1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
Subject: Yes, Base 7.0.10 was released!
From: "Johnson, Andrew N. via Tech-talk" <tech-talk at aps.anl.gov>
To: Han Lee <jeonglee at lbl.gov>, EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Wed, 11 Feb 2026 00:07:22 +0000
Dear Han and the EPICS community,
I completed the EPICS 7.0.10 release process today after fixing a final issue with the Release Note generation. My apologies for the delay in getting this out. The tar file that was generated and published on February 5th remains unchanged, although the documentation directory contents aren’t quite identical to the version on GitHub that was tagged as R7.0.10.
The changes in this release are documented in the Release Notes, which include many nice enhancements to the IOC shell, libCom facilities, record types, documentation, and should make life slightly easier for our developers in the future. Many thanks to everyone who has contributed to this release.
The full set of documentation created from this release can be found here.
For installation and use of published releases, we recommend downloading and building the tar file instead of checking out the tag from our GitHub repository. Links to the downloads are available here or here.
- Andrew
Complexity comes for free, Simplicity you have to work for.
On 2/9/26, 7:15 PM, "Tech-talk" <tech-talk-bounces at aps.anl.gov> wrote:
Hi Ralph,
Thank you for the update. I would be happy to help speed up the process if I can be of assistance. Please let me know what specifically needs to be done, and I will check my availability.
As I am trying to avoid unnecessary international travel this year, I won't be attending the Codeathon, but I hope you have a great time!
Best,
Han
On Sat, Feb 7, 2026 at 5:42 AM Ralph Lange via Tech-talk <tech-talk at aps.anl.gov> wrote:
On Sat, 7 Feb 2026 at 02:55, Han Lee via Tech-talk <tech-talk at aps.anl.gov> wrote:
I noticed that the R7.0.10 tag has been created on GitHub
However, I haven't seen any accompanying release notes or documentation.
Could someone please provide an update on the current status of this release?
Currently being released.
Tagging is done, tar files and generated documentation exist, but we had an issue with the generated documentation and want to double-check that it's fixed before finalizing.
Help is always welcome. See you at the Codeathon!
Cheers,
~Ralph
Jeong Han Lee, Dr.rer.nat.
Staff Scientist and Engineer
Lawrence Berkeley National Laboratory
Re: Yes, Base 7.0.10 was released! Han Lee via Tech-talk
Base 7.0.10 was released ? Han Lee via Tech-talk
Re: Base 7.0.10 was released ? Ralph Lange via Tech-talk
Re: Base 7.0.10 was released ? Han Lee via Tech-talk
Prev: Re: Support for piezo controller nanoFAKTUR EBD-060310 Torsten Bögershausen via Tech-talk
Next: Question: CA monitor event and timestamp handling on compress record reset Kim, Kukhee via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
Prev: Re: Base 7.0.10 was released ? Han Lee via Tech-talk
Next: Re: Yes, Base 7.0.10 was released! Han Lee via Tech-talk
