1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: caget: Identical process variable names on multiple servers
From: "J. Lewis Muir via Tech-talk" <[email protected]>
To: "Smith, Martin" <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Wed, 12 Nov 2025 16:45:34 -0600
On 11/11, Smith, Martin wrote:
> I think that this is happening because your PV name starts with a capital letter. At APS PVs that start with a
> capital letter are usually accelerator PVs so the PV gateway for your beamline lets that through. Although
> This should not be getting back through the reverse PV gateway but seems that it is. So the PV appears to be
> a duplicate I would guess because the PV gateway probably shows it has one and your IOC says that it has
> one.
Hi, Marty!
The PV name starting with a capital letter was Tejas's example, not
mine.  In my case, the actual PV names start with a number, not a
capital letter.
Still, this is a PV naming restriction for beamlines at the APS
that I did not know about.  Is it an official restriction, or are
you just wondering if it might be related to that due to a possible
misconfiguration in the APS-managed CA gateway that's on each sector's
"public" network?
Basically, I don't think there is a PV named the same as mine on the
APS accelerator side of things, so then I don't understand how the
APS-managed CA gateway could claim to have that PV.
> The thing I think that you would want to note is which CA server did it actually connect to and which got ignored.
Yes, and unfortunately, all I have is what it says in the
CA.Client.Exception messages, which is 0.0.0.1:5 and 0.0.0.2:5.  Is
there some other way for me to tell which CA server it ultimately
connected to?
But on top of that, and I just included this in my reply to Tejas, but I
failed to include the following error message that appeared right after
the CA.Client.Exception messages, which might indicate that it didn't
connect to any CA server in this case:
Channel connect timed out: some PV(s) not found.
> At APS beamline PVs should start with either with a lower case letter or a number which will help prevent this
> sort of thing from happening.
OK, the actual PV names in this case started with a number, so I'm
thinking that means that's not the problem.
> If you want to have a private conversation about this I would be happy to look into this issue for you.
OK, thanks.
> As far as if you are getting strange IP addresses I'm not sure what that is about.
Yeah, me neither.
Thanks!
Lewis
caget: Identical process variable names on multiple servers J. Lewis Muir via Tech-talk
Re: caget: Identical process variable names on multiple servers Paul Sichta via Tech-talk
Re: caget: Identical process variable names on multiple servers J. Lewis Muir via Tech-talk
Re: caget: Identical process variable names on multiple servers Guruswamy, Tejas via Tech-talk
Re: caget: Identical process variable names on multiple servers Smith, Martin via Tech-talk
Prev: Re: caget: Identical process variable names on multiple servers J. Lewis Muir via Tech-talk
Next: Re: caget: Identical process variable names on multiple servers Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: Re: caget: Identical process variable names on multiple servers Smith, Martin via Tech-talk
