On 3/5/26 4:54 PM, André Favoto via
Tech-talk wrote:
Hi all,
PVXS, and thus P4P, so far follows the convention of libca in not
providing an interface to override the "username" string.
Obviously, as a security feature this is quite weak. But then,
the ca-style "voluntary" authentication scheme is already quite
weak by modern standards.
I should first mention there is an ongoing Secure PVA (SPVA)
project to layer on TLS transport, with strong point-to-point
authentication by x509 certificate.
I would also highlight one significant difference between PVA/CA
vs. HTTP protocols. While HTTP passes authentication tokens (eg.
cookies) with each request, PVA and CA authenticate with each TCP
connection. So having different PVA identities means having
difference TCP connections. Be careful when thinking about an
http-to-pva bridge. Trying to proxy through end-user identity can
force significant duplication of subscription data, with
consequent increases in network bandwidth and system load on
IOCs. One of the reasons that a PVA and CA gateway (aka. proxy or
bridge) does not pass through identity is so that all downstream
subscribers to one PV can share a single upstream subscription.
See the diagrams on:
https ://epics-base.github.io/p4p/gw.html#background
In practice, lack of proxy authentication has proven not to be an
issue. Sites which have access control rules enforce at the
gateway boundary as it is simpler to update one gateway
configuration than to distribute changed ACF files to hundreds of
IOCs. (The SPVA project may eventually be able to change this
calculation, but not yet)
Context:
In web-based applications, users are often authenticated using
the organization's credentials (LDAP, SSO, etc.) before
interacting with a shared backend service. Besides the access
control from the application itself, the IOC Access
Security rules should also apply per authenticated user,
especially to avoid duplication of authorization logic in the
frontend application.
However, when a backend service mediates all EPICS operations,
the username seen by Access Security is the backend
The suggested fix is to also enforce the RBAC for the IOCs in
the frontend application - which I am trying to avoid, since
the source of credentials of the FE and the AS rules is the
same.
The question: with PVA and the "ca" authentication plugin, is
there a supported way to propagate the already
authenticated user identity from a frontend or service layer to
the IOC, so that AS rules are evaluated correctly per
user?
Suggestions of other perspectives for looking into this are
welcome.
Thanks!
