1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: pvxput denied via EPICS_PVA_NAME_SERVERS but works via EPICS_PVA_ADDR_LIST --- (pvxs 1.5.1 / p4p 4.1.7)
From: "Williams Jr., Ernest L. via Tech-talk" <tech-talk at aps.anl.gov>
To: EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Fri, 6 Mar 2026 17:41:46 +0000
Hi ,
I am doing some testing with a PVA gateway and ran into a behavior difference that I wanted to ask about.
My goal is to move some of our client configurations to use TCP name-server mode via the EPICS_PVA_NAME_SERVERS environment variable instead of the traditional UDP search mechanism.
This is particularly useful for Kubernetes-based deployments where UDP broadcast discovery is undesirable. In this case, I am pointing the environment variable at our PVA gateway.
However, I am seeing a difference in behavior between the two discovery methods.
Client Environment
Client tool: pvxs 1.5.1
Gateway implementation: p4p 4.1.7
Test PV
SIOC:SYS0:ML06:AO007 or Fred
Test 1 — Directed UDP search
Environment:
EPICS_PVA_ADDR_LIST=<pva-gateway-ip>:5167 EPICS_PVA_AUTO_ADDR_LIST=NO
Results:
Endpoint reported by pvxinfo:
SIOC:SYS0:ML06:AO007 from <pva-gateway-ip>:32925
Test 2 — TCP name-server mode
Environment:
EPICS_PVA_NAME_SERVERS=<pva-gateway-ip>:5169 EPICS_PVA_AUTO_ADDR_LIST=NO EPICS_PVA_ADDR_LIST=
Results:
ERROR RemoteError: Put permission denied by gateway
SIOC:SYS0:ML06:AO007 from <pva-gateway-ip>:5169
Observation
The PV resolves to different TCP endpoints depending on the discovery mechanism:
Mode
Resolved Endpoint
UDP search (EPICS_PVA_ADDR_LIST)
TCP name-server (EPICS_PVA_NAME_SERVERS)
Reads succeed in both cases, but writes only succeed when the connection goes through the dynamically advertised endpoint.
Question
Is it expected that the p4p gateway behaves differently for put authorization depending on whether the PV was resolved through:
In particular, should both mechanisms ultimately route the client through the same gateway path and authorization logic, or is there a known difference in how these endpoints are handled?
Our longer-term goal is to standardize on EPICS_PVA_NAME_SERVERS, since it works much better for containerized environments and controlled network paths. Before moving forward with that approach, I wanted to confirm whether the behavior I am seeing is expected or if I might be missing something in the gateway configuration.
If helpful, I can also provide packet traces or additional logs from the gateway side.
Thanks very much for any guidance.
Cheers,
Ernest Williams
Dept. Head, Controls Software Engineering
Instrumentation Division, Technology Innovation Directorate
SLAC National Laboratory, Stanford University
Re: pvxput denied via EPICS_PVA_NAME_SERVERS but works via EPICS_PVA_ADDR_LIST --- (pvxs 1.5.1 / p4p 4.1.7) Ralph Lange via Tech-talk
Re: pvxput denied via EPICS_PVA_NAME_SERVERS but works via EPICS_PVA_ADDR_LIST --- (pvxs 1.5.1 / p4p 4.1.7) Michael Davidsaver via Tech-talk
Prev: Re: Help in debugging ACF connection issue Ralph Lange via Tech-talk
Next: p4p helper module for device support development Sukhanov, Andrei via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: Propagating Frontend-Authenticated User Identity to EPICS CA/PVA Clients Michael Davidsaver via Tech-talk
Next: Re: pvxput denied via EPICS_PVA_NAME_SERVERS but works via EPICS_PVA_ADDR_LIST --- (pvxs 1.5.1 / p4p 4.1.7) Ralph Lange via Tech-talk
