1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: Help in debugging ACF connection issue
From: "Hu, Yong via Tech-talk" <tech-talk at aps.anl.gov>
To: Érico Nogueira Rolim <erico.rolim at lnls.br>, Michael Davidsaver <mdavidsaver at gmail.com>, EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Fri, 6 Mar 2026 20:59:49 +0000
Hello again, Érico,
I think I have managed to reproduce your ACF connection issue. Here is what I did:
1.  Turn off my laptop's networks completely, including WIFI.
2. Open a terminal and use tcpdump to monitor EPICS search: # tcpdump -ni any udp port 5064
3.  Manually start the first softIOC 'bpm-fron':  it has an ACF which reads a PV (myCommand:just4TestACF) that is provided by the second softIOC 'bpm-rear' .
4.  Immediately manually start the second softIOC 'bpm-rear'.
Here is my debugging:
0) I wait for a long time, more than 5 minutes.
1) On 'bpm-front': ascar shows 'connected:never'; interestingly, dbcar shows '3 connected ...'  because I do have 3 dbCA links, something like 'LNK2,"myCommand:just4Test CA"' inside the softIOC 'bpm-front'.
epics> ascar 1
connected:never  read:no  write:no  myCommand:just4TestACF <disconnected>
1 channels 1 not connected
epics> dbcar
CA links in all records
Total 3 CA links; 3 connected, 0 not connected.
2) On 'bpm-rear': there are no clients connected.
epics> casr
Channel Access Server V4.13
No clients connected.
Here is a snippet of tcpdump which makes sense to me: 'bpm-front' sends UDP search through 127.0.0.1 at varied intervals, eventually every 4.5 minutes (<EPICS_CA_MAX_SEARCH_PERIOD=300-sec) continuously (not timeout as Ralph corrected my wording in another thread).
15:03:31.797239 IP 127.0.0.1.59092 > 127.0.0.1.5064: UDP, length 56
15:03:32.821997 IP 127.0.0.1.59092 > 127.0.0.1.5064: UDP, length 56
15:03:34.869266 IP 127.0.0.1.59092 > 127.0.0.1.5064: UDP, length 56
15:12:15.058636 IP 127.0.0.1.59092 > 127.0.0.1.5064: UDP, length 56
15:16:37.198335 IP 127.0.0.1.59092 > 127.0.0.1.5064: UDP, length 56
15:20:59.337359 IP 127.0.0.1.59092 > 127.0.0.1.5064: UDP, length 56
3) test caget and camonitor, which fail:
$ caget myCommand:just4TestACF
Channel connect timed out: 'myCommand:just4TestACF' not found.
$ camonitor myCommand:just4TestACF
myCommand:just4TestACF         *** Not connected (PV not found)
osiLocalAddr(): only loopback found
4) Now, the most intriguing part: turn on laptop's networks (actually just WIFI). caget and camonitor both are working, getting the PV values ; tcpdump output message have changed a little bit because my laptop has a new IP '192.168.12.44'
15:40:12.856529 IP 192.168.12.44.53273 > 192.168.12.255.5064: UDP, length 56
15:40:12.857207 IP 192.168.12.44.5064 > 192.168.12.44.53273: UDP, length 40
However, on 'bpm-front', ascar still shows 'connected:never'. That is exactly what happened to your BPM system.
Conclusion: just as I mentioned below, most likely your IOCs start before your server's network is fully functional (valid IP address).
To CA developers: Is this a feature or a bug in the Access security Channel Access (asCa)?
Cheers,
Yong
Date: Thursday, March 5, 2026 at 12:47 PM
Hi Érico,
Thanks for sharing this interesting subtle CA connection issue.
Another thing worthy of checking: If you use systemd, make both IOC services start after network-online.target, to avoid your IOCs start before your NICs/IPs are fully functional.
I always think CA clients will continuously attempt to connect until timeout (EPICS_CA_MAX_SEARCH_PERIOD, 300-second). I am surprised it never connects in your asCa case.
Cheers,
Yong
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Érico Nogueira Rolim via Tech-talk <tech-talk at aps.anl.gov>
Date: Tuesday, February 24, 2026 at 1:14 PM
On 2/24/26 07:02, Michael Davidsaver wrote:
On 2/23/26 3:36 PM, Érico Nogueira Rolim via Tech-talk wrote:
Hi, all! We have had some occasional issues when rebooting servers in our BPM infrastructure, and I'd like to request guidance on how to best debug it. We have an IOC for each RF front-end and an IOC for the actual BPM board, and we have an Access Security rule to block writes to certain front-end PVs when the fast orbit distortion detection is enabled in the BPM board.
Sometimes, when these servers are rebooted, the front-end IOC is unable to connect to the PV from the BPM board IOC
So it never connects at all?  Odd.
Indeed. We rarely need to write to these PVs, so we can go without noticing these issues for months, and it doesn't connect for that whole time.
... While writing this email, I thought of adding a proxy record in the front-end DB that connects to the outside PV, and checking the connection on that. Should it yield different results? Is the connection path considerably different between DB links and AS links?
This seems an interesting test.  The asCa code [1] creates a separate CA client context to what the dbCa code (aka. CA_LINK) uses [2].  Both should use the same configuration from the environment, and so should yield the same result.
https ://github.com/epics-base/epics-base/blob/3855356d2faef8ccf67ae5d0a368d44ef2527a5c/modules/database/src/ioc/as/asCa.c#L172-L173
https ://github.com/epics-base/epics-base/blob/3855356d2faef8ccf67ae5d0a368d44ef2527a5c/modules/database/src/ioc/db/dbCa.c#L1108-L1109
I will make a patch for this and deploy it when possible, then. I'll report back when I have results!
Re: Help in debugging ACF connection issue Michael Davidsaver via Tech-talk
Help in debugging ACF connection issue Érico Nogueira Rolim via Tech-talk
Re: Help in debugging ACF connection issue Érico Nogueira Rolim via Tech-talk
Re: Help in debugging ACF connection issue Hu, Yong via Tech-talk
Prev: Re: pvxput denied via EPICS_PVA_NAME_SERVERS but works via EPICS_PVA_ADDR_LIST --- (pvxs 1.5.1 / p4p 4.1.7) Ralph Lange via Tech-talk
Next: Re: Propagating Frontend-Authenticated User Identity to EPICS CA/PVA Clients Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: Help in debugging ACF connection issue Hu, Yong via Tech-talk
Next: Re: Help in debugging ACF connection issue Michael Davidsaver via Tech-talk
