1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: MAXnet Alarm State Under High Motor Command Load
From: Jiajun Tian via Tech-talk <tech-talk at aps.anl.gov>
To: "Peterson, Kevin M." <kmpeters at anl.gov>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 28 Jan 2026 22:20:49 +0000
Hi Kevin
No MAXnet communication errors on the IOC shell.
When the error occurred, "Controller Error" was displayed on the MEDM ( from .STAT PV)
Here is the full Bluesky error message:
[I 2026-01-27 20:51:15,009 bluesky_queueserver.manager.plan_monitoring] Run was closed: 'b6ba8da7-91a8-4b70-b7b2-7175759a9c57'
ERROR:bluesky:Run aborted
ophyd.utils.errors.UnknownStatusFailure: The status MoveStatus(done=False, pos=sy, elapsed=15.9, success=False, settle_time=0.0) has failed. To obtain more specific, helpful errors in the future, update the Device to use set_exception(...) instead of _finished(success=False).
The above exception was the direct cause of the following exception:
Traceback (most recent call last):
  File "/home/chem_epics/anaconda3/envs/pydm/lib/python3.10/site-packages/bluesky/run_engine.py", line 1609, in _run
    msg = self._plan_stack[-1].send(resp)
  File "/home/chem_epics/anaconda3/envs/pydm/lib/python3.10/site-packages/bluesky/preprocessors.py", line 413, in subs_wrapper
    return (yield from finalize_wrapper(_inner_plan(), _unsubscribe()))
  File "/home/chem_epics/anaconda3/envs/pydm/lib/python3.10/site-packages/bluesky/preprocessors.py", line 536, in finalize_wrapper
    ret = yield from plan
  File "/home/chem_epics/anaconda3/envs/pydm/lib/python3.10/site-packages/bluesky/preprocessors.py", line 411, in _inner_plan
    return (yield from plan)
  File "<string>", line 201, in uvvis_channel_scan
  File "<string>", line 166, in inner_plan
  File "<string>", line 131, in uvvis_csv_scan
  File "/home/chem_epics/anaconda3/envs/pydm/lib/python3.10/site-packages/bluesky/utils/__init__.py", line 1258, in dec_inner
  File "/home/chem_epics/anaconda3/envs/pydm/lib/python3.10/site-packages/bluesky/preprocessors.py", line 358, in run_wrapper
    yield from contingency_wrapper(plan, except_plan=except_plan, else_plan=close_run)
  File "/home/chem_epics/anaconda3/envs/pydm/lib/python3.10/site-packages/bluesky/preprocessors.py", line 604, in contingency_wrapper
  File "<string>", line 102, in inner_plan
  File "/home/chem_epics/anaconda3/envs/pydm/lib/python3.10/site-packages/bluesky/utils/__init__.py", line 1952, in __iter__
    return (yield from self._iter)
  File "/home/chem_epics/anaconda3/envs/pydm/lib/python3.10/site-packages/bluesky/plan_stubs.py", line 392, in mv
    yield Msg("wait", None, group=group)
  File "/home/chem_epics/anaconda3/envs/pydm/lib/python3.10/site-packages/bluesky/run_engine.py", line 2399, in _status_object_completed
    raise FailedStatus(ret) from exc
bluesky.utils.FailedStatus: MoveStatus(done=True, pos=sy, elapsed=15.9, success=False, settle_time=0.0)
[E 2026-01-27 20:51:15,010 bluesky_queueserver.manager.worker] The plan failed: Plan failed: MoveStatus(done=True, pos=sy, elapsed=15.9, success=False, settle_time=0.0)
ERROR:ophyd.objects:Motion failed: sx is in an alarm state status=AlarmStatus.STATE severity=AlarmSeverity.MAJOR
Jiajun
Jiajun Tian, Ph.D.
Postdoctoral Researcher
NSF’s ChemMatCARS, Pritzker School of Molecular Engineering
University of Chicago
9700 S Cass Ave Bldg 434D
Lemont, IL-60439
United States
Sent: Wednesday, January 28, 2026 2:01 PM
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>; Jiajun Tian <jiajtian at uchicago.edu>
Jiajun,
Are there any MAXnet communication errors on the IOC's shell when the bluesky/ophyd errors occur?
Kevin
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Jiajun Tian via Tech-talk <tech-talk at aps.anl.gov>
Sent: Wednesday, January 28, 2026 10:32 AM
Subject: MAXnet Alarm State Under High Motor Command Load
Hi All,
We are using an OMS MAXnet motor controller via an EPICS IOC, with motion driven by Bluesky plans (Ophyd). Under a high rate of consecutive motor move commands, the motor PVs enter an EPICS alarm state after several moves. When this happens, Ophyd reports a failed MoveStatus, and the Bluesky RunEngine aborts.
The MAXnet is primarily connected via Ethernet. We have also observed similar behavior when using a serial connection, where the issue occurs more frequently.
Has anyone experienced similar MAXnet issues with EPICS, or can advise on relevant settings or configuration considerations?
Related error observed in Bluesky/Ophyd:
ERROR:ophyd.objects: Motion failed: sx is in an alarm state status=AlarmStatus.STATE severity=AlarmSeverity.MAJOR
Thanks in advance,
Jiajun
Jiajun Tian, Ph.D.
Lemont, IL-60439
United States
Re: MAXnet Alarm State Under High Motor Command Load Peterson, Kevin M. via Tech-talk
MAXnet Alarm State Under High Motor Command Load Jiajun Tian via Tech-talk
Prev: Re: MAXnet Alarm State Under High Motor Command Load Peterson, Kevin M. via Tech-talk
Next: RE: Investigating Archiver Appliance lost events Sky Brewer via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Next: Re: MAXnet Alarm State Under High Motor Command Load Peterson, Kevin M. via Tech-talk
