1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: [EXTERNAL] Does every DB record need to produce a PV?
From: Anders Lindh Olsson via Tech-talk <tech-talk at aps.anl.gov>
To: "Pearson, Matthew" <pearsonmr at ornl.gov>, EPICS Tech Talk <tech-talk at aps.anl.gov>, Ralph Lange <ralph.lange at gmx.de>
Date: Wed, 18 Feb 2026 15:23:44 +0000
> How do you handle database templates from upstream packages like areaDetector?
Depends on the case, but generally falls into one out of three solutions:
> I can see where that might be useful, but how do you handle moving PV names from internal to public or visa versa? Do you add a public alias name, or change the record name?
This is a completely different problem than internal/public, but the way we handle renames for things which have been in production and/or (potentially) has consumers is carefully (if at all).
Normally goes like:
* I always struggle with the idea to rename records as there is no persistence or unique identifier outside of the name.
Cheers
A
Sent: 18 February 2026 15:47
To: Anders Lindh Olsson <anders.lindholsson at ess.eu>; EPICS Tech Talk <tech-talk at aps.anl.gov>; Ralph Lange <ralph.lange at gmx.de>
Subject: RE: [EXTERNAL] Does every DB record need to produce a PV?
I’ve never found a need to mark some record names as internal and some not. I can see where that might be useful, but how do you handle moving PV names from internal to public or visa versa? Do you add a public alias name, or change the record name? How do you handle database templates from upstream packages like areaDetector?
Cheers,
Matt
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Anders Lindh Olsson via Tech-talk
Sent: Wednesday, February 18, 2026 5:43 AM
To: EPICS Tech Talk <tech-talk at aps.anl.gov>; Ralph Lange <ralph.lange at gmx.de>
> Do other sites using the Channel Finder have similar issues with internal PVs being included in its PV name database and making it harder to identify the public ones? Do you filter out the internal PVs at all? We do not have any real issues
We do not have any real issues at ESS, with ca 14 million between production and lab networks, all in ChannelFinder. We have talked about filtering out internal PVs but do not and most likely will not. We instead just mark the internal ones (using a pound symbol in the record names).
Cheers
A
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Ralph Lange via Tech-talk <tech-talk at aps.anl.gov>
Sent: 18 February 2026 09:48
On Tue, 17 Feb 2026 at 20:19, Sukhanov, Andrei via Tech-talk <tech-talk at aps.anl.gov> wrote:
From my perspective, an EPICS IOC with ~2000 PVs lacking descriptions, for a device without a Programmer’s Manual, is unmanageable.
Certainly. I completely agree. I've come across such things, and they're a pain.
But that's bad application quality, which is a different thing.
Like reading a bad book, which can be a painful experience. Where I don't think Microsoft Word (the tool they used) nor Merriam Webster (where they got the words from) is at fault.
Of course, nowadays, AI can write wonderful books. Amazon's ebooks section is full of them.
Cheers,
~Ralph
Re: [EXTERNAL] Does every DB record need to produce a PV? Simon Rose via Tech-talk
Does every DB record need to produce a PV? David Bracey via Tech-talk
Re: Does every DB record need to produce a PV? Mark Rivers via Tech-talk
Re: Does every DB record need to produce a PV? Sukhanov, Andrei via Tech-talk
Re: [EXTERNAL] Does every DB record need to produce a PV? Hartman, Steven via Tech-talk
Re: [EXTERNAL] Does every DB record need to produce a PV? Sukhanov, Andrei via Tech-talk
Re: [EXTERNAL] Does every DB record need to produce a PV? Ralph Lange via Tech-talk
Re: [EXTERNAL] Does every DB record need to produce a PV? Anders Lindh Olsson via Tech-talk
RE: [EXTERNAL] Does every DB record need to produce a PV? Pearson, Matthew via Tech-talk
Prev: Re: [EXTERNAL] Does every DB record need to produce a PV? Kasemir, Kay via Tech-talk
Next: Re: [EXTERNAL] Does every DB record need to produce a PV? Simon Rose via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: RE: [EXTERNAL] Does every DB record need to produce a PV? Pearson, Matthew via Tech-talk
