my infrastructure.
Lewis
