1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: [EXTERNAL] Does every DB record need to produce a PV?
From: "Sukhanov, Andrei via Tech-talk" <tech-talk at aps.anl.gov>
To: "Hartman, Steven" <hartmansm at ornl.gov>, David Bracey <dbracey at fnal.gov>, "Sukhanov, Andrei" <sukhanov at bnl.gov>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 17 Feb 2026 21:17:40 +0000
Mark, concerning your reply:
>To provide another counter-example I just checked the IOC for a >Dectris Eiger detector....
The Dectris Eiger Programming Manual is about 50 pages long and describes ~200 real parameters. I would approach support for the Dectris Eiger detector in Python using the following roadmap:
As a result, you would obtain a ready-to-run Python module serving ~200 PVs.
Final tuning with the real device may take several days. Debugging with the real hardware is significantly simpler in Python than in C/C++.
Processing detector data would be better handled by separate PVAccess servers.
Regards, Andrey
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Sukhanov, Andrei via Tech-talk <tech-talk at aps.anl.gov>
Sent: Tuesday, February 17, 2026 2:18 PM
To: Hartman, Steven <hartmansm at ornl.gov>; David Bracey <dbracey at fnal.gov>
Cc: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
From my perspective, an EPICS IOC with ~2000 PVs lacking descriptions, for a device without a Programmer’s Manual, is unmanageable. From: Hartman, Steven <hartmansm@ ornl. gov> Sent: Tuesday, February 17, 2026 12: 58 PM To: Sukhanov, Andrei
ZjQcmQRYFpfptBannerStart
This Message Is From an External Sender
This message came from outside your organization.
ZjQcmQRYFpfptBannerEnd
Sent: Tuesday, February 17, 2026 12:58 PM
To: Sukhanov, Andrei <sukhanov at bnl.gov>; David Bracey <dbracey at fnal.gov>
What makes you think this is unmanageable? There are plenty of counter examples of existing facilities where this works. -- Steven Hartman hartmansm@ ornl. gov On Feb 17, 2026, at 12: 12 PM, Sukhanov, Andrei via Tech-talk <tech-talk@ aps. anl. gov>
Steven Hartman
On Feb 17, 2026, at 12:12 PM, Sukhanov, Andrei via Tech-talk <tech-talk at aps.anl.gov> wrote:
This email was sent from a non-ORNL address. If suspicious, use the Report Phish button in Outlook.
Mark, Kai,
The multitude of the PVs, not related to real device parameters, may pose real trouble for end users. For example, we were provided with an EPICS-driven PSC (power supply controller). The controller itself has ~200 of control parameters. But the IOC hosts ~2000 of PVS. This is just not manageable without tight support from original designers.
/Andrey Sukhanov,
Collider-Accelerator Department, BNL.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
Sent: Tuesday, February 17, 2026 11:54 AM
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>; David Bracey <dbracey at fnal.gov>
Subject: Re: Does every DB record need to produce a PV?
Hi Dave,
  • A naïve user of EPICS would think that every database record of every IOC gets exposed as a PV.
Note that there is not a 1:1 relationship between records and PVs.  Even simple records like "bi" expose many record fields as PVs, not just the .VAL field.  For example, the .SCAN, .ZNAM, .ONAM, .SDIS, .DESC, and many more.  More complex records like the "motor" record have dozens of PVs, like .VELO, .ACCL, .STOP, .DVAL, .RVAL, etc.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of David Bracey via Tech-talk <tech-talk at aps.anl.gov>
Sent: Monday, February 16, 2026 10:15 AM
Subject: Does every DB record need to produce a PV?
Is this truly the case?  If so, has any mechanism for hiding the “internal” records ever been discussed?
The PV-space of an EPICS deployment seems very crowded.
Dave Bracey
AD Controls
Fermi National Accelerator Laboratory
Re: [EXTERNAL] Does every DB record need to produce a PV? Mark Rivers via Tech-talk
Re: [EXTERNAL] Does every DB record need to produce a PV? Kasemir, Kay via Tech-talk
Does every DB record need to produce a PV? David Bracey via Tech-talk
Re: Does every DB record need to produce a PV? Mark Rivers via Tech-talk
Re: Does every DB record need to produce a PV? Sukhanov, Andrei via Tech-talk
Re: [EXTERNAL] Does every DB record need to produce a PV? Hartman, Steven via Tech-talk
Re: [EXTERNAL] Does every DB record need to produce a PV? Sukhanov, Andrei via Tech-talk
Prev: Re: [EXTERNAL] Does every DB record need to produce a PV? Johnson, Andrew N. via Tech-talk
Next: Re: [EXTERNAL] Does every DB record need to produce a PV? Tynan Ford via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: [EXTERNAL] Does every DB record need to produce a PV? Tynan Ford via Tech-talk
Next: Re: [EXTERNAL] Does every DB record need to produce a PV? Mark Rivers via Tech-talk
