1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: [EXTERNAL] Does every DB record need to produce a PV?
From: Tynan Ford via Tech-talk <tech-talk at aps.anl.gov>
To: "Johnson, Andrew N." <anj at anl.gov>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 17 Feb 2026 13:24:18 -0800
Hi Andrew,
> Do other sites using the Channel Finder have similar issues with internal PVs being included in its PV name database and making it harder to identify the public ones? Do you filter out the internal PVs at all?
There is a new iocsh function in reccaster (since version 1.8) called addReccasterExcludePattern. It lets you exclude PVs from being sent by reccaster via wildcard patterns. One project here also uses the underscore convention at the end of PV names and we have added this to all IOCs - addReccasterExcludePattern("*_"). That definitely helped clean up the channel finder searches for users.
Tynan
On Tue, Feb 17, 2026 at 1:01 PM Johnson, Andrew N. via Tech-talk <tech-talk at aps.anl.gov> wrote:
Hi Andrei,
I suspect that you only see this device’s internal PV names because you're running the recsync module’s RecCaster or its equivalent on the IOC, making all of its PVs visible through the Channel Finder. The device documentation probably doesn’t list or describe the internal PVs because the supplier didn't intend them to be accessed by users.
We have Channel Finder installed at APS, but I suspect only a few people use it. Our naming convention allows us to mark internal PV names as such, but I don’t know if we filter those out of the CF database, and we do have commercial IOCs that don’t follow that convention. The PV name files that our IOCs generate (we don’t use recsync) are searchable, but only with some expert-level command-line programs or directly using grep, so our non-expert users normally only see the PV names on their GUI display widgets.
- Andrew
Complexity comes for free, Simplicity you have to work for.
On 2/17/26, 1:19 PM, "Andrei Sukhanov" <sukhanov at bnl.gov> wrote:
From my perspective, an EPICS IOC with ~2000 PVs lacking descriptions, for a device without a Programmer’s Manual, is unmanageable.
Sent: Tuesday, February 17, 2026 12:58 PM
To: Sukhanov, Andrei <sukhanov at bnl.gov>; David Bracey <dbracey at fnal.gov>
Cc: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
This Message Is From an External Sender
This message came from outside your organization.
What makes you think this is unmanageable? There are plenty of counter examples of existing facilities where this works.
Steven Hartman
On Feb 17, 2026, at 12:12 PM, Sukhanov, Andrei via Tech-talk <tech-talk at aps.anl.gov> wrote:
This email was sent from a non-ORNL address. If suspicious, use the Report Phish button in Outlook.
Mark, Kai,
The multitude of the PVs, not related to real device parameters, may pose real trouble for end users. For example, we were provided with an EPICS-driven PSC (power supply controller). The controller itself has ~200 of control parameters. But the IOC hosts ~2000 of PVS. This is just not manageable without tight support from original designers.
/Andrey Sukhanov,
Collider-Accelerator Department, BNL.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
Sent: Tuesday, February 17, 2026 11:54 AM
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>; David Bracey <dbracey at fnal.gov>
Subject: Re: Does every DB record need to produce a PV?
Hi Dave,
  • A naïve user of EPICS would think that every database record of every IOC gets exposed as a PV.
Note that there is not a 1:1 relationship between records and PVs.  Even simple records like "bi" expose many record fields as PVs, not just the .VAL field.  For example, the .SCAN, .ZNAM, .ONAM, .SDIS, .DESC, and many more.  More complex records like the "motor" record have dozens of PVs, like .VELO, .ACCL, .STOP, .DVAL, .RVAL, etc.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of David Bracey via Tech-talk <tech-talk at aps.anl.gov>
Sent: Monday, February 16, 2026 10:15 AM
Subject: Does every DB record need to produce a PV?
Is this truly the case?  If so, has any mechanism for hiding the “internal” records ever been discussed?
The PV-space of an EPICS deployment seems very crowded.
Dave Bracey
AD Controls
Fermi National Accelerator Laboratory
Does every DB record need to produce a PV? David Bracey via Tech-talk
Re: Does every DB record need to produce a PV? Mark Rivers via Tech-talk
Re: Does every DB record need to produce a PV? Sukhanov, Andrei via Tech-talk
Re: [EXTERNAL] Does every DB record need to produce a PV? Hartman, Steven via Tech-talk
Re: [EXTERNAL] Does every DB record need to produce a PV? Sukhanov, Andrei via Tech-talk
Re: [EXTERNAL] Does every DB record need to produce a PV? Johnson, Andrew N. via Tech-talk
Prev: Re: [EXTERNAL] Does every DB record need to produce a PV? Sukhanov, Andrei via Tech-talk
Next: Re: [EXTERNAL] Does every DB record need to produce a PV? Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: [EXTERNAL] Does every DB record need to produce a PV? Johnson, Andrew N. via Tech-talk
Next: Re: [EXTERNAL] Does every DB record need to produce a PV? Sukhanov, Andrei via Tech-talk
